Engine Seized? - Page 10 - Alfa Romeo Bulletin Board & Forums
 184Likes
post #136 of 572 (permalink) Old 10-17-2017, 10:04 PM
SamGTV's Avatar
I recently pulled apart a 2L engine from an Alfetta. One of the biggest problems was getting the crank shaft pulley off. I spent a decent amount of time leaning on it with a breaker bar extended with a piece of pipe and blasting it with all sorts of penetrating fluid but had no luck. In the end i borrowed an impact gun off of a mate and it came off easily. I would seriously look at going and buying a battery powered unit, makes the job a lot easier.
SamGTV is offline
post #137 of 572 (permalink) Old 10-17-2017, 10:29 PM
Jim G's Avatar
All of a sudden I can't view any of Shakey's pictures.
Put the number 4 main cap back on and if it locks the crank down you can then use a long breaker bar and a jack handle over it to make it longer and get the nut free. Have someone stand on the leg of the engine stand on the opposite side to keep it from flipping over.
The nut is a lock nut so no tab to worry about.
Also Alfa started doing something different in the late 70's to the crank plugs. After that they no longer were dropping out. My guess without being able to see a picture of the bearing is something stopped up or mostly blocked off the oil passage to the bearing causing the crank to lock up.
Jim G is offline
post #138 of 572 (permalink) Old 10-18-2017, 12:17 AM
^THIS^
Go out to harbour freight or whatever it is you have in the US and get yourself a battery operated impact wrench.. It's surprising how much easier stuff becomes when you have an impact wrench to undo bastard nuts and bolts. I have an air operated one, but a mate has an battery one and it's much less hassle (ie. No compressor or lines).
Don't forget all the other bits that could have jammed, distributor, oil pump, lower timing chain...
Craig_m67 is offline
post #139 of 572 (permalink) Old 10-18-2017, 07:05 AM
I use a Dewalt 1/2" 20V cordless impact wrench a lot and it will not loosen a crank pulley nut, neither will my big heavy corded Dewalt gun. A Harbor Freight "Earthquake" 1/2" air gun will get one off easily.
2011 Jaguar XKR
alfaparticle is offline
post #140 of 572 (permalink) Old 10-18-2017, 07:21 AM
nealric's Avatar
If you like electric, the Milwaukee Fuel high torque offering is rated to about the same torque as the Harbor Freight "Earthquake" air tool. I've yet to find anything it won't unfasten (or break).
1986 Spider Veloce Turbo
nealric is offline
post #141 of 572 (permalink) Old 10-18-2017, 09:23 AM Thread Starter
Shakey's Avatar
I have a HF 120VAC impact wrench. It's supposed to be 240 ft/lbs, but it doesn't seem to perform well.
I don't even use it on wheel lug nuts any more! ...a different story for a different forum.
-Kevin
Shakey is offline
post #142 of 572 (permalink) Old 10-18-2017, 10:57 AM
nealric's Avatar
I still have one of those sitting in a cabinet unused. It's pretty worthless. They actually have much better cordless units at HF now.
nealric is offline
post #143 of 572 (permalink) Old 10-18-2017, 03:34 PM
xalfaracer's Avatar
Shakey,
You have the head off, right? If so use some method of keeping the liners in place then shove the pistons up from the bottom enough so that you can see what the bearings look like. My experience is with a 750 or 101 engine so this idea may not apply.
As far as keeping the liners in place, use some thin wall metal electrical conduit cut to size with washers on both end and the head nuts on finger tight will do the job.
xalfaracer is online now
post #144 of 572 (permalink) Old 10-18-2017, 04:14 PM Thread Starter
Shakey's Avatar
Originally Posted by xalfaracer View Post
Shakey,
The rod end bearings look good. I cut a couple of pieces of 1/2" PVC pipe and used some washers to hold down the liners.
-Kevin
Shakey is offline
post #145 of 572 (permalink) Old 10-18-2017, 04:27 PM
PSk
There is an assumption here that you have been able to push the pistons up as previous poster suggested.
That only leaves crank won't turn, so flywheel or timing chain jammed. I cannot imagine a main bearing failure causing the crank to seize.
'71 1750 Series 2 GTV:
PSk is offline
post #146 of 572 (permalink) Old 10-18-2017, 04:36 PM
Member
I have a history as an offshore sailor having to deal with diesel inboard engines. The traditional method is to suck some vinegar into the coolant system and let it sit for a couple of days, and then pump it out. Vinegar is a mild acid, and does a good job of getting things clean.
Factotum
factotum is offline
post #147 of 572 (permalink) Old 10-18-2017, 04:37 PM Thread Starter
Shakey's Avatar
Flywheel is off. When I loosened the lower main bearing caps, I could turn the crank. I cannot see what the upper half of the main bearings look like until I get the crankshaft free. As to what caused that kind of wear on the bearings...I'll have to look around once the crank is out.
-Kevin
Shakey is offline
post #148 of 572 (permalink) Old 10-18-2017, 04:54 PM
horsewidower's Avatar
Radiator shop told me to circulate Cascade through for two flushes and then flush with plain water until clean.
But wait there's more: View my 164LS thread, now parts car status:
You didn't...oh yes I did II. 1995 164LS 5 speed, awesome when it runs!!!
Musings on shop related items:
horsewidower is offline
post #149 of 572 (permalink) Old 10-18-2017, 05:00 PM
It happened to my Spider when the engine dumped it's oil. My daughter was driving it and she did not stop in time to save it. In this case the bearing cap was discolored from the heat. The block and crankshaft were toast.
2011 Jaguar XKR
post #150 of 572 (permalink) Old 10-18-2017, 05:06 PM
Why can't I get this pulley nut off! I guess I can't complain. This is the first impasse I've encountered throughout this whole project.
Just drill it and crack it off, it's soft. Be careful not to get to close to the shaft/thread. The nut is available from all good suppliers. I did this on my duetto purely out of days of frustration
I now have an impact wrench
