89 spider graduate fuel pump blown - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 07-28-2017, 03:29 PM Thread Starter
Hi ,my 89 graduate is blowing the fuel pump fuse (30 A),i change it and starts and blows right away,any recomendations ????
Thks.
giorgiofrette1 is offline
post #2 of 10 (permalink) Old 07-28-2017, 03:34 PM
Gubi's Avatar
You posted in the 164 forum.
I don't have my wiring diagram in front of me, but I think on the S3 that fuse also protects he in-tank pump and the O2 sensor heater (it definitely does on the S4). For staters, unplug the two-wire Bosch connector to the O2 sensor and see if that fixes the the problem.
If nobody else beats me I'll check the wiring diagram tonight for other ideas.
1974 GTV
1991 Spider
Former: 1987 Milano Gold
Gubi is online now
post #3 of 10 (permalink) Old 07-28-2017, 04:25 PM
That's was the issue with my 86. Inline fuse would blow and I would lose my main pump. The issue was a short in the in-tank unit. My mechanic changed out the sending unit and that fixed the problem.
Jim99 is offline
post #4 of 10 (permalink) Old 07-28-2017, 05:14 PM
Gubi's Avatar
Yeah, just checked: fuse covers O2 sensor heater, main fuel pump, in-tank pump, and AAV. Likely one of those.
Also, in the wiring diagram that's an 8A fuse, not 30! I'm not sure what's correct, but if it's supposed to be 8 and someone stuck in a 30 to keep it from blowing that's not good.
1974 GTV
1991 Spider
Gubi is online now
post #5 of 10 (permalink) Old 07-28-2017, 05:51 PM
BB Janitor
ghnl's Avatar
(I took the liberty of moving this thread to the Spider section.)
Indeed the correct fuse for that location is 8 amps.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #6 of 10 (permalink) Old 07-28-2017, 06:46 PM
Registered Member
mcola's Avatar
Wow, great info! Thanks for posting. I always thought it was just for the pumps.
Mike
'87 Quadrifoglio
mcola is online now
post #7 of 10 (permalink) Old 07-28-2017, 07:59 PM
Gubi's Avatar
Yeah, I've seen a surprising number of O2 sensor heaters short out, which blows the fuse. Go figure.
1974 GTV
1991 Spider
Gubi is online now
post #8 of 10 (permalink) Old 07-28-2017, 10:09 PM
Jim G's Avatar
Once you find the short. You should use a 15 amp fuse for the circuit. The 8 amp the manual calls for is really to low for what the circuit pulls once it has some age on it.
Besides thats what they told us to do. When I took one of the Alfa factory Spider classes back in the day.
Jim G is offline
post #9 of 10 (permalink) Old 07-29-2017, 07:17 AM
Registered Member
mcola's Avatar
Also good to know. I've blown the 8 (7.5) a few times over 5-7 years. Next time its going to a 15.
Mike
'87 Quadrifoglio
mcola is online now
post #10 of 10 (permalink) Old 07-29-2017, 07:10 PM
alfabeach's Avatar
I thought the main fuel pump fuse was the 8amp one under the rear parcel shelf?
Richard
76 Alfetta GTV gone to rust haven, 89 Spider the red graduate, 86 GTV6 on wish list
alfabeach is offline
