crankshaft nut torque. - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 08-03-2016, 05:30 PM Thread Starter
hi,am trying to find out the correct torque for the front crankshaft nut ,i've read few post and they make it a litle more confused some say 120 ft other 140 ft ,can somebody clarify it for me please.
Thks. by the way it's the 85 Quadrifoglio
giorgiofrette1 is offline
post #2 of 10 (permalink) Old 08-03-2016, 06:19 PM
Alfajay's Avatar
My manual says 70 - 72 ft-lbs for a 2L. 140 sounds very high.
'63 Guilia spider
Alfajay is offline
post #3 of 10 (permalink) Old 08-03-2016, 06:31 PM
Vintre's Avatar
The Engine Overhaul manual I have for 2.0L engines, model years 1982 - 1991 says
Name:  Torque specs.jpg
Good luck,
Vin
Vintre is offline
post #4 of 10 (permalink) Old 08-03-2016, 06:52 PM
Andrew's Avatar
Non-Spica are like 80, Spica are like 140.
Andrew
Andrew is offline
post #5 of 10 (permalink) Old 08-03-2016, 07:21 PM
not2old4toys's Avatar
Vintre figures are correct from Spider shop manual
My old Shankle( which is indispensable) shows 140 on 2L up to 1978( last printed year?)
and 87 ft lbs on 1300 and 1600
Cheers, Jon
Present:
1967 Spider
1974 GTV (1969 Tribute)
1993 Spider ( project)
2018 Stelvio
Past:
1964 Giulia Sprint. 1966 Giulietta 101 Sprint
1967 Super 1968 GTV 1974 Berlina
1979 Alfetta Mille Miglia 1987 Milano
Non Alfa:
1953 MGTD 1958 TR3 1962 AH 3000 MKII
1969 AMX
not2old4toys is offline
post #6 of 10 (permalink) Old 08-03-2016, 11:06 PM
hunttheshunt's Avatar
You guys don´t forget that all the works data are just referring to a specific thread size ?
There are at least 3 DIFFERENT sizes possible; have a look here:
http://www.alfabb.com/bb/forums/engi...shaft-nut.html
Depending on the crank type/thread size in a specific car, the highest torque range is eventually way too high and will be followed by a cracked pulley boss soon.
Tell me which thread size´s in your engine and I can provide you with the correct torque figure for that.
It´s presumably correct that a 85´ engine needs the torque listed in Vintre´s sheet, but what if somebody replaced the crank or the engine to an earlier spec ?
hunttheshunt is online now
post #7 of 10 (permalink) Old 08-04-2016, 06:09 AM
I've heard of a few cracked pulleys and I presumed that they were due to mishandling or a manufacturing defect but I can see now that it could be due to confusion regarding nut torque. Is there a downside to using the lower setting on the bigger thread if you use loctite on the threads?
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is offline
post #8 of 10 (permalink) Old 08-05-2016, 01:52 AM
Ed,
meanwhile I´m using the lower torque setting (85 ft-lbs) for all three thread sizes in combination with some Loctite and never had any self-loosening issues (as long as one doesn´t reuse a cracked one). Only with a late double or triple groove pulley in combination with the biggest thread size I´m going to the high torque setting in Vintre´s list (140 ft-lbs).
Cracking issue occurs in my opinion mainly from either using wrong torque figure and/or using an air impact tool for tightening. Unscrewing with impact tool is ok, but never tightening. Cracks are always aligning following uncontrolled axial compression with air tools.
The biggest thread size (M26) can easily be identified as it´s the only one which has the same dia. as the rest of the crank body following the thread area. Both smaller threads are smaller in dia. and not in same line with the following area.
D.
post #9 of 10 (permalink) Old 07-11-2017, 10:23 AM
jclark's Avatar
And what is meant by 'wet'? Water ( most common use of term )? Oil ( what kind )? Dish soap ( hey, it gets wet too! )?
And what about the big concave washer? Concavity facing tailpipe, or the front of car?
And that washer has a small cutout - looks like it maybe had ( past tense ) a little tab that has over the years gotten lost/broken off - prolly originally used to bend over the large nut to keep it from backing out? Is it necessary to put new one in? Do fresh ones exist?
Inquiring minds, etc.
jeff
1982 Spider Veloce
1999 BMW R1100S
jclark is offline
post #10 of 10 (permalink) Old 07-04-2019, 08:59 AM
IRONBLOCK's Avatar
Old thread...wet usually refers to oil on the threads or in the case of head nuts and studs where they get re-torqued a few times; anti-seize compound for me.
The big concave washer in the crank pulley has a 'slot' for the key way on the crank shaft, like a Woodruff key. Not a tab washer, although the washer itself can be bent over a flat on the nut to keep it in place.
Mark
IRONBLOCK is online now
