Duetto (1600) Cooling water lines routing - Alfa Romeo Bulletin Board & Forums
post #1 of 9 (permalink) Old 11-20-2016, 04:41 AM Thread Starter
All,
I need to refurbish my Heater box and all associated hoses in my 1967 Duetto. The hoses connected to the heater box are most likely original and the bypass tube from the main supply line to the engine has been rubbing against the intake manifold.
As the hose is now rubbing against the inlet manifold I need to move the t-piece to a better place. I was thinking of putting it further in the line against the scuttle line.
Does anyone have some pictures of how it should be routed and where I should place the t-piece?
Jeroen
1967 Alfa Romeo Spider 1600
Jeroen76 is offline
post #2 of 9 (permalink) Old 11-20-2016, 06:52 AM
Dr.G's Avatar
Your positioning looks correct. Do you have it secured under the two metal folding tabs and are your motor mounts solid enough to keep the motor rocking under control? It might also be a a section of hose is a bit long, or short, making it rub.
Nice looking engine bay. Very original looking. Get yourself some crossover clamps for your crossover hose.
Dr.G is offline
post #3 of 9 (permalink) Old 11-20-2016, 07:19 AM
Dr.G's Avatar
I don't know if this original, just how I did it. The metal folding tabs aren't the most secure, my hose pops out and rubs on the white paint.
Dr.G is offline
post #4 of 9 (permalink) Old 11-21-2016, 06:00 PM
not2old4toys's Avatar
Alfa
This is the factory set, the tee fitting is more inboard of the fender wall.
Cheers, Jon
Present:
1967 Spider
1974 GTV (1969 Tribute)
1993 Spider ( project)
2018 Stelvio
Past:
1964 Giulia Sprint. 1966 Giulietta 101 Sprint
1967 Super 1968 GTV 1974 Berlina
1979 Alfetta Mille Miglia 1987 Milano
Non Alfa:
1953 MGTD 1958 TR3 1962 AH 3000 MKII
1969 AMX
not2old4toys is online now
post #5 of 9 (permalink) Old 11-22-2016, 12:59 PM Thread Starter
Dr G, Jon,
Thanks for the pictures. I see that the t-piece indeed needs to be closer to the wall - That was the solution I was thinking of.
I guess the cw lines were replaced at some point in time. Yesterday I found that the small 90degree was definately NOT replaced since 1967.
Jeroen
Jeroen76 is offline
post #6 of 9 (permalink) Old 03-14-2019, 04:45 PM
Jon, resurrecting this thread...you noted in your photo of the cooling lines for the 1600 Duetto that they were original. Are those the original hose clamps? Do you by any chance know the name/style of clamp? If so, do you know if they are still available.
Adam
c17troll is offline
post #7 of 9 (permalink) Old 03-14-2019, 05:57 PM
Adam
The clamps are original. Brevetti is stamped on the metal .. 24 mm.
I have seen them for sale on occasion but I'm not sure they are still being made. Try running a "wanted" in the classified section.
Cheers, Jon
Present:
1967 Spider
2018 Stelvio
Past:
Non Alfa:
1969 AMX
post #8 of 9 (permalink) Old 03-14-2019, 07:24 PM
Thanks Jon, appreciate it.
Adam
c17troll is offline
post #9 of 9 (permalink) Old 03-15-2019, 09:41 AM
Cheers, Jon
my '67 hoses look like this photo from Jon's car as well.
markgberry is offline
