Spider Aneurysm - Page 2 - Alfa Romeo Bulletin Board & Forums
post #16 of 20 (permalink) Old 01-29-2018, 01:51 PM
spiderserie4's Avatar
Originally Posted by David O'D View Post
According to the gauge my pump was putting out 300 psi, the PRV didn't rein it in, and the gaskets let so.
crikes!....that would certainly account for the low oil pressure light not going on
if it's being working fine in the past, its likely some sort of crud in the oil (metallic shavings) jammed the bore when the engine was turned off....probably need to investigate where such debris came from.....
spiderserie4 is offline
post #17 of 20 (permalink) Old 01-29-2018, 04:33 PM
BB Janitor
ghnl's Avatar
I don't have anything to add except I am impressed you can spell 'Aneurysm'...
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #18 of 20 (permalink) Old 01-29-2018, 04:38 PM Thread Starter
I can't, LOL, but spell check can . . . . .
David O'D is offline
post #19 of 20 (permalink) Old 01-29-2018, 06:03 PM
sloboy89's Avatar
I was more impressed with the correct use of “rein it in” back in post no. 15.
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is offline
post #20 of 20 (permalink) Old 01-30-2018, 11:25 AM
Little Italian's Avatar
Oil Pressure
I'd like to see pictures of the Oil pump after you take it out. ***** to remove the pump while the engine is in - even in a BERLINA.
......... Bud Feigel ........<Oo \*/ oO>....... Lexington, Kentucky ........
'82 RED GTV6 / 2.5 - '86 WHITE Spider Veloce 2000 - '71 GREEN GTV 1750
Little Italian is offline
