Duetto engine removal - Page 13 - Alfa Romeo Bulletin Board & Forums
 10Likes
post #181 of 197 (permalink) Old 06-12-2019, 05:49 PM
Jim G's Avatar
You need to do the roll pin update. If not you will start to get oil seepage at those spots in a couple of years.
Jim G is offline
post #182 of 197 (permalink) Old 06-12-2019, 05:53 PM
Jim G's Avatar
Originally Posted by markgberry View Post
Thanks Craig. I bought the roll pins from Jim G already. Theyíll go in next. Iím just gathering all the info I may need before crushing the new gasket.
Regards
Mark
I forgot it was you that I sold them to.
Jim G is offline
post #183 of 197 (permalink) Old 06-12-2019, 05:53 PM Thread Starter
Yep roll pins go in next Jim, thanks! Just wondering if I need to put sealant at the rear of the head gasket where the middle oil drain passage in the block is covered by the head gasket.
Mark
markgberry is offline
post #184 of 197 (permalink) Old 06-13-2019, 09:18 PM Thread Starter
Coming together! The head went on smoothly. I put a bead of anerobic sealant on both the head and the block between the water jacket and the oil return holes at the rear of the engine as was suggested. The timing chain took a couple tries to get right but ended up dead on in the end. Waiting on a lower oil pan gasket and a speedi sleeve for the crank pully now.
Mark
Shakey likes this.
Mark
post #185 of 197 (permalink) Old 06-13-2019, 10:07 PM
Jim G's Avatar
Don't forget the rubber square that goes in the upper pan.
Jim G is offline
post #186 of 197 (permalink) Old 06-14-2019, 05:48 AM Thread Starter
This thing? Got it in there, thanks Jim.
Jim G likes this.
Mark
post #187 of 197 (permalink) Old 06-18-2019, 10:05 AM Thread Starter
I made a blank off plate for the rear crankcase vent using the vent fitting as a template. I cut it out of 3/16Ē steel plate and sanded the mill scale off one side using 80 grit sandpaper flat on my viseís anvil.
Mark
post #188 of 197 (permalink) Old 06-18-2019, 09:50 PM Thread Starter
More progress. Speedi sleeve installed and engine compartment touched up.
Mark
post #189 of 197 (permalink) Old 06-29-2019, 09:10 PM Thread Starter
More Progress...slowly��. I had some down time waiting on a couple of gaskets so I sprayed the engine compartment again; I just didn’t like the color match after the first attempt. I received the gaskets and installed a few more bits installed today though! I should be able to marry the transmission to the engine tomorrow and maybe slide it in!
Mark
Shakey likes this.
Mark
post #190 of 197 (permalink) Old 07-03-2019, 06:28 AM Thread Starter
In! It slid right in with the back of the car jacked up to feet in the air. Great tip! Thanks to whoever mentioned that! I never noticed before how the engine doesnít sit perpendicular to the cowl.
Mark
post #191 of 197 (permalink) Old 07-03-2019, 10:42 AM
Member
otteud96's Avatar
Looks great. Good luck
otteud96 is offline
post #192 of 197 (permalink) Old 07-03-2019, 06:22 PM Thread Starter
Thanks! Is your Avatar a picture of a current project? It looks fantastic
Mark
post #193 of 197 (permalink) Old 07-03-2019, 07:30 PM
Member
otteud96's Avatar
Yes that is my current project. It was about a year and 1/2 ago whe I got it back.
otteud96 is offline
post #194 of 197 (permalink) Old 07-04-2019, 06:01 AM Thread Starter
I think iíve Read a couple of your posts regarding the restoration. Thatís going to be a beautiful car. I may like to find a body someday and do another full restoration, then swap the parts out while cleaning, painting, and plating as I go; but I donít want to take this car apart for several years and not have one to drive. Itís too much fun!
Regards
Mark
post #195 of 197 (permalink) Old 07-10-2019, 10:17 PM Thread Starter
Done! I’m breaking it in now with some 30W oil and a bottle of ZDDP additive for new engine break in. No leaks or funny noises yet.
Thanks everyone for all your help!
Best regards
Mark
IRONBLOCK and sloboy89 like this.
Mark
