opinion: No start; 1750 Spider - Page 2 - Alfa Romeo Bulletin Board & Forums
 2Likes
post #16 of 27 (permalink) Old 02-07-2019, 06:25 AM
Be careful about swapping coils. The original Marelli with ballast resistor is hard to beat for a points system. If you still have the ballast resistor then your coil should be about 1.5 ohms. If you have removed the resistor then the coil should be about 3 ohms. However the 3 ohm coil )Bosch Blue or similar) will make weaker sparks during starting and at higher rpm than a 1.5 ohm coil + ballast resistor. If you connect a 1.5 ohm or less coil without a ballast resistor you will quickly bugger up the points and possibly overheat the coil.
2011 Jaguar XKR
alfaparticle is online now
post #17 of 27 (permalink) Old 02-07-2019, 06:56 AM
Alfajay's Avatar
Originally Posted by AlfaRomeo1750 View Post
Engine spins very fast while cranking
Yes, I know the old rule about spark/air/fuel.
The actual rule is spark/fuel/compression. If your engine is spinning very fast, it may be because your compression is low. Have you tested it? Low compression + weak spark + stale fuel = no start.
Alfajay is online now
post #18 of 27 (permalink) Old 02-07-2019, 07:05 AM Thread Starter
AlfaRomeo1750's Avatar
Yes, engine has compression. Even pressure across all 4 cyl. Motor has been rebuilt. I know what youre saying... but I mean it spins fast with the starter as it should... to indicate proper voltage vs a poorly charged system. Not that God awful high speed spin that occurs when you bend valves... ask me how I know that noise.... or rather dont.... lol.
AlfaRomeo1750 is offline
post #19 of 27 (permalink) Old 02-07-2019, 04:03 PM Thread Starter
Cylinder compression test. Pretty much same result across the board.
post #20 of 27 (permalink) Old 02-07-2019, 04:17 PM Thread Starter
Well.... Its running. Sort of. Cyl #3 is weak/misfiring.
I took the plugs out, cleaned each one with solvent and a wire brush. Pulled some fuel out of my gas can with a cattle syringe and injected a small amount of fuel into each cylinder as I hand tightened back the spark plugs....
Got in... a couple of cranks.... and vroom... sort of. A lot of misfiring until the car came up to temp. Then the idle evened out.
I took it for a short drive hence the photo.... but as It went, it started missing on a single cylinder. So I turned around, drove home... and once I had the car under roof again, I started pulling plug wires with it running.
When I got to cyl#3 and pulled the lead off... no change in the idle.
Each other cylinder produced an appreciable change in the idle when the plug wire was removed....
So, either I have a dead plug.... or... bad wires. Because I've confirmed yesterday all cylinders were getting fuel.... and all have compression.
At least now it starts. Btw, removing the wire from the CSS didnt change anything... not judging the advice... just reporting no change.
Any other thoughts out there for tuning or diagnosis of cyl#3 issue?
goats likes this.
post #21 of 27 (permalink) Old 02-07-2019, 05:06 PM
Farace's Avatar
Had the same happen once. Swap the wire to another cylinder and see if the problem follows the wire or stays with the cylinder. I have had a single wire go bad before.
[FONT="Century Gothic"][B]Bob Farace[/B]
[COLOR="DarkGreen"]1971 Alfa Romeo 1750 Spider Veloce[/COLOR]
[I]Director, Connecticut branch, Scuderia Non Originale[/I][/FONT]
Farace is offline
post #22 of 27 (permalink) Old 02-07-2019, 06:56 PM Thread Starter
A bit off topic, but rather than start a new thread for a quick question... Where does one get a set of 4 new/rebuilt brake calipers? Vick Auto and Centerline International are both “out of stock”.
I know they sell rebuild kits, but my time is limited, no shops in my area want to touch brakes on a 48 year old car so Ive been looking for plug/play options. Ive done brake jobs in the past, but I want this job to be an afternoon adventure, not a weekend killer.
Im asking because the brake pedal felt a bit spongy tonight when I drove it. I have a new master cyl in a box of parts I keep on hand, so that will be going on soon. But I kinda like the idea with all new corners too...
post #23 of 27 (permalink) Old 02-07-2019, 08:29 PM
For brakes Miscellaneous Brake Components
Call (not email) Andy to verify stock.
2011 Jaguar XKR
post #24 of 27 (permalink) Old 02-13-2019, 06:28 AM
Lokki's Avatar
Rock Auto has them. I have a friend who bought the Centrics and is happy with them
https://www.rockauto.com/en/catalog/...b,caliper,1704
71 Spider
Lokki is offline
post #25 of 27 (permalink) Old 02-13-2019, 07:41 AM
I would start with a good flush and replacing the rubber lines. I was having weird brake issues on my Berlina and bought rebuild kits but then noticed I had never replaced the brake lines. Once I swapped them out the brakes feel great again. The old lines were nearly swelled shut.
I'm pretty sure whatever rebuilt calipers you find will be cheap aftermarket versions. If you do go that route save your money nice Ate calipers and rebuild them later.
Sent from my ONEPLUS A3000 using Tapatalk
Ian Lomax - Current: 1973 Berlina, 1987 Milano Platinum "racecar"
Past: 71, 74 Spiders, 2x 74 Berlina, 74 GTV, 76 Alfetta GT, 88 Milano 3.0, 164LS
archeologist is offline
post #26 of 27 (permalink) Old 02-13-2019, 08:53 AM
The link that I posted is for rebuilt Ate calipers. I too would always use rebuilt Ate over aftermarket parts.
I think that I have a good pair of Ate front calipers that I removed a couple of years ago when I switched to aluminum Brembo's. PM me if you want me to find them.
2011 Jaguar XKR
post #27 of 27 (permalink) Old 02-14-2019, 04:17 PM
Sometimes it is just the weird stuff. I had a similar problem with my Spica equipped 1973 2 liter. I had it running nicely until one day, no start. Just as you did I started tracing the electrical system, fuel system, and so on. I spent days checking and measuring and doing it again. I started with the easy stuff and then progressed onto the more difficult and unlikely. Then I find myself staring at the engine. My eyes work their way from back to front until I am looking at the top on the injection pump belt. I reach down, touch the belt with my finger; and it falls off in pieces.
Chipps is offline
Similar Threads
Available Wiring Diagrams papajam Electrical, Chassis & Lighting 1722 06-01-2019 05:35 AM
For Sale: Alfa Romeo Auction in New Jersey Falfa116 Alfa Romeo Cars For Sale & Wanted 72 02-02-2017 10:34 AM
For Sale: 1969 Spider 1750 tirefriar Alfa Romeo Cars For Sale & Wanted 51 01-10-2015 04:20 PM
Planning the Monterey Week mbaum Car Events 53 08-13-2006 09:08 PM
spider did not start . . . mdc Spider - 105 & 115 Series (1966-1994) 11 05-17-2006 06:19 PM
