Door handle parts (spring) - Alfa Romeo Bulletin Board & Forums
 5Likes
post #1 of 20 (permalink) Old 03-20-2019, 05:55 PM Thread Starter
abeasley's Avatar
I took my door handle apart to fix the locking mechanism and found the spring is broken. I've looked online to try to find a replacement spring but haven't had any luck. Does anyone know if this spring is available anywhere?
Also, as you can probably tell from the picture, the chrome is pretty much gone so at some point I'll either need to get these re-chromed or buy new door handles... which brings up the next question. Do the new door handles and/or lock sets contain the spring (I thought I saw where someone said it didn't).
Thanks!
Adam -- 1988 Alfa Romeo Spider Graduate
abeasley is offline
post #2 of 20 (permalink) Old 03-20-2019, 08:10 PM
sloboy89's Avatar
The new door handles from Classic Alfa do not have the locking mechanism, the cylinder, or the spring.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is online now
post #3 of 20 (permalink) Old 03-20-2019, 10:29 PM
Norseman50's Avatar
Have you asked a locksmith?
Edward
'88 Quad - "Claudia"
Norseman50 is offline
post #4 of 20 (permalink) Old 03-21-2019, 02:26 AM
spiderserie4's Avatar
uhmm....is this not the spring in question?
a DIY solution was outlined here, if it is:
https://www.alfabb.com/bb/forums/ele...le-spring.html
spiderserie4 is online now
post #5 of 20 (permalink) Old 03-21-2019, 04:14 AM
sloboy89's Avatar
He mentioned the lock mechanism, so I interpreted as the circular spring that returns the lock cylinder to the upright position (shown in bottom of the OP's photo).
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
post #6 of 20 (permalink) Old 03-21-2019, 04:19 AM
aha..
Ok, I get it now.....this little spring?
post #7 of 20 (permalink) Old 03-21-2019, 05:05 AM
divotandtralee's Avatar
Think "coil return spring" first... Ace or auto parts store. Try to find a coil return spring as a donor with a close wire diameter and inside diameter. I found a 29/32" size that eyeballs from the photo as close.. It might be somewhere between 5/8 -- 3/4" ... It doesn't have to be dead nuts metric and a perfect clone.. Then ogle the number of windings on your broken one and where the ears are supposed to be and cut out a section of the donor allowing to bend the ears in proper orientation with needle nose pliers. I can't see from the photo how the tumber acts against the tension of the spring but this should keep you busy.. Attached is an example of what path I would take. https://shop.advanceautoparts.com/p/...9207/9110109-p
divotandtralee is online now
post #8 of 20 (permalink) Old 03-21-2019, 05:08 AM
sloboy89's Avatar
aha..
Yes. It has two tangs that straddle the little post as shown in your photo. The OP's spring only has one of the tangs.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
post #9 of 20 (permalink) Old 03-21-2019, 05:22 AM Thread Starter
abeasley's Avatar
Yes, it's the little round spring with the two tangs. I believe it's called a barrel key lock cylinder spring? The closest I could find was on ebay from a seller in Turkey... but it's a bit pricey for a test fit. My door handle works, only I can't lock it from the outside, just from the inside.
https://www.ebay.com/itm/Ignition-Sw...o/223438860500
abeasley is offline
post #10 of 20 (permalink) Old 03-21-2019, 05:29 AM
Philosophically, Spider door locks are like screen doors on a submarine.
post #11 of 20 (permalink) Old 03-21-2019, 05:34 AM Thread Starter
abeasley's Avatar
LOL, true. Just a pocket knife and you are through the top and opening the door.
abeasley is offline
post #12 of 20 (permalink) Old 03-21-2019, 05:53 AM
Yes.. but we do whatever necessary to scratch the itch.. I'm just as bad. Gotta fix it even if ya don't use it! Gotta be right. It comes from many years of looking at other owners's cars and having him say.. "That doesn't work.. but I never needed it." I think the term "no excuses" is hollow. I haven't found many used cars that have "no excuses".... Get that spring fixed.. onward and upward.
abeasley likes this.
post #13 of 20 (permalink) Old 03-21-2019, 05:56 AM
Raimondo's Avatar
Uncle, that would certainly affirm the Italian expression, "L'opportunità fa il ladro"; "Opportunity makes the thief".
Ray
Oklahoma SNO Alfa Chapter Director
'64/66 Giulia Spider finally back in the garage and painted
'75 Olandase Blu Alfetta Sedan 2.0 & '88 Red Milano Verde; both long gone and dearly missed
Raimondo is offline
post #14 of 20 (permalink) Old 03-21-2019, 06:44 AM
goats's Avatar
Abeasley where are you located? If USA I might have one of those springs hanging around I can drop in the mail to you. I’ll check tonight or tomorrow if u confirm your location
goats is offline
post #15 of 20 (permalink) Old 03-21-2019, 07:02 AM Thread Starter
abeasley's Avatar
I'm in Anderson, SC. I think we are still a part of the Union, hard to tell from watching the news.
If you have an extra I'd appreciate it!
Thanks!
velocissimo likes this.
abeasley is offline
Similar Threads
For Sale: Spring cleaning of GTV 2000 parts esc2064 Alfa Romeo Parts For Sale & Wanted 0 02-12-2017 10:23 AM
Installing Front Spring (compression) rogerspeed Picture Room 10 03-21-2016 04:42 AM
For Sale: Used Alfa parts, rebuilt engines, etc. MANY AVAILABLE lalfaitalia Alfa Romeo Parts For Sale & Wanted 85 11-29-2012 09:37 AM
Alfa Romeo Parts Garage Sale - PA – Mostly Giulietta and GTV bobbrady Alfa Romeo Parts For Sale & Wanted 2 08-17-2012 10:05 AM
Over a TON of engine parts 2.0/2.5/3.0 24 Valve MarcusHMM Alfa Romeo Parts For Sale & Wanted 16 12-19-2007 07:48 PM
