New member - Alfa Romeo Bulletin Board & Forums
post #1 of 6 (permalink) Old 07-26-2018, 09:40 AM Thread Starter
New member
Hi. New member here. Just bought a 1987 Spider Veloce. Needs some work. Right now she bogs down and won't drive above 25mph. I'm thinking a clogged catalytic converter. I also read somewhere about the speedo causing a issue similar to this but I'm not 100% sure.
triz is offline
post #2 of 6 (permalink) Old 07-26-2018, 10:35 AM
nealric's Avatar
Given that the speedo is electronic (mechanical component is just the cable), I don't see how it would cause such a problem. The ECU doesn't see a speed input.
Clogged catalytic converter could be it, but could also be a fuel or spark issue. Couldn't hurt to swap the fuel filters (there's one under the car and one in the fuel tank) and spark plugs if the car hasn't run in a while.
nealric is offline
post #3 of 6 (permalink) Old 07-26-2018, 02:37 PM
Huzz's Avatar
If it's a clogged cat, you can try to loosen the front pipe to create an exhaust leak and then
take it for a drive and see if it improves.
I would check the air flow meter and also the air hose to the plenum for cracks.
Fresh spark plugs and fresh gas could help.
You might have to do a fuel pressure and volume test.
Huzz is offline
post #4 of 6 (permalink) Old 07-26-2018, 02:58 PM Thread Starter
That is the plan, disconnecting the cat from the header. I did see some tape around the air intake. Plan on doing some real cleaning up of the engine bay. New valve cover gasket, plugs, wires and cleaning the throttle body for starters.
triz is offline
post #5 of 6 (permalink) Old 07-26-2018, 04:01 PM
radamm's Avatar
There is an easier test for a plugged exhaust system. Connect a vacuum gauge to the intake. A plugged system will cause the vacuum to drop drastically when the engine reaches the problem rpm.
__________
Rick
MEMBRO LATO OSCURO
69 850 Spider (A fond college days' memory)
81 Spider Veloce
Downstate Illinois SNO Director
radamm is online now
post #6 of 6 (permalink) Old 07-26-2018, 05:30 PM
Huzz's Avatar
:thumbup1
Huzz is offline
