Brake pipe broke, very strange and dangerous. Duetto 1967 - Alfa Romeo Bulletin Board & Forums
 3Likes
  • 1 Post By ghnl
  • 1 Post By ossodiseppia
  • 1 Post By Jim G
post #1 of 7 (permalink) Old 07-29-2017, 03:38 AM Thread Starter
Wille R.'s Avatar
Exclamation Brake pipe broke, very strange and dangerous. Duetto 1967
Last week I was driving together with an MGB -64 and did some Italian Tube-up to warm up my friend. We were heading for the 1900 Garage. Speed was over normal and many turns and bends and hard breaking. When we got 200 meters from the garage, my brakes felt spongy. When I stopped and turned the engine off, I pressed the pedal quite hard, suddenly it went down all the way. Pressed once more and the pedal went to the floor again. Panic. We looked under the Alfa and under the rear axle there was a big brake fluid spot. Very big. Anyway, we checked and it turned out that the pipe going from the 3-way junction had been pressed out. See pics. It could have ended very bad as we had been driving very hard on the way.
I just want to inform that it is essential to check the brakes now and then. The material had cracked wehere you cannot see anything as the nipple holds it down in place.
I got quite scared when I noticed how bad it might have ended. Problem fixed today and the test drive was very fun.
[B]1967 Roundtail Spider, "Duetto" Mine since 1970. Meno parole, piú Duetto!.[/B]
My [B][COLOR="Red"]Duetto sites [/COLOR][/B]
and the [B][COLOR="Red"] Duetto Register [/COLOR][/B]
and
[B][COLOR="Red"] Duettoinfo [/COLOR][/B]
Wille R. is offline
post #2 of 7 (permalink) Old 07-29-2017, 11:39 AM
John533i's Avatar
Wow, glad that you're OK. It was smart to pull over when you did! It doesn't happen that way very often with brake fail stories
86 spider Veloce
74 TR6
John533i is online now
post #3 of 7 (permalink) Old 07-29-2017, 11:57 AM
BB Janitor
ghnl's Avatar
Are they copper brake lines? (not cupro-nickle) Copper will work hardened then break easily if allowed to flex.
PSk likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #4 of 7 (permalink) Old 07-29-2017, 02:34 PM
USTA BE AN AD-MIN
ossodiseppia's Avatar
Wille, it might be a good idea to change out all of the brake lines.
PSk likes this.
ossodiseppia is offline
post #5 of 7 (permalink) Old 07-29-2017, 09:47 PM
Jim G's Avatar
Now you know why the DOT passed the requirement for a duel stage master cylinder in 1969.
rogerspeed likes this.
Jim G is online now
post #6 of 7 (permalink) Old 07-29-2017, 10:14 PM Thread Starter
Wille R.'s Avatar
Wink
Sure will do. I have always used DOT best quality over the years. DOT4 since it was launched. My Duetto has a single brake circuit as it is an Euro version. Anyway, I sure will press the brake pedal very hard when in the garage to check for elaks until I replace the other lines.
and
Wille R. is offline
post #7 of 7 (permalink) Old 07-30-2017, 06:57 AM
USTA BE AN AD-MIN
Another winter project.
