89 Spider oil pressure sending unit - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 04-24-2018, 11:05 AM Thread Starter
farina's Avatar
Is there a special tool to remove the oil pressure sending unit? My wrenches are too thick to fin on the flats to loosen the unit. I don't want to grind an overpriced snap-on wrench! I'm willing to sacrifice a craftsman if no special tool exists though.
87 & 89 Spider
farina is offline
post #2 of 10 (permalink) Old 04-24-2018, 11:29 AM
Try to remove by hand.
Sent from my Z957 using Tapatalk
Max Pershyn is offline
post #3 of 10 (permalink) Old 04-24-2018, 11:50 AM
You need to grind a 14 mm open end wrench. I have a collection of cheap wrenches that have been ground in different ways to get at different nuts and bolt heads. My 14 mm is a Duralast.
2011 Jaguar XKR
alfaparticle is offline
post #4 of 10 (permalink) Old 04-24-2018, 11:54 AM
I got a thin set from Amazon. Cheap and came in a roll-up pouch. I have used them many times.
Gary
87 Spider Veloce
Spring Hill, TN
As of 9/29/19: NEXT: Fix foot-well lights, gas lid.
gmilke is online now
post #5 of 10 (permalink) Old 04-24-2018, 11:56 AM
I think my first one was a bicycle wrench from REI. I used that to remove the oil sensor. Later bought a set.
Gary
87 Spider Veloce
Spring Hill, TN
post #6 of 10 (permalink) Old 04-24-2018, 12:05 PM
spiderserie4's Avatar
not all oil pressure senders are 14mm, some are 17mm
I too bought a cheapish set of extra thin open metric wrenches in a foldup pouch, very useful to have.
once you crack it open, it spins off easily by hand.
replace the copper seal, or at least re-anneal the old one.
spiderserie4 is online now
post #7 of 10 (permalink) Old 04-24-2018, 01:03 PM
Trained (ex)Professional
1953-2018 RIP
papajam's Avatar
Thin open end wrenches are also called "tappet wrenches".
papajam is offline
post #8 of 10 (permalink) Old 04-25-2018, 05:29 AM Thread Starter
farina's Avatar
There ya go I've heard of tappet wrenches! There is no way where that S.O.B is located I'm gonna spin that thing off by hand!I just purchased a quality, not Snap-On quality, tappet wrench from Amazon. Total was 18 bucks! Any excuse to buy a tool! Here is the description of the wrench. Mine is 14mm. "Stanley Proto Facom FM-31.14X15 Tappet Satin Open-End Wrench, 14 by 15mm"
87 & 89 Spider
farina is offline
post #9 of 10 (permalink) Old 04-25-2018, 07:13 AM
btw: remember to disconnect battery!
Getting that wrench in there (I go in from the front, with a long arm, under the plenum), you get very close to the starter connections
post #10 of 10 (permalink) Old 04-28-2018, 05:51 PM Thread Starter
farina's Avatar
Got the tappet wrench yesterday. It fit perfect! The battery was already out of the car. Thanks for the help? I may be changing the starter soon, it sounded terrible the last time I started it.
87 & 89 Spider
farina is offline
