Another dead fuel pump! - Page 2 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #16 of 23 (permalink) Old 03-18-2019, 11:14 AM
spiderserie4's Avatar
stepped hose:
here (USA)
https://centerlinealfa.com/catalog/i...fuel-pump-hose
or here (UK), about 15$
https://www.alfaholics.com/parts/105...e-fuel-sender/
what year spider? has it the monopod instruments?
and
are all the other gauges working, as well as the illumination lights?
spiderserie4 is offline
post #17 of 23 (permalink) Old 03-18-2019, 01:06 PM Thread Starter
Car is '83 spider.. Pods.
Spike is offline
post #18 of 23 (permalink) Old 03-18-2019, 01:10 PM Thread Starter
All gauges working except fuel gauge. Will check wiring tonight, but doubt that any connections are crossed. Like I stated earlier After I did work gauge was working, then a few days later went back to start car and new inline Bosch pump was dead and then also noticed fuel gauge not working.
Spike is offline
post #19 of 23 (permalink) Old 03-18-2019, 01:54 PM
pantera928's Avatar
It should not get sucked into the pump. The sock will take care of that. The step hose is available from several vendors. Very cheap. Definitely worth changing. That may solve everything.
Make sure the sock is oriented properly as spiderserie mentioned and also the fuel tank level sender.
pantera928 is offline
post #20 of 23 (permalink) Old 03-18-2019, 02:03 PM Thread Starter
Yes, I realize the in tank pump would not suck the rubber reducer, I meant the in-line pump may have. The new Bosch in-line fuel pump I also installed died after about ten minutes. Not sure what caused that?
Spike is offline
post #21 of 23 (permalink) Old 03-18-2019, 02:07 PM Thread Starter
Center line wants $28 for a rubber reducer... can I get his for less elsewhere ?
Spike is offline
post #22 of 23 (permalink) Old 03-18-2019, 05:11 PM
radamm's Avatar
Originally Posted by Spike View Post
Regarding the small step hose.. it did need changing but did no come with new pump. It is loose so I zapped strapped, but the rubber is degraded. Where can I get a new one?
Appreciate everyone's input!
Here you go:
__________
Rick
[RIGHT] [I] MEMBRO LATO OSCURO[/I][/RIGHT]
69 850 Spider[I] [COLOR="Silver"](A fond college days' memory)[/COLOR][/I]
81 Spider Veloce
Downstate Illinois SNO Director
radamm is offline
post #23 of 23 (permalink) Old 03-22-2019, 06:33 AM
rtmcintyre3's Avatar
I have a 1982 Alfa Spider Veloce, which suffer fuel pump failure back in the 90s when I lived in Ohio. A friend who was a Maserati master mechanic and was connected to Bosch factory guy, discovered after three fuel pumps, drained and cleaned tank, new fuel filter (and one added pre and post pump) that the issue stemmed from additives in the winter-formulated fuel (petroleum naphtha). The naphtha was eating the seals, as the pump uses the fuel as the lubricate. Procured a Bosch pump with asbestos seals, and the car has been running smoothly for over 25 years, still purring along, regardless of the fuel formulation. Good luck.
rtmcintyre3 is offline
Similar Threads
In-tank fuel pump - fuel level sending unit question..... Wahootie Spider - 105 & 115 Series (1966-1994) 5 08-02-2015 12:39 PM
Fuel Pump Dead in 69 Spider wilkie Spider - 105 & 115 Series (1966-1994) 12 08-30-2010 05:22 PM
4th of July weekend + Tennessee + Scenic Drive + Alfa Spider = Fuel Pump Issues... AlfaRomeo1750 Spider - 105 & 115 Series (1966-1994) 9 07-05-2010 11:47 AM
Wanted: Alfetta Fuel Pump, dead or alive, pref dead tomhenneka Alfa Romeo Parts For Sale & Wanted 3 05-16-2008 10:16 AM
Fuel pump funeral? Donny Spider - 105 & 115 Series (1966-1994) 27 06-20-2006 07:47 AM
