Water pump help - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 2 Post By papajam
  • 1 Post By Castrique
post #1 of 3 (permalink) Old 09-01-2018, 07:32 AM Thread Starter
Water pump help
Well.....bought new water pump from Centerline for my 89 Grad. Followed Water Pump for Dummies post. Got everything back together. Feeling pretty good.....then notice fan blades were catching AC pulley. Yikes.....appears new water pump about half inch shorter from pulley to end of pump. I didn't see water pump for ac on Centerline so thought I had right one. I assume I need different pump? Anyway to use spacers on pump I installed? Am I missing something?
Thank you for your help.
Castrique is offline
post #2 of 3 (permalink) Old 09-01-2018, 07:51 AM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
Check to see if the old pump has a fan spacer that is just stuck to the pump. If so, it should pop right off.
IRONBLOCK and Huzz like this.
papajam is offline
post #3 of 3 (permalink) Old 09-01-2018, 08:39 AM Thread Starter
Yes it does and it popped right off. THANK YOU!!!
ghnl likes this.
