Engine Seized? - Page 9 - Alfa Romeo Bulletin Board & Forums
 184Likes
post #121 of 572 (permalink) Old 10-16-2017, 06:53 PM Thread Starter
Shakey's Avatar
I power washed the engine and trans, then drained the engine oil. Nothing on the magnetic plug, no debris or other oddities in the oil.
I turned the engine upside-down on the stand, and removed the lower and upper oil pan. Still no culprit. Removing the oil pump had no effect.
It would seem all that's left is to isolate whether it's the crankshaft, or one (or more) of the pistons.
-Kevin
Shakey is offline
post #122 of 572 (permalink) Old 10-16-2017, 07:21 PM
John533i's Avatar
So, you still can turn the crank to rotate the lower end?
86 spider Veloce
74 TR6
John533i is offline
post #123 of 572 (permalink) Old 10-16-2017, 07:42 PM
Gubi's Avatar
Originally Posted by Shakey View Post
]It would seem all that's left is to isolate whether it's the crankshaft, or one (or more) of the pistons.
Only other thing I can think of is some sort of a failure of the intermediate timing gear that locked things up. It's rare but I've seen a couple go in posts on the BB.
http://www.alfabb.com/bb/forums/engi...-sprocket.html
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #124 of 572 (permalink) Old 10-16-2017, 08:21 PM Thread Starter
Shakey's Avatar
No, still cannot turn the crank.
-Kevin
Shakey is offline
post #125 of 572 (permalink) Old 10-16-2017, 10:13 PM
I think you're going to find that one or more of the "plugs" in the crank throws came lose and there was a localized loss of oil pressure to whatever rod or main bearing was after the missing plug. The bearing with no oil pressure got super hot and seized to the crank. That's why you can't turn the crank. Time to get a good used crank off eBay.
Hope this was helpful. Bye
Milanoguy is offline
post #126 of 572 (permalink) Old 10-16-2017, 10:27 PM
Norseman50's Avatar
Another "long shot". When I first read about this mystery, one of my initial thoughts was a stuck starter motor. I know you have pulled the starter motor now, but did you try and turn the crank by pushing the car whilst in gear AFTER the starter motor was first removed? Have you bench tested the starter, or inspected the flywheel teeth for signs of damage?
Edward
'88 Quad - "Claudia"
Norseman50 is offline
post #127 of 572 (permalink) Old 10-17-2017, 04:21 AM Thread Starter
Shakey's Avatar
I put the car up on jackstands to get the starter out, so I haven't rolled it since then. I did take the starter to the auto parts store, they put it on their tester, and it checked out fine. No damage or unusual wear on starter or flywheel teeth.
-Kevin
Shakey is offline
post #128 of 572 (permalink) Old 10-17-2017, 08:51 AM
spiderserie4's Avatar
can't wait for you to open the engine and find the smoking gun!....
spiderserie4 is offline
post #129 of 572 (permalink) Old 10-17-2017, 09:30 AM
My vote is a cylinder is seized to the sleeve. Just 'cause I had the same problem with the same symptoms.
A dropped plug will drop the oil pressure, which he said didn't happen. Also, loosing oil at a bearing will overheat the soft bearing first, causing it to spin in the aluminum bearing. That might melt the aluminum, but it's hard to seize an engine on one bearing.
I too am anxious to find out.....
Robert
AaronsSpider likes this.
60sRacer is offline
post #130 of 572 (permalink) Old 10-17-2017, 06:23 PM Thread Starter
Shakey's Avatar
I took the connecting rod caps off. All four pistons slid smoothly in the liners (although 1 & 4 had less movement, since they're in the vicinity of TDC, and I can't turn the crank).
Now I'm working on removing the crank itself. I'm having difficulty getting the crank pulley off. The overhaul manual says, "bend back lockwasher tab using a punch and a hammer." Looking at the face of the pulley, I see the nut with a flat washer behind it, but no tab.
I've been soaking it in PB Blaster, while I search through the forums for wisdom.
