92 spider convertible frame arm broken - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By not2old4toys
post #1 of 8 (permalink) Old 10-31-2016, 04:39 PM Thread Starter
Hi I have a 1992 spider and the lower arms have broken off the mounting brackets. It looks like the arms are intact it is the mounting bracket itself that is broken. Does anyone know where I can get these brackets? I have searched the Internet without luck. Looks like a parts car is the way to go. The brackets are bolted to the car with two bolts and a nut. I need both the driver and passenger side. I took it to a welder but he doesn't athink he can line it up properly to get a strong enough weld. I don't have a garage and I can't get the top up. Help! Thanks. Tom
Chifty is offline
post #2 of 8 (permalink) Old 10-31-2016, 05:21 PM
not2old4toys's Avatar
I have a couple complete and one parts frame. Send a photo and I can probably come up with what you need. FYI frames 71-94 are the same.
Cheers, Jon
Present:
1967 Spider
1974 GTV (1969 Tribute)
1993 Spider ( project)
2018 Stelvio
Past:
1964 Giulia Sprint. 1966 Giulietta 101 Sprint
1967 Super 1968 GTV 1974 Berlina
1979 Alfetta Mille Miglia 1987 Milano
Non Alfa:
1953 MGTD 1958 TR3 1962 AH 3000 MKII
1969 AMX
not2old4toys is online now
post #3 of 8 (permalink) Old 10-31-2016, 05:40 PM Thread Starter
You are awesome. I will take a pic in the morning and include it. Thanks.
Chifty is offline
post #4 of 8 (permalink) Old 11-01-2016, 03:02 AM
spiderserie4's Avatar
Tom,
am I right in guessing it is this bracket you are talking about?
(one on each side, handed I'd guess)
http://www.alfabb.com/bb/forums/7135138-post9.html
spiderserie4 is offline
post #5 of 8 (permalink) Old 11-01-2016, 06:02 AM Thread Starter
Yes that is it exactly
Chifty is offline
post #6 of 8 (permalink) Old 11-01-2016, 08:09 AM
they are basically part of the frame mechanism.....OK you could drill out the huge rivets, but it is not going to be an easy job with the soft top on the car...methinks (I wonder if you undo the 3 bolts on each side, if that part of the frame might swing up to allow you access?....but if the frame needs to come off, you have to undo all those little nuts at the rear, job gets bigger and bigger).....then you need to replace the huge drilled out rivets with something appropriate.
(a perfect photo courtesy of a fleabay seller to illustrate the problem)
post #7 of 8 (permalink) Old 11-01-2016, 08:16 AM
Frame
Dom is right. Not sure how you can replace the drift rivets. I think you are better off replacing the entire frame. If you pay shipping from 97229 I will ship you one. You will have to clean it up.
Cheers, Jon
ossodiseppia likes this.
Present:
1967 Spider
2018 Stelvio
Past:
Non Alfa:
1969 AMX
post #8 of 8 (permalink) Old 11-01-2016, 09:30 AM Thread Starter
That sounds like the best solution. Very generous of you. If you can let me know the cost I will gladly send it via PayPal if that works for you. Thank you again. Just the fax @ Comcast . Net
Chifty is offline
