Compression test results - Page 3 - Alfa Romeo Bulletin Board & Forums
 5Likes
post #31 of 35 (permalink) Old 01-07-2019, 12:29 PM Thread Starter
Crowbar44's Avatar
The leak from the sender is on the drivers side of the block, from the low oil (idiot light) sender, the sender had a single spade connector with one wire running to it....i don't think it needs a washer...
What's a helicoil?
'81 Spider (Weber's, Euro Bumpers, Custom Interior) Ivorio over Red | '54 Austin Healey 100-4, Bone Stock save for M cam, Carmine over Black.
Crowbar44 is offline
post #32 of 35 (permalink) Old 01-07-2019, 12:33 PM
spiderserie4's Avatar
What's a helicoil?
OK, understand.
No washer required on that one
A helicoil is a metal replacement insert thread, but you'll likely get away with sealant on the idiot light.
spiderserie4 is offline
post #33 of 35 (permalink) Old 01-07-2019, 12:35 PM Thread Starter
Crowbar44's Avatar
Originally Posted by spiderserie4 View Post
OK, understand.
Hopefully it will hold with sealer!
post #34 of 35 (permalink) Old 01-07-2019, 05:49 PM
samakijoe's Avatar
I don't understand the comment.
"A helicoil is a metal replacement insert thread, but you'll likely get away with sealant on the idiot light. "
The oil pressure at the sending unit is the same as at the "idiot light".
A helicoil is the way to go but you don't want to get drill or tap shaving to get into the sump. This might not be a real problem because all the oil has to go through the filer before it goes to the bearings. I have seem guys put heavy grease on the drill bit and tap. Going really slow and cleaning out the shavings and regreasing every few seconds of drill/taping will help.
N.B. I came across something the other day.
a. Do a Google on the word "idiot".
Click on the images option on the top of the page.
b. Do the same for the word "moron" for a more extensive definition .
Much fun... ......
Hey, don't blame me, I didn't do it.
(Little) Washington, NC Incorporated 1776
Red 1959 Spider Conrero Veloce 100,000 miles
sold 1966 ( I had no idea what I had there.)
Red 1967 Spider 100,000 miles sold 1974
Red 1987 Milano 100,000 miles sold 1994
Red 1969 Spider 109,000 Miles in the garage, Sold
Dark Blue 1974 Spider (arriving soon)
We need a law, one that says every male gets a 10 car garage on his 16th birthday so that when he is 60 years old he will never have to say "**** I wish I had never sold that car".
(No, I did not put those "****" up there the system did... )
Question: Do they really make Alfas in any other color then red?
Answer: Well they really do. I fell in love with a Dark Blue Spider on BAT.
I have not done over to the dark side, only the Blue side.
It took me 50 years to see the light..
samakijoe is offline
post #35 of 35 (permalink) Old 01-08-2019, 12:34 AM
I said he'll "likely" get away with sealant (as long as the threads are not so far gone, that the sender turns round 'n round by hand)
different to the oil pressure sender, the 'low oil pressure warning sender' ( that's a better name) has tapered threads, which seal as you screw the item in (hence no need for a copper seal ring), and once tightish, you stop wrenching.....sealant might allow you therefore to tighten the item sufficiently.
If it won't tighten sufficiently with sealant then yes, a heli coil would be the 'correct' repair, as I said.
At least that side of the engine is easier to get at, so a heli coil (or similar) shouldn't be a problem.
