I've screwed up the spark on my spider! - Page 2 - Alfa Romeo Bulletin Board & Forums
 3Likes
post #16 of 23 (permalink) Old 04-04-2019, 01:20 PM
spiderserie4's Avatar
OK,
but first you really need to confirm the voltage whilst cranking, or we will all be going around in circles
Like I said if not showing 11V+ or thereabouts, nothing will work....it doesn't matter if your battery is reading a tip top 12.6V statically....you need to check cranking voltage, and you do not go by the voltgauge in the instrument cluster.
Hopefully you have a voltmeter? measure across the battery +/- poles and then crank the starter....let us know how many volts you get (useful to have someone else on hand, as the battery is in the trunk)
if that is good, move on to the flywheel sensor checks as per the 'L-jetronic spider diagnosis' (see post #10 above in Eric's signature)
if in the meantime you want to do something simple, then remove the shelf behind the seats. there you have an ECU and 2 relays....unplug and plug back the 2 relays a couple of times, just to make sure the contacts are OK.
spiderserie4 is offline
post #17 of 23 (permalink) Old 04-04-2019, 01:42 PM Thread Starter
lawrencedesigns's Avatar
Well, thanks for the help.
I indicated in an above post that I checked cranking voltage...It was 11.2
This happened suddenly after running perfectly just by putting dwell meter on the minus coil stud.
And a very loud buzz came from back at the ecu
I am sure I must of cooked it...tried everything else....
I'll take it to the shop
Keeth Lawrence
1988 Spider Veloce
lawrencedesigns is offline
post #18 of 23 (permalink) Old 04-04-2019, 02:04 PM
Originally Posted by lawrencedesigns View Post
I indicated in an above post that I checked cranking voltage...It was 11.6 - 11.8.
OK that is ideal cranking voltage (although I cannot see where you mentioned it above...)
(your edit: 11.2V is ideal as well!)
maybe you did fry the ignition ecu
the ignition ECU is the one behind the rear side carpet, passenger side
Bosch number for L-jetronic spiders is 0 227 400 003
you could send it out for checking/repairing to ECU doctors....costly, though you could send it to them for testing, just to be sure.
https://www.ecudoctors.com/alfaromeo-spider-003.html
let us know how it goes.
post #19 of 23 (permalink) Old 04-04-2019, 02:24 PM Thread Starter
Again...thank you all (especially spiderseries4) for your help.
She runs again!
Didn't see test lamp pulse in the sun...it is subtle.
Original HT cable came out hard...and looked really bad on the ends...almost crumbling apart.
Replaced HT with a new generic one...Seated it very well...
Gave it a few cranks...and success!
Shakey and abeasley like this.
Keeth Lawrence
1988 Spider Veloce
post #20 of 23 (permalink) Old 04-04-2019, 02:26 PM
great news! well done
post #21 of 23 (permalink) Old 04-04-2019, 02:36 PM
SkiBum's Avatar
I am so glad you found the issue! Isn't it strange how we will think of all kinds of crazy scenarios of what could be wrong while we overlook the simplest, easiest checks..... let this be a lesson to us all!
SkiBum is online now
post #22 of 23 (permalink) Old 04-05-2019, 08:33 PM
alfaromeoblack's Avatar
So glad to see you are on the road again
Ken Smith
alfaromeoblack is offline
post #23 of 23 (permalink) Old 04-05-2019, 11:47 PM
you might want to inspect the plug leads.
If the HT lead was almost crumbling apart, the spark leads might be showing similar signs of age.
Similar Threads
Available Wiring Diagrams papajam Electrical, Chassis & Lighting 1722 06-01-2019 05:35 AM
Giulietta/Giulia Spider Register pathung Giulietta & Giulia (1954-65) 553 05-17-2019 01:38 AM
pininfarina scrpit etc. placement konati Spider - 105 & 115 Series (1966-1994) 14 08-11-2015 08:25 AM
Performance debate smsmith Spider - 105 & 115 Series (1966-1994) 25 11-26-2013 02:14 PM
For Sale: Spider parts on eBay stellaromeo Alfa Romeo Parts For Sale & Wanted 0 09-06-2013 07:16 AM
