S4 Side Mirror Loose - Alfa Romeo Bulletin Board & Forums
post #1 of 11 (permalink) Old 07-23-2017, 01:50 PM Thread Starter
srguy's Avatar
I've had this issue since I purchased the car 2 years ago, The mirror on the driver side continues to loosen from the base even though I've added shims. Time to take the door apart. Has anyone on the bb dealt with this issue? I see from the maintenance disc how to remove the panel but are the screws that fasten the mirror accessible? Any tips are appreciated.
srguy is offline
post #2 of 11 (permalink) Old 07-23-2017, 02:46 PM
sriswit's Avatar
Can you show a picture of your issue? I've rebuilt my S4 passenger side mirror before but not sure if your problem is the same as mine.
65 TI, 74 GTV, 86 GTV6, and 91 Spider
sriswit is offline
post #3 of 11 (permalink) Old 07-23-2017, 05:03 PM Thread Starter
srguy's Avatar
Got the panel loose except for the upper screw on the grab handle. Seems frozen but hit it with wd40 and see if I can get it removed tomorrow.Will post photos as soon as I get the panel off. As I mentioned earlier the base of the mirror is connected firmly to the door it's the joint between the base and the mirror housing that's loose. Any suggestions are greatly appreciated.
srguy is offline
post #4 of 11 (permalink) Old 07-23-2017, 07:19 PM
sriswit's Avatar
Then your problem is the same as mine. Once you take the mirror off, you'll find that the mirror frame is connected to the base via a threaded rod, a spring, and a nut. It could just be that the nut is loose. If that's the case, you are quite lucky.
In my case, the threaded rod was stripped so the nut cannot hold tightly. In this case, you will need to drill out the old rod. Find a metal rod of about the same size (the ones used for lamp shades work quite well) and then tap the hole and secure the new rod. Might need to cut it to get the right length. You'll also need to find a new nut that fits on the new rod. You can then reconnect the mirror back to the base. Make sure to put the spring back on there too so that you can fold in the frame.
sriswit is offline
post #5 of 11 (permalink) Old 07-24-2017, 11:22 AM Thread Starter
srguy's Avatar
If I understand correctly the mirror base that attaches to the door must be removed in order to tighten the mirror frame to the base, correct?
srguy is offline
post #6 of 11 (permalink) Old 07-24-2017, 11:32 AM
sriswit's Avatar
Yes, you need to remove the entire mirror assembly to get to the underside of the base. I think you need to move the two 8mm nuts from inside the door, disconnect the power harness and then the assembly can be removed from the outside.
This is where you can see if there are any problems with the mechanism to secure the frame to the base. Basically, at the bottom of the frame, there is a long threaded rod that extends into the base. From the base side, there is a stiff spring to allow folding and then a nut to secure the frame to the base. Threads on that rod tend to stripped.
sriswit is offline
post #7 of 11 (permalink) Old 07-24-2017, 02:06 PM
spiderserie4's Avatar
mmolto posted some excellent photos here:
http://www.alfabb.com/bb/forums/spid...options-2.html
spiderserie4 is offline
post #8 of 11 (permalink) Old 07-25-2017, 09:15 AM Thread Starter
srguy's Avatar
Thanks ... Are the bolts that secure the base to the door accessible from the inner door panel? Couldn't tell from the photos
srguy is offline
post #9 of 11 (permalink) Old 07-25-2017, 09:31 AM
sriswit's Avatar
They can be accessed from inside the door once the panel is removed.
sriswit is offline
post #10 of 11 (permalink) Old 07-25-2017, 09:41 AM
2nd photo in that link shows the bolts inside door.....
I am guessing small hands needed, to get up there
post #11 of 11 (permalink) Old 07-29-2017, 12:17 PM Thread Starter
srguy's Avatar
Well in true Alfa fashion the internals of the mirror had been modified by the PO. The sleeve that's carries the wires is intact however it looks like the stem was broken off. The PO drilled 3 holes from the mirror base to the mirror housing and glued the housing to the base and fastened it with 3 screws which if found had loosened along with the glue hence the loose mirror. Sorry I neglected to take photos. Rather than reinvent the wheel I elected to use an item that I've used in the past called Mr. Grip wood fasteners. Cut a few slivers and dropped them in the holes along with sanding off the glue residue to create a flat surface and the mirror is secured to the base. The results look good we'll see if it lasts.
I gathered from other posts that the mirrors swivel is that right? If so this one doesn't and won't. Hopefully I won't have to address this in the future. Thanks for all the suggestions. BTW the nuts that secure the base to the door are 10mm.
srguy is offline
