Fuel hose leak- help! - Page 2 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #16 of 27 (permalink) Old 03-12-2019, 05:49 PM
Not to ask anything too dumb, but where did you get Lodge plugs? Last time a found a set of 4 the guy wanted $40 (Canadian) each. I didn't buy.
Kim Boydell is offline
post #17 of 27 (permalink) Old 03-12-2019, 07:10 PM Thread Starter
Alfa parts
Berkeley
*+1 (510) 525-9435‬
tremere613 is offline
post #18 of 27 (permalink) Old 03-12-2019, 07:56 PM Thread Starter
It wasn’t $40 each, but still expensive at around $18 USD each. I figure I don’t skimp on the engine, no regrets so far! The design was very different from the standard plugs I removed from the car..
post #19 of 27 (permalink) Old 03-13-2019, 06:41 AM
Thanks for responding. $18 US, about $24 Canadian, is a lot cheaper than $40 Canadian but still far more expensive than the alternatives. When it is time to replace my plugs I will look at the Bosch with 3 electrodes.
post #20 of 27 (permalink) Old 03-13-2019, 01:14 PM
jclark's Avatar
Why not look at the Bosch with 4?
jeff
1982 Spider Veloce
1999 BMW R1100S
jclark is offline
post #21 of 27 (permalink) Old 03-13-2019, 01:45 PM
spiderserie4's Avatar
I would just go with NGK B7ES like most classic alfa drivers do
I used Lodge religiously in every alfa since the 70's, even when they started getting expensive after the company (at the end taken over by 'spica') finally stopped production....but nowadays the market is flooded with fake Lodge.
(you get to know these when the green 'lodge' script wipes off with your fingers after a few heat cycles!)
spiderserie4 is online now
post #22 of 27 (permalink) Old 03-13-2019, 02:13 PM
jclark's Avatar
Ducking out on the 3 xtra grounds, eh? And only $5.25 each, from NAPA.
jeff
1982 Spider Veloce
1999 BMW R1100S
jclark is offline
post #23 of 27 (permalink) Old 03-13-2019, 04:32 PM
msiert's Avatar
Those would be nice, wouldn't have to index them.
Darkside Member
msiert is offline
post #24 of 27 (permalink) Old 03-14-2019, 05:50 AM
Not to hijack a thread on leaking fuel hoses, and if this is going too far down the spark plug hole, let me know, I though the Bosch had 3 electrodes, but if it is four, that is fine with me too, it has been over a decade since I used the Bosche so my memory could be faulty. NGK B7ES are also a possibility as is the Beru.
post #25 of 27 (permalink) Old 03-16-2019, 11:08 AM Thread Starter
What’s the part number on the Bosch plugs?
post #26 of 27 (permalink) Old 03-16-2019, 01:48 PM
jclark's Avatar
I have been using the Platinum 4477 +4 since ~ 1987. IIRC...(long time)
jeff
1982 Spider Veloce
1999 BMW R1100S
jclark is offline
post #27 of 27 (permalink) Old 03-17-2019, 09:09 AM
It has been a long time since I used the Bosch plug, so I would hate to guess which plug it was without talking to my local specialty shop. As J Clark mentioned the 4477 +4 and it is listed on lots of search engines as is the the WR78, but I am neither recommending or not recommending these.
Similar Threads
Correct in tank fuel pump polarity and stepped fuel hose skytop Spider - 105 & 115 Series (1966-1994) 10 07-19-2015 01:44 PM
Fuel Hose Advice NEEDED ASAP. AlfaRomeo1750 Spider - 105 & 115 Series (1966-1994) 8 10-24-2011 07:37 PM
Question in regards to a fuel return line leak riveroflava Spider - 105 & 115 Series (1966-1994) 2 07-08-2011 05:54 PM
Fuel Injection Hose Mac D 164 & 168 (1991-1995) 2 08-17-2009 05:33 PM
Fuel Pump Function: one man's opinion MrT 164 & 168 (1991-1995) 8 11-17-2008 08:37 PM
