-   Spider - 105 & 115 Series (1966-1994) (https://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/)
-   -   while replacing radiator..? (https://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/593537-while-replacing-radiator.html)
adamreed31 06-22-2017 11:41 AM
Hello all.
About to replace my defunct radiator.
It has been repaired more than once so I am going to just give it a clean slate.
My question is while replacing the radiator, what are some inexpensive things that should be replaced at same time?
hoses if crapped out/tired I assume?
plastic fan if tired?
fan belt?
Any input appreciated from those more experienced than I.
Thanks again!
bruce1976spider 06-22-2017 11:53 AM
Probably just what you think - I have my whole engine out right now (which means the radiator came out too).
I'm replacing ALL of the radiator mounting padding, the two rubber bushings (if I can find them), the heater hoses (which aren't formed special - just generic hose). I'll check the thermostat.
I will flush my heater core too - because I had an OIL-in-the-antifreeze problem. Mine has an electric fan conversion that needs new wiring as well.
Alfaboutvegas 06-22-2017 12:38 PM
mounts
The mounting brackets are available from almost all venders listed here on the board as well as any other you might choose.
inexpensive at least to change them, so,,, why not. Easier than having to after the radiator is re-installed.
spiderserie4 06-22-2017 12:40 PM
check waterpump for leaks
check front crankshaft oil seal for leaks
(both somewhat easier to inspect with rad removed)
alfabeach 06-22-2017 02:31 PM
Also makes it easier to get to distributor for changing cap and rotor.
Jim99 06-24-2017 09:03 AM
You should replace the fan. They are plastic an known to fail with age. It is not pretty when they come apart. Inexpensive
alfazagato 06-24-2017 09:10 AM
Change the plastic shroud too if it cracked or missing bits. Makes a lot of difference.
adamreed31 06-24-2017 09:45 AM
yeah...agreed. I'm thinking radiator, all hoses, all clamps, shroud (mine is cracked), and new fan....project creep!!!! warning! warning!
BMX 06-24-2017 10:11 AM
Bin the fan and fit a pusher electric one, much more efficient and quiet
adamreed31 06-24-2017 10:23 AM
Would love to bmX! not sure If I am confident enough with the install doing myself....I wish someone had a step by step/idiots guide for the conversion...have not see one.
adamreed31 07-31-2017 11:04 AM
OK .
Just a follow up .
Finally was able to complete radiator install on my 87 s3.
Replaced radiator with new unit from Vick, new upper and lower hoses, new clamps, new fan shroud.
Fan was in good order...not faded or brittle so I left it.
Bled out cooling system, replaced fluid, fired up....good to go!!
So far so good.
Was proud of myself for I have never replaced one before.
Thanks for all your input/guidance.
60sRacer 07-31-2017 02:35 PM
Originally Posted by alfazagato (Post 7686385)
Change the plastic fan. They are notorious for failure, and not pretty.
I had one explode at a kinda high speed. The dents in the hood were a nightmare to fix.
Robert
BMX 07-31-2017 11:13 PM
Its surprisingly easy with a good kit, I used a cheap kit because I'm fine with DIY, but it sounds like your starting to learn your way round, you've done good so far, once you gain confidence you'll be itching to do other work on your Alfa, good start
