Steering stuck, key won't turn - Page 2 - Alfa Romeo Bulletin Board & Forums
 6Likes
post #16 of 22 (permalink) Old 08-08-2017, 01:41 PM
SpiderMan59's Avatar
Hi All,
I just encountered this problem today, upon parking my 1991 Spider right after it was delivered to me - the key and steering wheel locked up. So I came here looking for the answers - I was able to unstick everything by another wiggle of the steering wheel and key, but I am concerned that this problem will recur, as it will unless I get the lock mechanism replaced, right?
A couple of questions - is the lubricant mentioned above Tri-Flow? I think my keys are the original ones....can I just go to a hardware store or locksmith to get copies cut from them?
JimB in SoCal
Current Cars Owned: 1991 Alfa Romeo Spider Veloce!!!!, 2012 Buick Verano
Previous Cars Owned: 1956 Chevy Sedan, 1969 Chevy Caprice Sedan, 1973 Chevy Caprice Sedan, 2000 Saturn S1 Sedan.
SpiderMan59 is offline
post #17 of 22 (permalink) Old 08-08-2017, 03:29 PM
Del
Our Milano had this sort of thing happen, and it turned out a piece of the casting broke off inside the cylinder. Had to take it all apart and take out the broken piece. Then it worked ok since. The broken piece was a tab inside which retained the key when turned, forgot just how now, but the switch works ok now with no problems.
Del
Seattle
1989 Milano, Shankle Sport
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
previously owned since 1964:
Del is offline
post #18 of 22 (permalink) Old 08-08-2017, 04:18 PM
I hope that's not the case with mine.....
JimB in SoCal
post #19 of 22 (permalink) Old 08-08-2017, 06:43 PM
Del
Well, it was an easy fix, actually, but you do have to remove the switch from the column. that wasn't bad either. Just meant removing a soft metal screw which retained the switch in the column, by cutting a slot in the domed top and unscrewing it.
SpiderMan59 likes this.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is offline
post #20 of 22 (permalink) Old 08-08-2017, 11:57 PM
spiderserie4's Avatar
yes.
yes, as long as they have the right sort of blanks (or you supply them blanks)
I had my original keys copied here at a shop, but not from Silca blanks, just something he had hanging up on the wall, and they fitted and worked but were notchy and sometimes stuck (maybe just bad work, few hardware stores care about the final refinish)
in the end I took some good digital photos of both sides of each key and emailed them off to keys4classics in Australia
QUALITY KEYS FOR Alfa Romeo Spider 1981-94
...I recieved perfect cut keys back, which worked as smooth as silk. They can decode the key from good photos...
NB: it is generally a good idea for anyone to take good photos of their keys (especially if they only have one set), both sides, and keep them on file.
Robertinwc and SpiderMan59 like this.
spiderserie4 is online now
post #21 of 22 (permalink) Old 08-11-2017, 04:38 PM
Originally Posted by spiderserie4 View Post
yes.
Thanks very much for that valuable tip and link, Spiderserie4! I have not been able to get keys cut here (have tried Pep Boys, Home Depot, a local hardware store, and two nearby locksmiths - nobody has the correct/compatible blanks), so I will take pics of mine and email them to keys4classics. I picked up the Tri-Flow a couple of days ago as well.
Thanks (Danke!),
JimB in SoCal
post #22 of 22 (permalink) Old 08-11-2017, 06:32 PM
Del
I was pleased with the service I got from keys4classics when they found keys for the Alfa 164 roof rack.
Del
Seattle
1991 164S, stock
1994 164LS (~Q)
1972 Morgan 27
Del is offline
