82 Spider won't start - Alfa Romeo Bulletin Board & Forums
 6Likes
  • 1 Post By ghnl
  • 1 Post By mghamms
  • 1 Post By mghamms
  • 2 Post By 65Sprint
  • 1 Post By sgweiner
post #1 of 11 (permalink) Old 11-23-2016, 11:08 AM Thread Starter
I'm hoping one of the electrical gurus on the BB can help me.
1982 Spider (fuel injected)
Battery is fully charged. When I turn the key one click everything works (light, radio, etc). When I turn it further to start the engine, there is a brief click from the engine bay and then it all dies. Nothing works again unless I disconnect and reconnect the battery, and then I can start over.
I just did a full service (new fan belt, new radiator fluid, change oil, gear oil, muffler, fuel filter) so I was messing around with lots of places on the car, but everything looks like it's all attached. I can push it and it turns. Since the electrics come back when I disconnect and reconnect battery it doesn't appear to be a fuse.
Any tips appreciated (before it snows!!)
Scott
'82 Alfa Spider Veloce + '74 Fiat X1/9 + '10 Mazda RX-8 GT
sgweiner is offline
post #2 of 11 (permalink) Old 11-23-2016, 11:55 AM
BB Janitor
ghnl's Avatar
My guess is the ignition switch is on its way out. The internal contacts wear/get burned with years of use until they finally no longer allow electrons to pass.
Since the switch is both expensive and difficult to R/R, try a few easier/cheaper things first. The most important is to be sure all electrical connections are 100%. Don't assume - remove, clean & secure all connections in the battery to starter circuit (including the ground cable's connection to the body) and the connections for the ignition switch.
Connect a voltmeter to the battery and see what it reads. With everything off a fully charged battery should show 12.6V. Then see what it reads when you turn the key to 'start'. If there is a significant drop then either the battery has failed or the starter motor is failing.
sgweiner likes this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #3 of 11 (permalink) Old 11-23-2016, 12:08 PM
Bad starter solenoid?
May be sticking closed.
Disconnecting battery opens?
Find the click in the engine bay. all I can think on is the starter.
mghamms is offline
post #4 of 11 (permalink) Old 11-23-2016, 12:11 PM Thread Starter
Grrr- another mystery without an answer
After posting, I went back to the garage and tried a few more times - nada. it sounded like the click was from the starter. Then, I turned on the lights, left them on, and cranked and it turned right over. Why in the world that would work beats the heck out of me.
Thanks for the suggestions - if it happens again I'll check those things.
sgweiner is offline
post #5 of 11 (permalink) Old 11-23-2016, 12:16 PM
may be a week battery.
charge it up or replace if old.
lights on gets the battery warmed up.
but i would think you would have to shut em off to start.
anyhow you running.
mghamms is offline
post #6 of 11 (permalink) Old 11-23-2016, 06:43 PM
65Sprint's Avatar
I suspect you have a ground problem. Check the battery ground first, including the connection to the chasis.
sgweiner and John533i like this.
Rich Hanning
65Sprint is offline
post #7 of 11 (permalink) Old 11-25-2016, 04:58 PM
spidryell's Avatar
I also think it sounds like a ground issue. I would check the braided ground strap under the car. Is it there? Remove it and clean both ends and clean the connection points on the engine and the body before putting it back on.
When you check the main battery ground cable make sure to wiggle the terminal ends to see if one is loose or corroded. Mine was suspect so I replaced my cable. NAPA actually had a cable that was the same gauge and length. Had to find a worker that is willing to look in the back like the old days vs looking in the computer. Part number was 711631. Approx $18
spidryell is offline
post #8 of 11 (permalink) Old 04-10-2017, 06:39 PM Thread Starter
Well, 5 months after the last post, I just wanted to conclude with the solution, in case it helps another knucklehead like me. I pushed the car to the side of the house to store it for the winter and just got it our again as we had our first >70 degree day in Boston and the snow has *finally* all melted. I kept focusing on the starter because the accessories would work in the first position but when I clicked to turn it off it would all just die. I installed a starter relay (pretty easy to do - happy to provide tips if anyone is confused by what 30/85/86/87 mean). It still did the same thing.
I went to test the battery as I always have, but putting my voltmeter to the posts of the battery - it read normal/well-charged. Then, by accident, I touched the battery ground cable instead of the post and, sure, enough, the volts dropped to 7. So spidryell was right - it was corrosion (barely even visible) on the main battery ground cable. What happened was that it was enough to power the accessories, but when the starter engaged the whole thing just shut down. A little sandpaper cleanup and now it's all working again.
So the lesson:
- When testing the strength of your battery to diagnose electrical issues, measure at the cable end and not at the battery terminal. Thanks, all.
ghnl likes this.
sgweiner is offline
post #9 of 11 (permalink) Old 07-02-2018, 06:22 AM
So the lesson:
I am having a similar issue- I cleaned up the ground cable inside the trunk space- is there two ground cables?
evilmnky45 is offline
post #10 of 11 (permalink) Old 07-02-2018, 06:34 AM
BB Janitor
ghnl's Avatar
There are two ends to the battery ground cable - the terminal at the battery* and where it is bolted to the body - sort of behind the battery & out of view. There is also a ground strap connecting the bellhousing to a tab in the transmission tunnel (underneath the car). All those connections should be cleaned & secured - don't assume they are good because they look OK.
*if the battery's ground connection has been replaced with a bolt-on clamp, be suspicious of that. They are temporary repairs for a corroded cable clamp.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is offline
post #11 of 11 (permalink) Old 07-02-2018, 07:22 AM
Interesting. I would have never thought that. I cleaned the car one and put dielectric on it. Was nasty, but did not fix the starter and electric drain issue. Ill take a look for the ground strap today. on the passenger side?
