Water Pump Q - Alfa Romeo Bulletin Board & Forums
 4Likes
post #1 of 16 (permalink) Old 10-19-2017, 03:26 PM Thread Starter
adenzeno's Avatar
Water Pump Q
I have the radiator out and am replacing hoses, belts...Should there be ANY wiggle/looseness in the water pump when I move the pulley? If not, how hard is the water pump replacement? I saw the documented version from 2010...is that it for an 84 Spider? Thank you in advance
Luis
1984 Spider- Celestial blue
adenzeno is offline
post #2 of 16 (permalink) Old 10-19-2017, 04:30 PM
Tom Frasca's Avatar
Luis
very easy there should be no play(wobble) whatsoever remove it make sure the replacement has the exact same pulley...
Tom Frasca is offline
post #3 of 16 (permalink) Old 10-19-2017, 05:01 PM Thread Starter
adenzeno's Avatar
Dang it...Thanks!! Will have to study the crap outta the water pump stuff..double nutting studs etc etc...
adenzeno is offline
post #4 of 16 (permalink) Old 10-19-2017, 08:26 PM
Gordon Raymond's Avatar
The pulley CAN move in and out s l i g h t l y. This is the spring on the water stop seal allowing for normal seal carbon wear. However, NO WOBBLE, as that indicates the bearings are on the way to bearing heaven.
Gordon Raymond
Now:
Gordon Raymond is offline
post #5 of 16 (permalink) Old 10-21-2017, 09:20 AM Thread Starter
adenzeno's Avatar
I didn't detect any in out, but just a bit of up down...I also see that the fan (and the new one) has a deeper pocket and a more shallow pocket to place on the hub/pulley...of course I didn't pay attention when removing it..which end goes over the pulley, and If I recall, the metal washer/is on the outside for the bolts...Thanks again in advance for all the info..
adenzeno is offline
post #6 of 16 (permalink) Old 10-21-2017, 10:08 AM
Up/Down = BAD! MONOR in/out = probably Ok. Deep end over the snout.
adenzeno likes this.
Gordon Raymond
Now:
post #7 of 16 (permalink) Old 10-21-2017, 11:51 AM
Tom Frasca's Avatar
I don't want you to think I am being a smarta-s... use your cell phone camera as you disassemble...
post #8 of 16 (permalink) Old 10-21-2017, 12:57 PM Thread Starter
adenzeno's Avatar
Not thinking that at all..I should have taken pics, at at least taken notes (better than I did)...lessons learned...
adenzeno is offline
post #9 of 16 (permalink) Old 10-21-2017, 01:01 PM
Tom Frasca's Avatar
I do it all the time...
post #10 of 16 (permalink) Old 10-21-2017, 01:41 PM
Tom Frasca's Avatar
While you're at it have the radiator descaled and flow tested,pressure tested... the original core are so superior to recores.. any good rad shop can do it for about a $100 I repaint with epoxy some powder coat the rad shops use heat resistant paint ...but usually to glossy..
alfabeach likes this.
post #11 of 16 (permalink) Old 10-21-2017, 03:14 PM Thread Starter
adenzeno's Avatar
Picking it up Monday! It has been 28 years since I had it done...
adenzeno is offline
post #12 of 16 (permalink) Old 10-21-2017, 05:39 PM
One of the reasons water pump bearings wear out is the owner or mechanic over-tightens the belt tension. This puts high loads on the bearings in the water pump and the alternator. In earlycars it also can lead to cracks in the mainsheet pulley - along the keyway slot. That will eat up front crankshaft seals and start sharing all your oil with the rest of the engine and undercarriage.
Robert
60sRacer is offline
post #13 of 16 (permalink) Old 10-21-2017, 07:14 PM
In racing, (and street use with race engines) non-notched belts, loose enough to slip at high rpm, work best. This avoids water pump cavitation and alternator / generator blow-ups.
Water pump and generator / alternator bearings also last many many years.
Gordon Raymond
Now:
post #14 of 16 (permalink) Old 10-21-2017, 09:24 PM Thread Starter
adenzeno's Avatar
EXCELLENT info re belt tension, as I would certainly have tightened the deal out of it...
adenzeno is offline
post #15 of 16 (permalink) Old 10-22-2017, 06:53 PM
jclark's Avatar
Robert
Yup, yup yup!
jeff
1982 Spider Veloce
1999 BMW R1100S
jclark is offline
