Carello headlight holes - Alfa Romeo Bulletin Board & Forums
post #1 of 19 (permalink) Old 04-04-2018, 12:47 AM Thread Starter
John Kouris's Avatar
Send a message via Skype™ to John Kouris
Hi all,
Am doing a headlight cover conversion.
Can anyone tell me if I need 1 or 2 holes at the front for the headlight cover clip.
If there are any people with words of wisdom or references please let me know.
John
John Kouris is offline
post #2 of 19 (permalink) Old 04-04-2018, 01:14 AM
hi John,
should have 2. the outer one should be threaded. the inner one is for the pin on the catch/clamp to go in to. so the pin goes thru the cover and in to the hole.
if you need more detail let me know.
cheers Ian
62 LANCIA FLAMINIA GT 2500 PROJECT (now sold) 64 SPRINT GT (Gone)
68 1750 ROUND TAIL SPIDER 70 1750 GTV 62 101 GIULIA SPRINT
ITALCAROZ is offline
post #3 of 19 (permalink) Old 04-04-2018, 01:35 AM Thread Starter
Originally Posted by ITALCAROZ View Post
hi John,
cheers Ian
Thanks Ian, so what I have there is correct?
John
post #4 of 19 (permalink) Old 04-04-2018, 01:44 AM
it looks right
is the front one threaded.
cheers ian
post #5 of 19 (permalink) Old 04-04-2018, 01:55 AM Thread Starter
it looks right
cheers ian
Yes it is. Thanks Ian
post #6 of 19 (permalink) Old 04-04-2018, 04:53 AM Thread Starter
Chris from highwood alfa says one hole.
Any other takers?
post #7 of 19 (permalink) Old 04-04-2018, 06:31 AM
USTA BE AN AD-MIN
ossodiseppia's Avatar
I've seen it done both ways. You'll just need to see how that post sticks through the cover. On my spares, it sticks through a little over 1.0mm. The best thing for you to do is to check how they fit on your car.
ossodiseppia is offline
post #8 of 19 (permalink) Old 04-04-2018, 12:47 PM Thread Starter
Thanks for the info am constantly checking the fit as am going.,
post #9 of 19 (permalink) Old 04-04-2018, 01:34 PM
sprintgtc's Avatar
I've never needed to drill the second hole on my Spiders. If the locating pin is too long, you can always trim it a bit. I agree that welding a nut behind the big hole is a great idea. You can reach through the bumper on a round-tail but not on the later cars.
Mike Macaulay
Seattle
69 Spider
69 GTV
74 GTV
84 Spider Veloce
18 4C Spider
sprintgtc is offline
post #10 of 19 (permalink) Old 04-06-2018, 07:23 AM
Jim G's Avatar
I would nut weld a nut on the underside of the nose. I don't know about the repro covers out there. But the originals tended to shrink a little bit from the heat of the headlights. Which is why you see slotted holes on some of the cars.
Jim G is online now
post #11 of 19 (permalink) Old 04-06-2018, 01:13 PM Thread Starter
Thanks guys, great advice.
I will put 2 holes to be safe. Add in the welded nut and make sure second hole is not too wide or too tight. Donít want paint to crack.
Next job is changing wiper linkage, motor and scuttle panel to RHD.
post #12 of 19 (permalink) Old 04-07-2018, 01:48 AM
my car is a fairly original car and has the 2 holes. it stops the clamp rotating and then the cover coming loose. you don't want this to happen on the freeway. I Nearly lost one once that came loose and only found out when pulling in to a servo.
us cars don't have these as they didn't have the cover but a bulky ring around the headlight instead.
cheers ian
post #13 of 19 (permalink) Old 04-07-2018, 04:00 AM Thread Starter
cheers ian
Thanks Ian,
Am just having nosepiece done as previous owner had put on a series 3 nose piece and trying to rectify for nostalgia sake.
post #14 of 19 (permalink) Old 04-10-2018, 09:53 AM
I just bought the kit from Centerline. The clip pin does not reach the metal. The cover is too thick for the pin to penetrate into the metal.
snicholson is offline
post #15 of 19 (permalink) Old 04-10-2018, 10:03 AM
Hi all,
John
Hiya, I think you and i are doing the same install now. I have a 74 us spider. The passenger side lens fits fine but the drivers side sucks. Just chipped the paint to check on fill material and there is none. Oh well. I have been cutting my buckets for the headlight to respectfully fill the ugly gap that i have. A tip I cut a screw driver line in the back of the adjusting screws for adjusting the lights from the rear. Looks ok to me. Will European sealed beams fit the "hole" better? Adios
