bosch fuel injector service - Alfa Romeo Bulletin Board & Forums
post #1 of 7 (permalink) Old 06-03-2018, 08:05 AM Thread Starter
mgsteve's Avatar
I would like to send my complete FI rail with the injectors to be cleaned and serviced. Anyone have any recommendations?
87 spider grad, 06 audi cab, 12 prius, 79 bellanca viking
mgsteve is offline
post #2 of 7 (permalink) Old 06-03-2018, 08:09 AM
BB Janitor
ghnl's Avatar
Greg Gordon at OK Injectors used to offer that service, but no longer.
In the past I've used Cruzin Performance with good results. https://www.cruzinperformance.com/
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 7 (permalink) Old 06-03-2018, 08:23 AM Thread Starter
mgsteve's Avatar
Eric, thanks for the reply. Do you know if they would service the whole assy?
mgsteve is offline
post #4 of 7 (permalink) Old 06-03-2018, 09:43 AM
BB Janitor
ghnl's Avatar
If you mean 'service the whole fuel rail' I don't know. But such a service is basically just changing the fuel hoses. In fact that is fairly easy - but you need the correct size fuel hose. I've bought a few feet from IAP - should be a lifetime supply. I've also seen the correct fuel hose on a VW website. It is not a size you are likely to find at a local auto parts store. 1/4" is too small and 5/16" is too big. The correct size is 7.5mm ID. Centerline sells it by the foot: https://www.centerlinealfa.com/catalog/fuel-line-75-mm
The old fuel hose should be removed by using a soldering iron (translated as a 'welder' in the shop manual) to melt through the rubber hose. A sharp knife can nick the hose barbs which may lead to a leak. Cut the ends of the new hose square, remember to put the cup shaped washer on (called a 'bushing' in the shop manual) then push the hose on. (if you forget the cup washer then you have to ruin the hose to remove it...)
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #5 of 7 (permalink) Old 06-12-2018, 03:55 PM
DaVinci's Avatar
https://witchhunter.com/ make sure you send the order form along with the injectors
DaVinci is offline
post #6 of 7 (permalink) Old 06-12-2018, 05:56 PM
I bought a new set from autozone for $30.00 each.running for several years no problem
mghamms is offline
post #7 of 7 (permalink) Old 06-13-2018, 08:15 PM
Shakey's Avatar
+1 what @ghnl said. I just did this during my engine rebuild.
-Kevin
Shakey is offline