-Kevin
Shakey is offline
post #131 of 572 (permalink) Old 10-17-2017, 06:37 PM
not2old4toys's Avatar
Alfa stopped using the lock tabs on later Spiders Using a air impact tool should remove that nut easily , but it will take at least 125 psi
Cheers, Jon
Present:
1967 Spider
1974 GTV (1969 Tribute)
1993 Spider ( project)
2018 Stelvio
Past:
1964 Giulia Sprint. 1966 Giulietta 101 Sprint
1967 Super 1968 GTV 1974 Berlina
1979 Alfetta Mille Miglia 1987 Milano
Non Alfa:
1953 MGTD 1958 TR3 1962 AH 3000 MKII
1969 AMX
not2old4toys is online now
post #132 of 572 (permalink) Old 10-17-2017, 06:49 PM Thread Starter
Shakey's Avatar
Cheers, Jon
Well, a driveway mechanic like me doesn't have air tools. I guess I'll try the heat method.
-Kevin
Shakey is offline
post #133 of 572 (permalink) Old 10-17-2017, 09:29 PM
Veronica Mangan's Avatar
Thumbs up
That's what Harbor Freight is for. I'm strictly a shade tree mechanic - I don't even have a real driveway, which makes using jacks and jackstands a real joy, but we did invest in an air compressor and air impact wrench. You can even find buys at places like Home Depot. We got a compressor with air tools on sale there a while back. It's worth a try. But the heat method works too. We're all watching this with great interest! My husband has a Spider. Thank goodness I haven't had to pull the engine on it yet. I have been mostly working on his 164.
Keep up the good work!
VM
Help is always close at hand...
1991 white 164L "Spinor"
1986 white Spider Graduate "8 Legs"
1995 Chevy Caprice Wagon (needs a little love)
1998 Subaru Forester (emergency temporary ride)
1986 Ford F250 - farm rig
1977 Chevy Silverado - retired from the concrete mines
in a constant state of repair: not one, but 2, 1968 Rover P6s
needing a new home: 1975 Black Cadillac 6-door limo
27' Ericson
18' Precision daysailer
Veronica Mangan is offline
post #134 of 572 (permalink) Old 10-17-2017, 09:34 PM Thread Starter
Shakey's Avatar
While awaiting divine inspiration on removing the crank pulley, I thought I would do a little more troubleshooting.
(forgive my numbering convention, if it's not technically correct...1 is in front, 4 in the rear)
I loosened the main bearing caps one at a time, starting with #1 and working my way to the rear. When I loosened #4, I could turn the crank. I re-tightened #4, and went back to #3 and loosened it again...no turn.
I pulled the #4 bearing cap, the crank itself was shiny and smooth, but the surface of the bearing was dull and somewhat rough. I pulled all the bearing caps to compare them (at work, we call this an Air Force check). Here's what I found:
I would have expected the bearing surfaces to be smooth and shiny like the crank. All the bearings exhibit some degree of surface action. It almost looks like galling to me. The crankshaft itself looks very smooth and shiny at all locations, with no surface features that correspond to the condition of the bearings. Rubbing the discolored areas with a finger has a rougher tactile feel than rubbing the exterior of the valve cover.
All I did for the photo was to wipe them down with a shop rag. I haven't done any rubbing or cleaning to the bearing surfaces, other than feel around for the roughness that you can see in the photo.
While this seems to be the problem, I do not know the cause. All components had oil on the surfaces, so it seems they were getting lubrication. There wasn't enough coolant leaking into the oil to turn it milky, so I don't think the oil's lubricating qualities were compromised.
Of course, now I've screwed myself: with the bearing caps out, the crankshaft will turn...I'll never get that stupid pulley off now! Once I can remove the crank, I'll be able to see what the upper half of the bearings look like.
-Kevin
Shakey is offline
post #135 of 572 (permalink) Old 10-17-2017, 09:43 PM
While you're figuring out how to get the nut off the front of the crankshaft you could carefully cut open the oil filter and see what's lurking in it.
Chas H is online now
