Engine Seized? - Page 13 - Alfa Romeo Bulletin Board & Forums
 184Likes
post #181 of 572 (permalink) Old 10-20-2017, 06:02 PM
#2 and #4 bearings clearly damaged, like the uppers. I'd like to see what the crank journals are like. Do you have a dial indicator? It'd be nice to see of the crank is bent. It doesn't take much to cause a lot of problems.
Robert
60sRacer is offline
post #182 of 572 (permalink) Old 10-20-2017, 06:28 PM
BrundleFly's Avatar
It seems it's not uncommon for bearings 2 and 4 to fail sooner due to the way they're oiled via the crank instead of directly from the block, and with oil pressure having to oppose the centrifuge effect of the spinning crank:
http://www.alfabb.com/bb/forums/engi...tml#post312815
BrundleFly is offline
post #183 of 572 (permalink) Old 10-20-2017, 07:24 PM
Gubi's Avatar
Maybe it's important to drill them in racing applications but, man, the Nord engines are reasonably famous for having strong bottom ends. Something must have gone seriously wrong.
The STP addition could be just a coincidence, but maybe it screwed with the oil flow enough to mess things up. That stuff is probably a bad idea regardless.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #184 of 572 (permalink) Old 10-20-2017, 09:40 PM
Jim G's Avatar
Originally Posted by Gubi View Post
Most (all?) modern spin-on oil filters have a bypass valve. I know Wix, Napa, Purolator, Bosch, etc. do. There's basically a spring at one end of the can, where if the pressure drop across the media gets too high the media shifts in the can and opens up a bypass. No need to spend a ton of cash on an oil filter just for that feature.
No. Not all of them do. Quite a few don't. So do your research on the filters you get.
It was Wix Filters on the 2 boat engines that stopped up. When I talked to Wix I was shocked to find out they didn't have a bypass and they were the top of the line Wix filters for V-8 Chevy's. Expensive lesson learned.
Jim G is offline
post #185 of 572 (permalink) Old 10-20-2017, 10:06 PM
Gubi's Avatar
I don't know about your boat engines, but the Wix automotive ones do. See below for example disassembly photos:
Engine Oil Filter Study
I've never seen a modern automotive canister oil filter without a bypass, myself. Even the POS Fram filters have them.
1974 GTV
1991 Spider
Gubi is online now
post #186 of 572 (permalink) Old 10-20-2017, 11:11 PM
Jim G's Avatar
All those filters are for one type of Ford engine. As the article stated. Filters are made for specific engines. Not all of them will have a bypass.
Doesn't matter if its for a car or a boat. An oil filter for a specific engine brand is going to be the same in either application.
Below is from Wix.
Some WIX full-flow filters include anti-drainback and/or filter by-pass valves. These types of filters are identical to full-flow filters, except that a by-pass valve replaces the inner element support and an anti-drainback valve has been added. The Anti-Drainback Valve prevents oil from draining out of the filter inlet holes when the engine is shut off. It also provides seal between clean and dirty oil at the upper end cap. This is necessary in applications where the oil filter is mounted in a horizontal or inverted position.
The Filter By-Pass Valve
If a WIX full-flow filter becomes "clogged", or excessively restrictive to oil flow, the filter by-pass valve ensures continued engine lubrication by allowing the oil to by-pass the filter. Some vehicle manufacturers have the by-pass valve built into the oil filter mounting unit (located on the engine).
Other vehicle manufacturers require full-flow filters have the by-pass valve built into the filter itself. All Wix oil filter types recommended for these particular applications include the by-pass valve assembly in the filter.
As I said in an earlier post. Do your research and make sure it has a bypass. Oil filters completely stopping up is rare. But it can happen.
Another chart I found about oil filters. All these filters fit the same type engine.
Jim G is offline
post #187 of 572 (permalink) Old 10-20-2017, 11:12 PM
John533i's Avatar
Are you confusing bypass with anti-drain back? I've only heard of oil pressure by-pass as being a function of the filter housing, if it exists at all.
-Ah, we posted one minute apart, never mind.
I had a friend at an independent BMW shop that was on an oil change interval and filter Jihad, around 2005 or so. BMW had some recent models out with extended oil filter changes, as in 2year oil changes. He had a filter on his website from a BMW certified pre-owned vehicle that was brought in for some engine issues, and he cut the filter in half to show how bad an idea it was to go that many miles/years with out changing the oil filter. It was black jelly inside the filter, which was clearly a BMW filter. It took a lot of time to clear that engine of sludge, IIRC.
86 spider Veloce
74 TR6
John533i is offline
post #188 of 572 (permalink) Old 10-20-2017, 11:57 PM
Gubi's Avatar
Fair enough: don’t use the filter for a Chevy in your Alfa then, I guess. I assume there must be one in the filter mount on the engine for that car.
The Alfa cross-reference ones do have them, though. So unless someone got real creative i doubt that’s the problem here, but easy enough to look up the specs of the filter on the car.
1974 GTV
1991 Spider
Gubi is online now
post #189 of 572 (permalink) Old 10-21-2017, 01:03 AM
PSk
Originally Posted by Shakey View Post
Here's a view of the upper bearings, still in the block. The surface action seems comparable to the lower bearings.
Looks very clean.
'71 1750 Series 2 GTV:
PSk is offline
post #190 of 572 (permalink) Old 10-21-2017, 02:56 AM Thread Starter
Shakey's Avatar
The bearings did have oil on them; I wiped them off with a rag to see the condition of the surface.
-Kevin
Shakey is online now
post #191 of 572 (permalink) Old 10-21-2017, 05:16 AM
It will be interesting to see how straight the crankshaft is. I cannot imagine how it would be bent enough to lock it up like that. I had the main journals ground on a Spider crank last year and the machinist found that it was .0015" out of alignment which he was able to correct when he ground them.
2011 Jaguar XKR
alfaparticle is offline
post #192 of 572 (permalink) Old 10-21-2017, 05:40 AM
Try installing the crank alone (ie, no pistons, etc) and see if turns. If no, then I suppose it could only be a bent crank. If yes then I think it would point to an oil starvation issue. That said, those bearings don't look all that horrible as to seize the motor...
AaronsSpider likes this.
gprocket is offline
post #193 of 572 (permalink) Old 10-21-2017, 09:06 AM
What would cause a bent crank? I've seen a broken crank on a 67 camero after the manual transmission locked up.
Beerman73 is offline
post #194 of 572 (permalink) Old 10-21-2017, 09:19 AM
What do the rod bearings look like?
I doubt very much the crankshaft is bent. Nothing looks like it got hot. The trace we see on #2 and #4 is from some sort of debris. If the crank was bent we would see evidence on #3 bearing.
sbadaro likes this.
Chas H is online now
post #195 of 572 (permalink) Old 10-21-2017, 11:16 AM
True if the bend is in the middle. The Spec is +/- .0005" between journals. Mine was worse than that but not noticeable.
2011 Jaguar XKR
