plug in rubber door gaskets? - Alfa Romeo Bulletin Board & Forums
 5Likes
  • 1 Post By Vintre
  • 4 Post By spiderserie4
post #1 of 13 (permalink) Old 02-19-2017, 02:28 PM Thread Starter
lgbalfa's Avatar
Send a message via Skype™ to lgbalfa
these rubber door gaskets, are they suppose to have a plug?
i had them installed two summers and just noticed that mine do not have them.
thanks
1992 Alfa Romeo Spider Veloce, 2017 Alfa Romeo Giulia, 2018 Volkswagen Tiguan SEL Premium
lgbalfa is offline
post #2 of 13 (permalink) Old 02-19-2017, 03:41 PM
radamm's Avatar
A little dab of black RTV would be discrete and keep rain out.
__________
Rick
MEMBRO LATO OSCURO
69 850 Spider (A fond college days' memory)
81 Spider Veloce
Downstate Illinois SNO Director
radamm is offline
post #3 of 13 (permalink) Old 02-19-2017, 03:53 PM
Alfajay's Avatar
How about a pair of these? See: RB023 SPIDER DOOR SEAL END PLUG - Classic Alfa
Alfajay is offline
post #4 of 13 (permalink) Old 02-19-2017, 06:03 PM
Vintre's Avatar
Those are the plugs that I have. I put a bit of RTV around them and then insert as they tend to get squeezed out with the door closing on them.
Those plugs are also at the other end of the door seal at the top of the windshield. Do you have them there?
Good luck,
Vin
Norseman50 likes this.
Vintre is offline
post #5 of 13 (permalink) Old 02-19-2017, 07:57 PM Thread Starter
lgbalfa's Avatar
Good luck,
Vin
yes i have them up top of the windshield.
i will order 2 more from centerline.
https://www.centerlinealfa.com/catal...ider-door-seal
you recommend i use RTV though?
thanks
lgbalfa is offline
post #6 of 13 (permalink) Old 02-19-2017, 11:55 PM
spiderserie4's Avatar
when you close the door the air inside the seal tries to pop those stoppers out (and you lose them), so a dab of sealant helps (or spot of superglue).
door seals should have air holes, some aftermarket don't.
on the other end (windshield) there is a rubber plug that first goes inside the seal then the stopper.....probably helps stop leaks in that corner!
spiderserie4 is online now
post #7 of 13 (permalink) Old 02-20-2017, 04:50 PM Thread Starter
lgbalfa's Avatar
thanks for the reply back and the diagram.
i'll try RTV or superglue.
i'll see what i have im the house.
thank you.
lgbalfa is offline
post #8 of 13 (permalink) Old 09-01-2017, 11:29 AM
never lose another door seal plug!
just updating this:
I have lost so many seals that popped out without me noticing, and at 5 bucks each it was getting on my nerves! Especially the ones at the door shut. The ones at the windscreen kind of slip a little under that plastic end cap.
Once I glued them (the door ones) in with a real strong contact glue....you guessed it...they still popped out, but this time tore a freakin bit of the door seal with them
As I recently replaced my door seals, I bought a length of 9mm closed cell neoprene sponge cord....like this:
Closed Cell NEOPRENE SPONGE CORD Foam Rubber 3mm, 5mm, 6mm, 7mm, 8mm, 9mm, 10mm | eBay
This fits exactly into the plug. You glue the plug onto this (contact glue), Then insert say 6 inches or whatever length you want of the neoprene cord, with the plug glued onto the end, into the door seal (both at windscreen and at door end, spray talc helps if you choose a long length to perhaps fill out the seal)....now they sit just where they ought to......and if they ever tried to pop out, I'd notice them dangling on the end of a length closed cell cord
So, yes, basically following the little diagram I posted above from the alfa book (They were paid for a reason, the alfa designers!)
Edit: oh, and an added bonus... it prevents them from deforming too, as the closed cell cord keeps the shape a lot better than a hollow bit of rubber!
(sorry, only poor phone photos)
alfabeach, Vintre, Shakey and 1 others like this.
post #9 of 13 (permalink) Old 09-02-2017, 03:01 PM
Gee, I've only had this problem for 50 years ('67 Duetto). With a sharp x-acto knife, put a slit in the plug. The air pressure will blow thru this and keep the plug in place.
Robert
60sRacer is online now
post #10 of 13 (permalink) Old 09-03-2017, 12:56 AM
John533i's Avatar
My door wouldn't even close with the plug in place, so I leave them out. It just banged on the hard plastic plug.
86 spider Veloce
74 TR6
John533i is offline
post #11 of 13 (permalink) Old 09-03-2017, 02:20 AM
yes a slit would work I suppose
there is on the other hand an added use for the foam insert coil, at least at the windscreen end.....it helps seal the top part, which according to the soft top manual is sometimes a source of leaks. The manual recommends a 5" length.
If the door will not close with just the hollow rubber plug, there is something not right and my guess would be the window tracks are raked too far inwards....(rake can be adjusted with the two 10mm bolts at the bottom)
post #12 of 13 (permalink) Old 09-03-2017, 07:10 PM
John533i's Avatar
I got my plugs from Mr. Fiat two years ago, along with a door seal. The plug prevents the door from latching. The seal was s h i t and has worn worse than the original passenger side, where it curves around to the floorboard from the b post. The foam just tore away. Price you pay for 'in the ballpark' parts, I guess.
86 spider Veloce
74 TR6
John533i is offline
post #13 of 13 (permalink) Old 09-04-2017, 04:27 PM
WithanF's Avatar
Thanks to this thread I discovered I was supposed to have a plug. I don't. I never will. Not sure I see the need.
The top of my door gasket is folded under the trim at the top of my windshield. Not sure if that's OEM, but it works.
It is a fierce, piercing shade of yellow, aglow with passion and defiance,
vibrating with the energy of a thousand suns, of thunder at dawn.
Have - 93 Spider Veloce (2006)
Had - 86 GTV-6 (1987-2006)
WithanF is offline
