Troubleshooting 76 Spider blower fan - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By ARwrench
post #1 of 8 (permalink) Old 07-28-2017, 06:33 PM Thread Starter
Blower fan hasn't worked since I got the car. I found several good threads on this forum and am working through them. One question if you please, regarding the fan switch and the "heating" light in the speedo.
With my fan switch in the top position the light is off. With the switch in the middle position the light comes on. With the switch in the bottom position the light goes off again.
What does this mean?
Canadian Spider is offline
post #2 of 8 (permalink) Old 07-28-2017, 07:25 PM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
First off ..does the fan blade turn?
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #3 of 8 (permalink) Old 07-28-2017, 07:38 PM Thread Starter
I can't figure out where to stick my finger/screwdriver to check. I feel all around but there isn't anything there like a fan blade. Just solid plastic.
These are the holes I am probing. Any suggestions?
post #4 of 8 (permalink) Old 07-28-2017, 07:41 PM
ARwrench's Avatar
Take those 8mm? bolts off the duct to gain access to the blade
cuorealfa likes this.
ARwrench is offline
post #5 of 8 (permalink) Old 07-28-2017, 09:14 PM
Alfajay's Avatar
You don't need to stick your fingers anywhere; if the fan is turning, you will hear it. If it's silent, the the answer to ARwrench's question is "no".
Well, that's a little weird. The light just indicates voltage to the motor. The middle position is "high", so the light is typically bright (which you confirm). The bottom position puts the blower motor on low speed; typically the light will be on, but glowing dimly in that position (which you report as "off"). Can you see the light at night with the switch on "low"?
Alfajay is online now
post #6 of 8 (permalink) Old 07-28-2017, 10:14 PM
Jim G's Avatar
Put the air distributing lever about half way. Then stick your finger in the bottom of the slot you pictured and it will go in between the case and the flap you see pictured. You should then feel the fan blade. Push it with your finger. If it will spin then the is probably bad. If its stuck then see if you can free it by turning it.
You can search the BB for different things to try if its stuck.
Jim G is offline
post #7 of 8 (permalink) Old 07-28-2017, 10:17 PM
Gubi's Avatar
Listen to Jim. No need to remove anything: just reach in there and spin it.
Often the bearings rust up. If that's the problem you can get it working with manual spinning an copious application of spray lube.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #8 of 8 (permalink) Old 07-29-2017, 02:00 AM
spiderserie4's Avatar
obviously make sure the 4 wires are still connected to the heater.....
and also worth trying to put 12V direct to heater to see if it works.
http://www.alfabb.com/bb/forums/spid...ench-test.html
spiderserie4 is offline
