Fuel supply and return hoses on 1986 US Spider - Alfa Romeo Bulletin Board & Forums
post #1 of 8 (permalink) Old 04-02-2019, 08:53 PM Thread Starter
Lew
Member
Question Fuel supply and return hoses on 1986 US Spider
Hey everybody,
Finally getting around to replacing the 7.5 mm fuel supply and return hoses on the 1986 Spider. (Already replaced the fuel rail to injector lines). I'm trying to keep the hose as close to original as possible. The supply and return lines have been replaced once already, so are not the originals. Does anyone know what manufacturer and style/model fuel line was used for the supply and return lines in a 1986 US car? Was it the cloth braided fuel line like this that was typical in other parts of the fuel system in the 1986?
https://www.belmetric.com/braided-me...mm-p-8316.html
(I'm not familiar with Cohline, but I don't buy fuel hose every day).
I understand that the supply side needs to be "fuel injection" pressure rated (but that the return doesn't necessarily). Got it. However, were the supply and return hoses the same on a stock car?
I run only ethanol-free gas in the car, so I'm not necessarily concerned with finding a modern type of hose that's protected from ethanol, etc. Would be a bonus, but not as much of a base requirement as trying to stay with original.
Answers and thought are appreciated.
Lew
Lew
1986 Spider Quadrifoglio
Lew is offline
post #2 of 8 (permalink) Old 04-02-2019, 11:57 PM
spiderserie4's Avatar
this might help
https://www.alfabb.com/bb/forums/865737-post6.html
spiderserie4 is offline
post #3 of 8 (permalink) Old 04-03-2019, 09:19 AM Thread Starter
Lew
Member
Originally Posted by spiderserie4 View Post
That's helpful! I was headed down the wrong path with 7.5mm ID. Thanks!
Lew
Lew is offline
post #4 of 8 (permalink) Old 04-03-2019, 01:53 PM
From what I've seen, the 7.5 hose is pretty much unobtanium!!! I suspect 1.5 feet is enough to do the injectors. Where did you get yours? Thanks Paul
azALFAowl is offline
post #5 of 8 (permalink) Old 04-03-2019, 01:56 PM Thread Starter
Lew
Member
Centerline sells the 7.5 mm in a pre-cut injector kit.
https://centerlinealfa.com/catalog/f...tor-repair-kit
Lew
Lew is offline
post #6 of 8 (permalink) Old 04-03-2019, 02:23 PM
Gubi's Avatar
I would suggest using fuel injector rated hose on both the supply and return lines. It's not that much hose overall since you're just connecting the metal sections.
Unless you're wedded to the idea of the original hose for some reason, just pick up some off-the-shelf fuel hose: the fabric hoses make it hard to evaluate the condition of the rubber and I don't like them for that reason. 8mm is pretty much the same as 5/16" (7.94mm) and I think the FI hose I bought at the local auto parts store was labeled as both.
Any modern hose should be rated for ethanol, but you should ensure you're using ethanol-resistant hose regardless of what you're putting in the tank.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is offline
post #7 of 8 (permalink) Old 04-03-2019, 03:10 PM Thread Starter
Lew
Member
Thanks Gubi. This makes sense. Will probably go this route. I was just trying to keep things as original as possible, but you're right about the fabric obscuring deterioration (dangerously, as many of our members have recounted).
Lew
Lew is offline
post #8 of 8 (permalink) Old 04-03-2019, 08:03 PM
Jim G's Avatar
They originally came with the rubber high pressure hose on the supply side which would be the fuel end closest to the firewall. the return hose is standard cloth braided fuel line. As it is just a return line that is not high pressure.
Jim G is offline
Similar Threads
Available Wiring Diagrams papajam Electrical, Chassis & Lighting 1722 06-01-2019 05:35 AM
164 Firewall Fuel Hose Replacement Roadtrip 164 & 168 (1991-1995) 7 10-10-2015 09:12 AM
pininfarina scrpit etc. placement konati Spider - 105 & 115 Series (1966-1994) 14 08-11-2015 08:25 AM
Spica to Weber Conversion - Fuel Supply Luscombe1940 Carburetors, Fuel Injection & Air Intake 43 01-03-2013 10:44 AM
1978 Spider Spica/fuel supply/Vapor lock Issues resolved firstalfa Carburetors, Fuel Injection & Air Intake 3 07-19-2005 03:39 PM
