Spider VVT Solenoid - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By spiderserie4
post #1 of 12 (permalink) Old 01-09-2019, 09:35 AM Thread Starter
Spider VVT Solenoid
I tested my VVT solenoid with 12volt and nothing happens. The plunger has been cleaned. Is there anyway to get into it and fix the electronics for does anyone have one available?
Robby
rozment is offline
post #2 of 12 (permalink) Old 01-09-2019, 09:56 AM
sloboy89's Avatar
Robby
Where did you apply the 12v? If you put +12v on one of the two male spade terminals on the end of the solenoid (and the other one to ground), then the solenoid itself is likely bad if it did not extend. I don't think that the solenoid itself is repairable, but used ones are available.
If you were applying 12v somewhere else, we need to understand what you did.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is offline
post #3 of 12 (permalink) Old 01-09-2019, 10:41 AM
spiderserie4's Avatar
what year spider do you have? is it S3 with the white electronics gizmo on the end, or just a rubber boot with 2 spade connectors (S4)?
you say you have cleaned the plunger, do you mean the little plunger that goes thru the cam cover, or, do you mean you have opened the solenoid and cleaned that big plunger?
photo (thanks to mcola/Mike!) shows big plunger inside the solenoid itself.
If that moves freely and the solenoid electronics/coil itself is broken, there is no fix.
spiderserie4 is online now
post #4 of 12 (permalink) Old 01-09-2019, 03:00 PM
Richard Jemison
Alfar7's Avatar
VVT solenoid assembly
I have a good one from a low mileage `91 motronic. Send me a pm if interested. In fact I am removing the entire Motronic package if anyone would be interested in it.
Richard Jemison
RJR Racing
Same with stupid"
Alfar7 is offline
post #5 of 12 (permalink) Old 01-10-2019, 05:51 AM Thread Starter
It's a 1988. I took the plastic end off and cleaned the big plunger inside. I applied + to one of the male spades and - to the other male spade. Also, I applied the - to the body of the solenoid and the + to each of the males spades separately. Not even a spark.
rozment is offline
post #6 of 12 (permalink) Old 01-10-2019, 06:32 AM
then it is kaputt. I'm afraid.
In your hands you'd feel the solenoid move and hear it click.
You could, I suppose, tap the unit with a hammer...see if you get anything out of it that way....
Of course you also do not know for sure if the big white plastic endpiece with the transistorized internals is working. It could also be bad - a double failure.
That you will only know if you attach a good working VVT solenoid to it, and crank the throttle thru about 55
post #7 of 12 (permalink) Old 01-10-2019, 07:23 AM
sloboy89's Avatar
@spiderserie4 makes a good point about the electronics in the white plastic endpiece -- these are subject to failure and are not available new. You can do an electrical test on that component to see if it is working. With the key "on" (engine off), open the throttle all the way using the throttle lever on the intake manifold. With a voltmeter, measure the voltage across the two female connectors inside the white plastic endpiece. If the electronics are good, you will get 12V across those terminals. (There is also an in-line fuse located near the coolant overflow bottle inside the right fender, so if the electrical test fails, a bad fuse might be the problem).
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is offline
post #8 of 12 (permalink) Old 01-10-2019, 09:14 AM
as a side note, the solenoid activates when 12v is applied (ie throttle is open), the small plunger sticks out. But is it supposed to go back in when 12v is no longer applied?
89 spider grad
76 alfetta GT long gone
viken69 is offline
post #9 of 12 (permalink) Old 01-10-2019, 09:24 AM
sloboy89's Avatar
Yes. If it doesn't, it is likely just gummed up with grease & grime. Cleaning should correct it.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is offline
post #10 of 12 (permalink) Old 01-11-2019, 10:14 PM
I have a 1986 Spider. With the key on I only see 8.6 volts. Does that seem normal or should I see a full 12 ?
pkflynn4427 is offline
post #11 of 12 (permalink) Old 01-12-2019, 03:51 AM
sounds correct.
quote from a 10 year old VVT thread:
"BTW, papajam discovered that the harness puts around 8 volts to the solinoid, not 12 like one would expect.....
Vintre likes this.
post #12 of 12 (permalink) Old 01-14-2019, 07:06 AM Thread Starter
Hey Alfa7,
I'm new here and apparently have posted enough to PM. Maybe you can PM me.
Robby
rozment is offline
