Ignition Switch Connector - Alfa Romeo Bulletin Board & Forums
 5Likes
post #1 of 18 (permalink) Old 08-13-2017, 01:54 PM Thread Starter
Vintre's Avatar
Hello All,
1991 Spider Veloce.
I have had issues with my ignition switch so I decided to replace it.
Getting the ignition switch out is patience testing enough but now I have this.
Seems like a bit of power was going through the connector and it has melted together.
Since the connector seems to have been melted together, I can't separate them.
Any suggestions?
As always, thank you in advance.
Vin
Vintre is offline
post #2 of 18 (permalink) Old 08-13-2017, 02:49 PM
BB Janitor
ghnl's Avatar
First, walk down to the 7-11 and buy a lottery ticket! Luck must be on your side!!
I would strip back the wire harness cover and see if you can find undamaged wires. Then go 6"-8" further and attach new wires (either a proper crimp or solder/heat shrink tubing). I am not sure where you can find a new connector but it doesn't have to be an Alfa-specific item. (you'd also need to put the other half of the connector onto the new ignition switch wires)
You may also want to consider adding a relay to the system so the ignition switch doesn't have to carry the full load of switched items. I did this to our GTV6 and found all the switched items work a lot better not that they get full system voltage.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #3 of 18 (permalink) Old 08-13-2017, 03:05 PM
Gubi's Avatar
Great googly-moogly. It's possible your switch is okay and something else went wrong that caused the wiring problem.
The brown wire powers the fusebox: that looks okay, so probably an ignition relay won't make a difference. It looks like it's melted between the incoming +12 line and the black starter solenoid wire, so my guess is too much current on that circuit heated up the connectors and melted the insulation.
Normally I'd say install a starter relay, but you already have one, correct? I suppose it's possible this damage predates the relay? Or perhaps you had a short/failure in the stater relay circuit that caused the melting. Were you having issues before you installed the relay?
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #4 of 18 (permalink) Old 08-13-2017, 03:07 PM Thread Starter
Vintre's Avatar
Thanks Eric,
I added a relay a few years ago when I was stranded a few times. Looks like the relay got me a few more years out of the ignition.
I will leave the relay after I get this mess cleaned up.
So, basically, cut the connectors out, and splice the wires together?
Vin
Vintre is offline
post #5 of 18 (permalink) Old 08-13-2017, 03:20 PM
Gubi's Avatar
To clarify: you added a starter relay, Eric is talking about an ignition relay. Two different things.
An ignition relay isn't a terrible idea, but it's a bit more complicated/risky to install than a starter relay (while it can help with voltage drop it's adding additional potential points of failure to your main power feed). In this case I don't think that's your problem: see what I wrote above.
1974 GTV
1991 Spider
Gubi is online now
post #6 of 18 (permalink) Old 08-13-2017, 03:34 PM
USTA BE AN AD-MIN
ossodiseppia's Avatar
It's hard to tell if that is a three wire plug, but British Wire has connectors and terminals that will work.
3-Way 1/4" Spade Connector
ghnl and Norseman50 like this.
ossodiseppia is online now
post #7 of 18 (permalink) Old 08-13-2017, 03:44 PM Thread Starter
Vintre's Avatar
Yes, I was stranded 2x before adding the relay.
Both times, on hot days, with the ignition in the accessory position for 20 mins or so, the car would not start.
I would then wait 30 minutes or so, with the key completely out, and the car would start right up.
After the starter relay was installed, I have not had any issues starting for years. Until recently.
Vin
Vintre is offline
post #8 of 18 (permalink) Old 08-13-2017, 03:47 PM Thread Starter
Vintre's Avatar
Yes, its a 3 wire plug, although the new ingnition switch came with an additional green wire, AND the original ignition switch also had 2 small wires that the new one does not. Ugh!
Do you think it is important to use the connector as shown or can I just use male/female connectors and heat shrink to protect them?
As always, grateful to the community for your help.
Sincerely,
Vin
Vintre is offline
post #9 of 18 (permalink) Old 08-13-2017, 04:30 PM
BB Janitor
ghnl's Avatar
Separate connections (properly insulated) will work fine. The advantage of the connection blocks is that it will make sure they always go together correctly.
The smaller wires are probably for the tiny lamp at the ignition switch and the 'hey dummy, you left the key in the ignition' warning buzzer.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #10 of 18 (permalink) Old 08-13-2017, 04:34 PM Thread Starter
Vintre's Avatar
Well, cant say I remember every having the tiny lamp at the ignition switch and maybe that is what the green wire in the new ignition switch is for?
If that is what the green wire is for, dont know if I have to connect it to the red or black wires?
Vin
Vintre is offline
post #11 of 18 (permalink) Old 08-13-2017, 04:47 PM
BB Janitor
ghnl's Avatar
Or maybe to the lamp?
Do you have a copy of PapaJam's wire diagrams?
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #12 of 18 (permalink) Old 08-13-2017, 05:15 PM Thread Starter
Vintre's Avatar
I think that is the way I will go. The guage of the wire seems to be 12, so I will need to get some of that tomorrow and the proper insulated connectors.
I dont want to jinx myself, as it wouldnt be the first time, but looks like the wires are well colour coded, Red, Black and Brown.
Wish me luck.
Vin
Vintre is offline
post #13 of 18 (permalink) Old 08-13-2017, 06:21 PM
mcola's Avatar
Quadspy and I were talking about Vintre's issue the other day, and he said that when he had some time he wanted to look into the possibility of adding the relay you speak of. Can you share the details, providing it would be similar to what would be needed in a Spider?
Mike
'87 Quadrifoglio
mcola is offline
post #14 of 18 (permalink) Old 08-13-2017, 06:24 PM
rogerspeed's Avatar
typically four wires ignition switch:
1)power in
2)power out (run)
3)starter
4)accessories
the key buzzer is two thin wires
the ignition switch ring lamp is not part of the ignition switch harness
current:
84 Spider Veloce
ex:
rogerspeed is offline
post #15 of 18 (permalink) Old 08-13-2017, 07:00 PM
BB Janitor
ghnl's Avatar
I did this in our GTV6. The Spider would be the same (I haven't done it there yet but likely will as soon as I get a Roun Tuit). See reply #12 here: http://www.alfabb.com/bb/forums/alfe...r-82-gtv6.html Note this is different than the relay for the starter solenoid. This relay prevents the ignition switch from having to carry the full load of all switched accessories.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
