Main Battery Connection Cable - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 1 Post By alfaloco
  • 1 Post By spiderserie4
post #1 of 12 (permalink) Old 04-10-2019, 11:28 AM Thread Starter
As I was getting my 1991 Spider ready for spring, I discovered that the jacketing on the main battery connection cable that runs across the back of the engine compartment has melted away. Can anyone advise on the difficulty and process of replacing that cable? It is a continuous cable that runs from the trunk, under the car, and across the engine compartment? Thanks, John.
post #2 of 12 (permalink) Old 04-11-2019, 09:16 AM
Alfaboutvegas's Avatar
Difficulty?
John,
difficulty is of course depending on the tools you have accessible to your use. Do you have a lift for the Alfa? You will need to get under the car. The cable runs underneath to back of passenger seat area and enters the interior at the "tray" area. Continues through the "interior-trunk" wall, into the trunk, to the battery. It is one continuous cable.
Cable is secured at different intervals under the chassis along-side with gas & brake lines.
GLW endeavor.
be sure of proper wire mil size.
"No chance, no destiny, no fate can circumvent, change or control the firm resolve of a determined soul"
73 Spider
80 BMW e21(Sold, gone to Houston)
79 Spider (sold)
78 Spider (sold, gone to U K)
Greg
Alfaboutvegas is offline
post #3 of 12 (permalink) Old 04-11-2019, 10:09 AM Thread Starter
Fantastic! Thanks for the reply and constructive information. John.
post #4 of 12 (permalink) Old 04-11-2019, 10:36 AM
alfaloco's Avatar
You can buy new primary copper cables with insulator jackets online, by the foot, but the question still is, why did it melt the insulation jacket? Is there something lurking in there still, to bite you? Starter or solenoid short out?
[email protected] likes this.
alfaloco
Lexington, KY USA
alfaloco is offline
post #5 of 12 (permalink) Old 04-11-2019, 10:42 AM Thread Starter
I had to replace the alternator last year. The exposed wiring was green with oxidation. If the jacketing had melted by the time I replaced the alternator, I would have thought my mechanic would have said something.
post #6 of 12 (permalink) Old 04-11-2019, 03:53 PM
alfaloco's Avatar
Well, if you saw that kind of corrosion on the outside of the wiring and at terminals, you can bet it extended into the strands of copper wire, thus raising resistance and producing heat.
I'd suggest you have someone experienced in auto electrical systems do a voltage drop test on all your primary components... from the battery forward to the alternator, starter, and the junction block there on the fender where those red wires get distributed. You need to know the root cause of that kind of overheating, in my opinion. Maybe it was the corrosion, or maybe there's more to it.
f4driver likes this.
alfaloco
Lexington, KY USA
alfaloco is offline
post #7 of 12 (permalink) Old 04-12-2019, 01:16 AM
spiderserie4's Avatar
if the burned section of the cable is visible and doesn't actually disappear into the bulkhead, I'd look at professionally splicing in a new repair section with correct AWG wire.
alfaloco likes this.
spiderserie4 is online now
post #8 of 12 (permalink) Old 08-23-2019, 08:26 PM
clescn's Avatar
While this thread has been dormant for a while, I please ask: What is the correct AWG wire size for a 1991 Spider Veloce positive battery cable?
Thanks.
clescn is offline
post #9 of 12 (permalink) Old 08-23-2019, 09:11 PM
alfaloco's Avatar
Thanks.
On my '91, it looks like 1/0 or 2/0 AWG cable, based on the diameter.
alfaloco
Lexington, KY USA
alfaloco is offline
post #10 of 12 (permalink) Old 08-24-2019, 03:15 PM
clescn's Avatar
Thank you. I'll probably go with 2/0 AWG cable.
The reason I'm asking, I'm replacing the positive cable from battery to starter. Would anyone know the size of the stud (8 mm or 9 mm?) on the solenoid to which the battery attaches?
My thanks in advance.
clescn is offline
post #11 of 12 (permalink) Old 08-24-2019, 03:29 PM
Nakagtv's Avatar
Studs on starter solenoid are 8mm
Zaza
Current Alfas:
2018 Stelvio Ti Sport
1987 Milano Verde
1970 Euro-spec GTV 1750
Refreshing 1750 GTV
Nakagtv is offline
post #12 of 12 (permalink) Old 08-24-2019, 07:13 PM
clescn's Avatar
Thanks, Nakagtv.
clescn is offline
Tags
Similar Threads
Duetto Window Regulator Cable Replacement MrZo Spider - 105 & 115 Series (1966-1994) 9 07-30-2019 06:21 PM
Wanted: Positive Battery cable for 74 GTV goats Alfa Romeo Parts For Sale & Wanted 8 02-11-2015 03:08 PM
A couple of cable questions Lotuselise Spider - 105 & 115 Series (1966-1994) 4 12-17-2011 11:44 AM
Alfetta GTV Rear Mount Battery Cable Routing Cintos Alfetta & GTV6 (1972-1986) 6 12-20-2008 05:44 AM
Battery Cable (& Firewall Grommets) Bi-Motore GT (1963-1977) 0 09-26-2006 09:48 PM
