Engine removal instructions or link - Alfa Romeo Bulletin Board & Forums
 4Likes
  • 1 Post By Top Down
  • 1 Post By Andrew
  • 2 Post By Top Down
post #1 of 12 (permalink) Old 04-14-2019, 07:58 PM Thread Starter
I need to remove my 72 engine this weekend. Can anybody share instructions or a link to a thread please.
RIQUE is offline
post #2 of 12 (permalink) Old 04-17-2019, 02:39 PM
Top Down's Avatar
Remove the bonnet, radiator, carbs, remove battery, disconnect any wiring (starter, coil etc) undo the exhaust manifold from the head and if you can undo the manifold from the front pipe, tie up the exhaust.
Start to unbolt the engine mounts. Lift the car and remove the dust shield at the bottom of the gearbox. Remove gearbox to engine bolts accessible under the car. Lower the car.
Attach your engine sling/chain hoist/crane, support gearbox, remove remaining bellhousing bolts.
Now the fun starts!! Begin to lift the engine whilst pulling it forward, you may need to use a prybar to separate the engine from the gearbox, lift engine being careful of the paintwork (on the car, not the engine)
See, that was easy!
You may find it easier to remove as many ancillaries as you can to aid access and just make the lift easier, I'm talking about things like the alternator etc, just look and see what can be taken off.
Enjoy!
sbadaro likes this.
Daily drive is a Giulia 2.0 MA, wife drives a 939 Spider in the summer and a 1.6TS 147 in the winter. For special sunny days we have a S2 Spider Junior in the garage.
Top Down is offline
post #3 of 12 (permalink) Old 04-17-2019, 11:44 PM
sbadaro's Avatar
See, that was easy!
Enjoy!
You forgot the gearbox... Name:  FB_IMG_1554534481188.jpg
Sent from my F8332 using Tapatalk
sbadaro is online now
post #4 of 12 (permalink) Old 04-18-2019, 04:37 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
If you're removing the gearbox with the engine, raise the rear of the car and place on jack stands.
ossodiseppia is online now
post #5 of 12 (permalink) Old 04-18-2019, 07:23 AM
nealric's Avatar
I found I needed to put both the front and rear up so I could get the hoist underneath, but with the rear higher. I suppose that's not an issue if you have a gantry crane instead of a cheap harbor freight engine hoist like I do. One word of caution: the smaller of the two Harbor Freight hoists will not work in a spider even though the engine is not particularly heavy. The arm is not long enough to reach. I had to sell my small one on craigslist and buy the bigger one when I pulled my motor.
Agreed that it's usually going to be easier to remove the engine and gearbox together.
1986 Spider Veloce Turbo
nealric is offline
post #6 of 12 (permalink) Old 04-18-2019, 08:52 AM
Andrew's Avatar
Folks have their methods. I don't take out more than I need to. I find it easy to do the engine alone. Block up the front of the trans to support it. Make sure to remove the sway bar and the fan.
To each his/her own.
Andrew
Top Down likes this.
Andrew is online now
post #7 of 12 (permalink) Old 04-18-2019, 08:57 AM
nealric's Avatar
Andrew
I had no problem getting my motor out without the swaybar. YMMV I'm sure.
nealric is offline
post #8 of 12 (permalink) Old 04-18-2019, 02:32 PM
Top Down's Avatar
Same here. (anti roll bar this side the pond)
Top Down is offline
post #9 of 12 (permalink) Old 04-18-2019, 02:35 PM
Top Down's Avatar
Originally Posted by sbadaro View Post
You forgot the gearbox... Attachment 1561808
He never asked for the gearbox, now go put it back.
Ranz and sbadaro like this.
Top Down is offline
post #10 of 12 (permalink) Old 04-18-2019, 03:02 PM
Member
otteud96's Avatar
Remove the center tie rod link at one end or it will most likely get bent. Good luck
otteud96 is online now
post #11 of 12 (permalink) Old 04-18-2019, 03:07 PM
Member
otteud96's Avatar
Remove the center tie rod link at 1 end or it will likely get bent. Good luck
post #12 of 12 (permalink) Old 04-18-2019, 11:08 PM
sbadaro's Avatar
Dammit... Back to the shop...
Similar Threads
Engine mount replacement for the dummies Sapilot143 Spider - 105 & 115 Series (1966-1994) 118 08-11-2018 05:17 PM
Engine Removal: A couple of questions wutdhec Alfetta & GTV6 (1972-1986) 23 06-01-2014 10:01 PM
alternative engine removal methods kman42 Shop Talk 1 07-29-2013 09:16 AM
Engine removal procedure Giorgio68 Engine Repair, Diagnostics & Rebuilding 51 03-08-2010 06:45 AM
Engine removal - With or Without Bell Housing?? izeljic Milano/75 (1985-1993) 17 05-01-2006 07:20 AM
