My car keeps burning out condensers - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 1 Post By Alfisto Steve
  • 1 Post By Somer
post #1 of 14 (permalink) Old 04-12-2019, 03:03 PM Thread Starter
Hi guys-my 2 L single point distributor just ate its second condenser.. The first was a made in Italy one and the second was a generic that cross referenced to the car. Both separated where the wire comes out of the condenser body which may just be a coincidence but certainly seems odd
I have a Bosch blue 3 ohm coil ( which actually measured four ohms, not sure if that matters ) on it and new correct plugs. Plug wires are new.
When the first one went out I think my points gap being too narrow contributed to it, but this one went out with the points gap at .019 and it was only about 120 miles of driving before it failed.
Any ideas on what is going on - or just bad luck?
Thanks!
1966 Giulia Sprint $500 junk yard find. I probably overpaid...
1971 1750 Spider basket case , 1972 GTV 2.0 L
tdskip is offline
post #2 of 14 (permalink) Old 04-12-2019, 05:34 PM
Alfisto Steve's Avatar
Do you have a resistor in the coil circuit? We used to burn up 12v coils in a points and condensor Fiat dizzy conversion in a Lancia Beta coupe.
f4driver likes this.
Virginia Beach, VA
My Maintenance Sticky:
Alfisto Steve is offline
post #3 of 14 (permalink) Old 04-12-2019, 06:15 PM
There have been other posts about the poor quality of condensors. The demand for them is low and there is no money in making them for folks like Bosch and Marelli so they are made by companies with lousy quality control programs.
85 GTV6 3L
alfaparticle is online now
post #4 of 14 (permalink) Old 04-12-2019, 09:35 PM
Alfajay's Avatar
I don't think a Bosch blue coil needs a resistor.
Originally Posted by alfaparticle
There have been other posts about the poor quality of condensors...... they are made by companies with lousy quality control programs.
Yea, I think that's what's going on here. You might try finding a used condensor; the OE versions of those things lasted a long time.
Or just go with a Pertronix and ditch the condensor & points.
'63 Guilia spider
Alfajay is offline
post #5 of 14 (permalink) Old 04-13-2019, 05:47 AM
The Marelli system that has a 1.5 ohm ballast resistor plus a 1.5 ohm coil is superior to the simple Blue coil and no resistor. They both put the same load on the points but the Marelli makes stronger sparks during starting when the resistor is bypassed and also at higher rpm due to the lower coil inductance.
85 GTV6 3L
post #6 of 14 (permalink) Old 04-13-2019, 06:42 AM Thread Starter
Thanks gentlemen - I put a new high “quality” condenser in but I do think an electric ignition is the ticket.
Thanks for the responses!
tdskip is offline
post #7 of 14 (permalink) Old 04-15-2019, 03:03 AM
BMX
Bin the points and fit an electronic sensor or a 123..
1975 Spider S2
BMX is offline
post #8 of 14 (permalink) Old 04-15-2019, 07:35 AM
John533i's Avatar
This same thread goes on in the '6-pack' forum, for the Triumph TR-6, and an Alfa YouTuber named Jethro Bronner did a video on why he went to the '123' distributor. Seems like a common theme, but by TR6s points/condenser are working great after 2years. I'd make sure that your coil is right version for your model? Try a stock coil if you have one.
Luck, John
86 spider Veloce
74 TR6
John533i is offline
post #9 of 14 (permalink) Old 04-15-2019, 07:39 AM
Shakey's Avatar
The same thing is going on in the air-cooled VW community. I went through two Bosch condensers on my wife's fuel-injected Super Beetle. When the condensers got warm, they'd quit working. I installed a generic from AutoZone, and its been running great.
Lots of YouTube videos, etc. on crappy condensers...even with name brands.
-Kevin
Shakey is offline
post #10 of 14 (permalink) Old 04-18-2019, 04:33 PM
Somer's Avatar
All condensers are the same . I think it is something like .22 microfarads? Coils have to be matched to the ignition. An electronic ignition requires a different resistance than a points ignition.
Years ago, I went in an tried to buy a condenser at Pep-Boys. I threw a vehicle out there (351 Ford ). Guy said that's $135 ! I said "boy, they've gone up!". Turned out the only condenser he knew was an AC condenser !!
radamm likes this.
Somer is offline
post #11 of 14 (permalink) Old 04-18-2019, 04:45 PM
Most electronic ignitions can handle a wider range of coil resistance than points (which has nothing to do with condensors). There is more to a condensor (capacitor) than it's capacitance. Take a look at .22 mfd capacitors and you will see different shapes and sizes and they are not all interchangeable. Different voltage ratings require different materials of construction.
85 GTV6 3L
post #12 of 14 (permalink) Old 04-18-2019, 04:50 PM Thread Starter
Thanks guys - good to be aware of it being an industry issue.
I've got a new Bosch blue coil on there, correct OHM for the set up.
I'm heading towards a point-less system soon.
Appreciate the discussion!
tdskip is offline
post #13 of 14 (permalink) Old 04-18-2019, 06:49 PM
Bosch blue coils are for old VW bugs. The original setup with a 1.5 ohm coil and a 1.5 ohm ballast resistor is superior. AR knew what they were doing.
85 GTV6 3L
post #14 of 14 (permalink) Old 04-18-2019, 09:04 PM
Send a message via AIM to Calguy 17
Points and condensers are stone age technology today...Go with a Pertronix electronic ignition system and you will never have to mess with it again....
Calguy 17 is offline
Similar Threads
Alfa Romeo 6C1750 Gran Sport - Fifth Series iicarJohn Limited Production (1910-1949) 115 12-31-2018 03:23 PM
1300 GTJ 1972 Project car. Steve105 AROCASA - Alfa Romeo Owners Club of Australia (South Australian Division) 0 02-05-2018 04:42 AM
Cost breakdown of importing car from Europe Gary73Super Sedan (1962-1977) 33 04-01-2014 02:58 PM
For Sale: An Alfa Trilogy -- '67,'71 &'79 Euro Euro Spider 79 Alfa Romeo Cars For Sale & Wanted 13 08-23-2012 10:29 AM
A traumatic car week - need sympathy jamieandthemagi Alfa Romeo Topics Not Covered Elsewhere 4 05-06-2006 05:42 PM
