Trany or Clutch? - Alfa Romeo Bulletin Board & Forums
post #1 of 5 (permalink) Old 04-15-2019, 05:46 PM Thread Starter
scagliog's Avatar
Trany or Clutch?
Hello...
1982 Spider. All of the sudden while driving only 5th gear would go in ( with force... )
Engine stopped, I can engage all gears fine, with or without clutch.
Clutch pushes fine, and I checked with my son pushing on the clutch pedal and me under the car that it moves the arm into the trany from the slave cylinder.
If I engage any gear when stopped, tried 3d and 4th, if I try to crank the engine to start with the clutch pressed, the engine is fully engaged like the clutch is having no effect...
I cannot remember if this is normal.. But I thought I could start the car with the clutch pressed in any gear... did not have to be in neutral.
Again, with some grinding I was able to put the car in 5th gear and I made it back home (oh yes it was something... ) flying thru stop signs in the country side not to stop the car!!
I am ready to have a mechanic friend pull the trany, but I am leaning toward something with the clutch... even if the plate only has 3000 miles or less, maybe the throwout bearing???
yes it is the original trasmission with a typical 2d gear grind and some other issues like not really liking going from 3d to 4th gear at high RPM...
Any comments or suggestions before I start spending money!
Giuseppe
"alfista"
scagliog is offline
post #2 of 5 (permalink) Old 04-18-2019, 08:55 AM
Andrew's Avatar
Sounds like clutch. Either way, you've got to remove something to fix. I'd measure how far the throw out bearing arm moves at the gearbox. If it moves the full distance, I think you need a clutch disk. If it doesn't, try replacing hydraulics first.
Andrew
Andrew is offline
post #3 of 5 (permalink) Old 04-18-2019, 10:22 AM
BB Janitor
ghnl's Avatar
Well, the transmission has to come out either way...
I agree with Andrew - first check that you have full movement of the operating fork at the slave cylinder. Usually the hydraulics are the weak link - leaks or entrained air. I've seen broken clutch discs where the pieces jam the clutch so it can't disengage even though the fork is moving the full distance.
One other thought - where does the clutch pedal sit relative to the brake pedal? It should be equal or slightly higher. If it is lower the pivot shaft weld may have failed. If it is lower and you can reach down and pull the pedal up it is almost certainly the pivot shaft failed. see: https://www.alfabb.com/bb/forums/1142619-post108.html
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #4 of 5 (permalink) Old 04-18-2019, 10:55 AM Thread Starter
scagliog's Avatar
Well the pivot was replaced..the clutch pedal is at the right hight..the master and slave cylinders have ~2500 miles..all seams to move correctly as far as hydraulics...yes next the trany and possibly the engine are coming out..stay tuned...
Giuseppe
"alfista"
scagliog is offline
post #5 of 5 (permalink) Old 04-18-2019, 01:45 PM
pantera928's Avatar
Definitely not disengaging. You can usually drive one and get through the gears without a clutch once you start off in first or second gear. Just carefully timed shifting between gears. Been there a few times on cars.
If you are getting the travel as mentioned by Eric, then you may have something in the clutch pressure plate or throw out bearing that has failed. I have seen one throw out bearing fail that way but that was years ago and it had just been replaced.
Good luck
pantera928 is offline
Similar Threads
Strange clutch behavior -- diagnosis? Canadian Spider Spider - 105 & 115 Series (1966-1994) 6 08-29-2017 09:57 AM
clutch pedal feel and operation mcola Spider - 105 & 115 Series (1966-1994) 27 09-10-2013 08:17 PM
Clutch engagement- out of ideas ninjzx998 Spider - 105 & 115 Series (1966-1994) 15 06-30-2012 06:36 PM
Clutch cover & clutch for Alfetta free GregSef Alfetta & GTV6 (1972-1986) 0 05-16-2012 08:27 AM
Clutch mystery Gary73Super Gearbox, Transaxle, Differential & Propshaft 22 12-16-2008 05:18 PM
