Squadra Chips???? - Alfa Romeo Bulletin Board & Forums
 1Likes
post #1 of 20 (permalink) Old 04-02-2019, 08:28 AM Thread Starter
Jack Straw's Avatar
Squadra Chips????
I was reading an older post on the Squadra chip for S4 Spiders and am curious as to whether they are currently available. A cursory online search turned up nothing in English. Is there a dealer in the U.S. or U.K?
Bill
1991 S4 Spider "Gabriela", 2017 VW Golf R, 2018 VW GTI,
Previous obsessions; 2006 Mustang GT, 2006 BMW Z4M, 5 other Bimmers, Capri V6, Renault 5, Lotus Cortina, Sunbeam Alpine, Ducati Diana Mk 3, Norton Commando
Jack Straw is offline
post #2 of 20 (permalink) Old 04-02-2019, 09:13 AM
Gubi's Avatar
I'd just email them directly: they speak English very well. [email protected]
The S4 chip works well but you really need 93 octane gas as it mostly works via more aggressive timing advance. I tried one in my car but it pinged too badly on California 91 octane to use.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #3 of 20 (permalink) Old 04-02-2019, 09:14 AM
pantera928's Avatar
pantera928 is offline
post #4 of 20 (permalink) Old 04-02-2019, 10:08 AM Thread Starter
Jack Straw's Avatar
Gubi,
I noted in an older post that you had a problem with pinging on CA 91 octane. We're limited to 91 here in Arizona for some reason and I suspect I'd have the same problem. I'll continue to investigate the chip but I suspect I'll pass due to the octane issue. Many years ago I had a hot-rodded Renault and I resorted to buying little bottles of 104 octane boost to kill the detonation problem. That was tedious and expensive.
Thanks for the replies gentlemen.
Bill
post #5 of 20 (permalink) Old 04-02-2019, 10:14 AM
spiderserie4's Avatar
I have one fitted and the difference is very subtle, so really don't expect to suddenly have a racing car
you get a bit more pull without changing down a gear, and the reason I got it was I was fed up changing down to first gear trying to get up some steep swiss mountain roads, following my brother in his 59 vette!
The performance is very smooth (as is a healthy normal S4, tbh) with perhaps a bit more pull.
The one difference you feel is in higher revs, so overtaking on the motorway, or really pushing it on long twisting roads....but we are speaking above 4000/4500 rpm
Idling, starting, and generally poodling along thru town traffic is unchanged, which is also good.
I do not get worse mileage per gallon, which is good, as the super plus fuel (100+) here costs 18 eurocents a litre more! (basically 76 UScents per US gallon more)
The first chip they sent me didn't work!.... but they were very quick to send a replacement as when they checked the one I sent back it was indeed not correctly programmed.
Fitting was easy once they told me which way up it was supposed to go
alfaloco likes this.
spiderserie4 is offline
post #6 of 20 (permalink) Old 04-02-2019, 02:10 PM
SkiBum's Avatar
This thread kinda touches base on something I have been wondering. I have sent ECUs back East a couple of times to have them "reflashed" for performance and if you have modifications he will consider this on the map. I realize that these all ran off of a Power Commander module but I would think someone would have delved into this procedure for the injected years.... anyone heard of anyone doing this?
SkiBum is offline
post #7 of 20 (permalink) Old 04-02-2019, 02:16 PM
Gubi's Avatar
The chip with the fuel/timing maps is just an EPROM. You can pull it, read it with an EPROM reader, and write whatever map you want: I think there's software out there that decodes the Bosch maps. I've actually read the EPROM with a reader I have, and I have the stock maps sitting around somewhere.
That said, Squadra's already done the work of coming up with a good tuned map. I'd think the smart move would just be to buy their chip rather than just DIY it, especially considering every DIY tuning cycle would require removing the chip from the ECU.
1974 GTV
1991 Spider
Gubi is online now
post #8 of 20 (permalink) Old 04-02-2019, 02:43 PM
SkiBum's Avatar
Are the chips just for the S4's or so they work with the earlier injection models?
SkiBum is offline
post #9 of 20 (permalink) Old 04-02-2019, 02:46 PM
SkiBum's Avatar
Oh, I see you brought up Bosch so I guess you can write a map for an S3! I certainly would like to learn about this further...
SkiBum is offline
post #10 of 20 (permalink) Old 04-02-2019, 02:52 PM
Gubi's Avatar
No. The S4 uses Bosch Motronic, which has a digital EPROM map as described above. The S3 uses L-Jetronic which is analog. There are ways to modify the S3 ECU but they involve changing resistors, etc, and are by no means simple.
Tom Zat used to sell the "Pandora's Box," for example, which modified the V6 L-Jetronic fuel and ignition ECUs. I don't recall anyone doing that for the Spider.
1974 GTV
1991 Spider
Gubi is online now
post #11 of 20 (permalink) Old 04-02-2019, 03:00 PM
SkiBum's Avatar
Well, there goes that idea! 😜 Thanks for the knowledge though!
SkiBum is offline
post #12 of 20 (permalink) Old 04-04-2019, 04:16 PM
I got a second hand chip for my S4 originally from Alfa Ricambi. I don't know if it is same as the Squadra chip but it is supposed to increase the redline (engine cutoff) by about 500 RPM and as I recall adjusts the spark curve. The difference is noticeable if not earth shattering. The idle is smoother and the engine seems to have a little more bite. I have not noticed any pinging. The increased rev limiter is fun.
Paulinct is offline
post #13 of 20 (permalink) Old 04-05-2019, 06:43 AM
alfaloco's Avatar
I also have the old Ricambi chip in my S4, and I agree with your comments. Comparing the Ricambi and Squadra chip via seat-of-the-pants, there is really no detectable difference IMO. Both will improve your S4 Spider. But the Squadra chip is still available, unlike the Ricambi.
The changeout of the chips in the Motronic ECU was simple, you just want to be grounded, and clean, and be patient with the tweezers.
alfaloco
Lexington, KY USA
alfaloco is offline
post #14 of 20 (permalink) Old 04-05-2019, 07:17 AM
Mine triggers the cbeck engine light so when we had emissions testing in CT I had to swap the chip in and out for the annual test
Paulinct is offline
post #15 of 20 (permalink) Old 04-05-2019, 07:24 AM
Gubi's Avatar
That was apparently an issue with the Ricambi chips. The Squadra chip doesn't do that as far as I know.
1974 GTV
1991 Spider
Gubi is online now
Similar Threads
Introduction To Squadra GTV smestas Squadra GTV - GTV Owners Club 32 02-21-2019 06:54 AM
To squadra, or not to squadra? That is the question... orfedj 164 & 168 (1991-1995) 15 04-26-2012 06:55 AM
Any experience with Squadra chips for S4 Spider? Alfafalfa Spider - 105 & 115 Series (1966-1994) 7 03-09-2006 06:20 PM
Squadra chip conedriver Spider - 105 & 115 Series (1966-1994) 1 01-28-2004 07:13 PM
1991-1994 Performance chips, Squadra and ? luvmy115 Alfa Romeo Topics Not Covered Elsewhere 0 01-20-2004 07:49 PM
