1974 Veloce "Full Package" - Page 2 - Alfa Romeo Bulletin Board & Forums
 9Likes
post #16 of 35 (permalink) Old 04-24-2019, 01:41 PM
Having picked up an Alfetta with Spica that had been sitting a while, I'd advise to replace all the fuel lines if possible when you do the filters. Mine seemed fine, but then sprung a huge leak about 9 mos later and I'm lucky to have not started a fire.
I wonder why the PO was removing the steering wheel?
1978 Alfetta Sport Sedan | 1985 GTV Lemons Racer
Instagram: Alfaddiction
peakay is offline
post #17 of 35 (permalink) Old 04-24-2019, 02:33 PM Thread Starter
I went over today and inflated the tires in preparation for the move. I got a little more information from the widow of PO. Apparently, it's been sitting since around the mid 90's and reportedly due to some sort of misfire, backfire, "shooting flames". The engine was also rebuilt around that time and only a few hundred miles on it since then. Additionally, some parts from a parts car added but I don't have information as to what and why but there is an (extra?) SPICA pump in the trunk.
Here's a few more photos too.
Billy_McSkintos is offline
post #18 of 35 (permalink) Old 04-24-2019, 04:00 PM
Wow, that is going to clean up nicely I bet . please post before/during/after photos! Also, I'm in newport if you need any help - always love resurrecting old cars.
peakay is offline
post #19 of 35 (permalink) Old 04-24-2019, 04:04 PM Thread Starter
@peakay, definitely, I'm sure I will be reaching out soon. I'm at the end of the 73 just where it meets the 5 so only 20 minutes...
post #20 of 35 (permalink) Old 04-24-2019, 04:52 PM
jbbosco's Avatar
Send a message via MSN to jbbosco
Wow, looks like a pretty good barn find - I bet you will be able to get a lot done yourself, including getting it started and running the first time. Everyone has an opinion, here is mine:
Most parts you can find at https://centerlinealfa.com or Vick Autosports, The Premier Fiat and Alfa Parts Source, and more obscure stuff can be found at https://classicalfa.com/
Buy this: https://www.themotorbookstore.com/al...er-manual.html (shop around for a cheap price)
Buy this: https://www.wesingram.com/pricesheet.htm#book
Remove the battery and just get a new one. If it doesn't hold a charge later on down the line, you'll know it's not that, and I'll sell you my spare alternator.
Hose down that engine bay - @AlfistiSA is spot on for engine bay cleaning procedure
Swap out the plugs - NGK BP7ES
New cap and rotor - make sure you figure out exactly what is needed, not sure if you have a MarelliPlex or..?
Fuel filters - replace the rear one for sure, whether you think it needs one or not.
Replace the engine oil, oil filter, SPICA filter - do all this at once, I like Castrol GTX 20W50, and the oil filter they sell at https://centerlinealfa.com is good.
Coolant - There is a well documented process to refilling the coolant so that you don't get air bubbles trapped in the system, be sure to follow this.
Transmission and diff oil - Use Redline 75W90 NS (NS is the important identifier) in the transmission, and Redline 75W90 in the diff.
Clean/replace the air filter - K&N makes a good replacement
New fan belt
Inspect braking system & replace brake fluid
Inspect /replace clutch cylinder fluid
Check the SPICA - @Roadtrip has the info you need here
... and go from there. https://www.alfabb.com/bb/forums/spi...aq-digest.html is very helpful. That should keep you busy for a while!
JB
'74 Spider
jbbosco is offline
post #21 of 35 (permalink) Old 04-24-2019, 05:15 PM
Great, let me know. I'm at the 73 and mcarthur.
peakay is offline
post #22 of 35 (permalink) Old 04-24-2019, 07:54 PM Thread Starter
Thank you all! @jbbosco do I need any special grease or similar when replacing the plugs?
post #23 of 35 (permalink) Old 04-24-2019, 09:00 PM Thread Starter
How do I install the rear bumper properly?
post #24 of 35 (permalink) Old 04-24-2019, 10:31 PM
Ranz's Avatar
'Backfire, misfire, shooting flames'.
Reckon the distributor wasn't well secured and may have moved after the rebuild.
Odds are the ignition timing is way out. Double-check that too.
Billy_McSkintos likes this.
Ranz is offline
post #25 of 35 (permalink) Old 04-25-2019, 01:46 PM Thread Starter
Quick question. I need to push the car up a short slope into my garage. After sitting for 20 odd years, what are your thoughts on whether there would be any kind braking available and if not, best safe method to stop the car if need be?
post #26 of 35 (permalink) Old 04-25-2019, 05:04 PM
radamm's Avatar
2x4s or the like would be a sensible precaution.
__________
Rick
[RIGHT] [I] MEMBRO LATO OSCURO[/I][/RIGHT]
69 850 Spider[I] [COLOR="Silver"](A fond college days' memory)[/COLOR][/I]
81 Spider Veloce
Downstate Illinois SNO Director
radamm is offline
post #27 of 35 (permalink) Old 04-25-2019, 05:15 PM
Ranz's Avatar
Brakes....
Does your park brake work?
Got a firm brake pedal?
Can you (or someone else) move the car with your foot on the brake, or with the park brake on?
That should tell you enough.
Ranz is offline
post #28 of 35 (permalink) Old 04-26-2019, 11:11 AM
This book has been very useful for me:
https://www.amazon.ca/Alfa-Romeo-Own...r=8-1-fkmrnull
1976 Spider
Canadian Spider is offline
post #29 of 35 (permalink) Old 04-26-2019, 05:12 PM
Jim G's Avatar
Do not push the brake pedal. More then likely if you do it won't be rolling anywhere. Just use the parking brake.
Jim G is online now
post #30 of 35 (permalink) Old 04-26-2019, 05:39 PM Thread Starter
Oops too late. Brakes worked enough but the handbrake didn't. Now that it's in my garage i can see a little more. Clutch pedal is on the floor, a few dings on the rear panels, no rust immediately obvious, missing the rear alfa and iniezione badges but after I go through the various extra parts I might them. Unfortunately, the dash is cracked in a few places and the turbina wheels have some curb rash so those have been added to the "make beautiful" list.
Cleaning over the weekend...
'74 Spider - in the works
Similar Threads
For Sale: 1974 2000 Spider Veloce Owners Manual set tirefriar Alfa Romeo Collectibles, Literature & Manuals For Sale & Wanted 2 12-20-2014 04:05 PM
2008 Convention Concours Chi Si Dici Car Events 5 05-19-2008 01:17 PM
1974 spider veloce alleygata Spider - 105 & 115 Series (1966-1994) 6 03-01-2007 07:09 PM
newbie considering 1974 Alfa Spyder Veloce...precautions? [email protected] Alfa Romeo Topics Not Covered Elsewhere 8 09-16-2005 02:27 PM
1974 Alfa Romeo Veloce 2000 for sale Omar Rodriguez Alfa Romeo Cars For Sale & Wanted 7 01-30-2003 04:25 PM
