Advice on U.S. to Euro Bumper Conversion - Page 2 - Alfa Romeo Bulletin Board & Forums
 7Likes
post #16 of 25 (permalink) Old 07-24-2019, 10:53 AM Thread Starter
Tom Frasca's Avatar
Originally Posted by Jim G View Post
Where are the drawings for the brackets on the BB?
I've been looking on and off for them again but can't find them.
I just emailed you what I found.
Tom Frasca is online now
post #17 of 25 (permalink) Old 07-25-2019, 03:45 AM Thread Starter
Tom Frasca's Avatar
@JimG here is the link, still haven't found any shop drawings with clear measurements for center grill I hate "winging it"
https://www.alfabb.com/bb/forums/spi...-question.html
post #18 of 25 (permalink) Old 07-25-2019, 08:45 AM Thread Starter
Tom Frasca's Avatar
Trial fit continued,guess there's a few more holes to weld shut....
post #19 of 25 (permalink) Old 07-26-2019, 08:04 AM Thread Starter
Tom Frasca's Avatar
DAZED AND CONFUSED ..
More of a fitment problem then I thought... anyone?
post #20 of 25 (permalink) Old 07-26-2019, 10:23 AM
conedriver's Avatar
You are almost there...
Make a upper bracket like I showed in post #12. Tilt the bottom of the grille back so the upper surface is parallel to the ground and this should bring the little pin on the bottom of the grill within an inch or so of the bottom of the scalloped contour in the lower body pan. I used a 1/8 x 1.00 Aluminum bracket to bridge this gap. A hole and small nut & bolt to fasten to the lower pan, a slight bend and a hole for the grill pin to fit into.
I don't have a picture of the bracket, but here's one of the car where you can see the grill mounting.
George Schweikle
Scuderia Non Originale
conedriver is offline
post #21 of 25 (permalink) Old 07-26-2019, 06:09 PM Thread Starter
Tom Frasca's Avatar
@conedriver
I must be having a senior moment I missed post 12 on my tablet, essentially a pivoting bracket, which gives room for adjustment, thank you George !!!!
post #22 of 25 (permalink) Old 09-25-2019, 12:40 PM Thread Starter
Tom Frasca's Avatar
Spider Restoration.... or am I to old for this nonsense..
Back at it nose looks good to me and a bit of floor pan as well..
post #23 of 25 (permalink) Old 09-27-2019, 10:39 AM
garwood1's Avatar
Send a message via Skype™ to garwood1
Regarding the amount these bumpers project forward...can I offer these pics of a UK car for comparison ?
Tom Frasca likes this.
Chris
1977 Spider 2000
garwood1 is offline
post #24 of 25 (permalink) Old 09-29-2019, 01:00 PM Thread Starter
Tom Frasca's Avatar
@garwood1
Thanks Chris!Very helpful, believe we are going in the right direction, I would love to see a photo of the bottom of the center grill to lower valance...Thanks!!
post #25 of 25 (permalink) Old 09-30-2019, 01:02 AM
garwood1's Avatar
Do these help ? It's just a metal tang that is welded to the edge of the lower lip of the opening in the valance; I fitted a rubber grommet in the end of the tang, and the pin cast into the grille frame sits in the grommet.
Chris
1977 Spider 2000
garwood1 is offline
