Engine Seized? - Page 23 - Alfa Romeo Bulletin Board & Forums
 184Likes
post #331 of 572 (permalink) Old 11-10-2017, 12:51 PM Thread Starter
Shakey's Avatar
@spiderserie4, I hadn't considered that the bigger tabs were for coarser threads. I thought it was just an unfortunate design choice. I guess Alfas had different thread pitches for different series.
I've seen photos of S4 engines without the pal nuts. I'm thinking I'll just use locknuts, and torque them to the pal nut value.
-Kevin
Shakey is offline
post #332 of 572 (permalink) Old 11-10-2017, 01:21 PM
horsewidower's Avatar
I'd leave them off and not substitute with anything. The rods are held on by bolt stretch, locknuts at that low torque setting adds no security.
But wait there's more: View my 164LS thread, now parts car status:
You didn't...oh yes I did II. 1995 164LS 5 speed, awesome when it runs!!!
Musings on shop related items:
horsewidower is online now
post #333 of 572 (permalink) Old 11-10-2017, 01:58 PM Thread Starter
Shakey's Avatar
I certainly do not claim to be smarter than the designers, but I was wondering how much good those lock nuts could possibly be doing at that low of a torque value. My only thought was it was possibly related to harmonic vibrations. We encounter plenty of that engineering consideration in turbine engines.
-Kevin
Shakey is offline
post #334 of 572 (permalink) Old 11-10-2017, 02:10 PM
Exactly. You should also consider that adding any appreciable weight to the big end, changes your balance. I don't know how many grams the nut weighs that you are considering.
post #335 of 572 (permalink) Old 11-10-2017, 02:22 PM Thread Starter
Shakey's Avatar
You're exactly right. The good news is, that this is on the stationary main bearing caps. If this were on the connecting rod bearings, it would be a whole different story!
horsewidower likes this.
-Kevin
Shakey is offline
post #336 of 572 (permalink) Old 11-10-2017, 02:26 PM
DOH!!!
So much for my reading comprehension score today.
Carry on.
post #337 of 572 (permalink) Old 11-10-2017, 03:00 PM
PSk
Loctite ...
'71 1750 Series 2 GTV:
PSk is offline
post #338 of 572 (permalink) Old 11-10-2017, 05:37 PM
gigem75's Avatar
I've never used the locktabs on con rods. Red locktite is just fine. I'm pretty sure the Centerline torque sheet has red on the con rods. Just make sure you don't need to take them off after several hours because something "came up". Cleaning all that hardened red stuff off the bolts and nuts is a pain, don't ask me how I know.
The pal nuts when first used can be hard to get started because you are basically threading them onto the main studs since the ends of the tabs that go into the threads are all in the same plane and you have to get them pitched to go on. Not having seen yours that may not be your problem but it's worth mentioning.
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #339 of 572 (permalink) Old 11-10-2017, 06:33 PM Thread Starter
Shakey's Avatar
My connecting rods just had the nut/washer, no pal nuts nor loctite.
-Kevin
Shakey is offline
post #340 of 572 (permalink) Old 11-10-2017, 08:04 PM
gigem75's Avatar
Connecting rods don't need washers or locktabs with locktite. Palnuts are not used on the connecting rods so they shouldn't have had them. locktite = peace of mind.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #341 of 572 (permalink) Old 11-11-2017, 12:20 PM Thread Starter
Shakey's Avatar
After pondering the cigarette seal issue, and reading through the forum a bit, I went with @Vintre's Ultra Copper method. I'm still waiting for it to completely cure before I trim the excess off.
I also put some Ultra Gray on the main bearing cap and main seal. That whole area of the block seems like a torturous design; no wonder there's leak problems.
-Kevin
Shakey is offline
post #342 of 572 (permalink) Old 11-11-2017, 01:21 PM Thread Starter
Shakey's Avatar
Here's how the engine overhaul manual would have you position the piston rings:
I'm a bit uncertain regarding the aa and dd lines. I'm guessing that aa is the axis of the pins? I read on the forums that you don't want any ring gap over the pin. The Hastings instructions address the offset of the gaps for the three components of the oil ring.
EDIT: My thoughts were correct. I found a YouTube video where the individual briefly discusses the thrust line. I should also mention that the Hastings piston rings that I bought from Classic Alfa measured perfectly on their gap.
-Kevin
Shakey is offline
post #343 of 572 (permalink) Old 11-12-2017, 07:55 PM Thread Starter
Shakey's Avatar
The pistons and liners are all in, and everything is still working smoothly. The liners I bought from Classic Alfa came already honed and washed. I washed them again anyway, just to be sure. All measurements have checked out, and I've had no real issues with reassembly so far.
It's starting to look like an engine again! I'm waiting for a warm day, so I can do some touch-up painting in the engine compartment. I also need to pull the oil pan guard off and clean it up. I still have some gasket-scraping on the water pump and oil pans, but progress continues.
I've ordered some transmission parts to stop the oil leaking from the shift tower. Before the engine goes back into the car, I think I'm going to do the 1st and 2nd gear fixes. This will be new territory for me, as I've never done any transmission work before.
-Kevin
Shakey is offline
post #344 of 572 (permalink) Old 11-12-2017, 08:07 PM
gigem75's Avatar
I didn't know Classic Alfa sold Hastings rings. Good thing you washed the liners, no vendor can clean them the way the end user can or should for that manner. Looking good! If you don't have them I'd highly recommend a pair of at least 9 inch snap ring pliers for the syncros.
currently
2017 Giulia Q4
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #345 of 572 (permalink) Old 11-12-2017, 08:17 PM Thread Starter
Shakey's Avatar
The rings gapped right in the middle of the allowable range. The liners were very clean; it was more an exercise in 'peace of mind' to wash them again. I have a whole set of snap-ring pliers...I'll check to make sure I have one of those. Thanks for the tip!
-Kevin
Shakey is offline
