The "Proper" Grease? - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By GV27
post #1 of 8 (permalink) Old 06-13-2016, 01:52 PM Thread Starter
I am in the process of rebuilding the suspension on my 86 spider and I have few questions pertaining to grease. I looked in the shop manual and there are mention of a few greases there but I was thinking 30 years have passed and surely there must be better grease out there?
I apologize if this answered somewhere but I searched and did not really come up with any answers.
What kind of greases should I use and where?
Is this question just as subjective as "what oil should I use"?
Use lithium based grease on or near poly bushings... right?
What is the best grease for items around rubber bushings?
Use synthetic?
Here is a list of items that I tackling in the rebuild:
1) Prop shaft
2) Front suspension (poly is used in certain places)
3) Rear Suspension.
4) Steering Idler
phillipah is offline
post #2 of 8 (permalink) Old 06-14-2016, 04:32 PM Thread Starter
really... no opinions?
post #3 of 8 (permalink) Old 06-15-2016, 06:39 AM
whatever the book calls for in propshaft is fine - or go synthetic.
none of the others require grease, except for the poly parts - which hopefully came with grease for install.
barbone105 is offline
post #4 of 8 (permalink) Old 06-15-2016, 09:54 AM Thread Starter
The poly bushings did come with grease. I used the packs that came with them. I was thinking they might need greased again a few months down the road.
The lower control arms had grease when i pulled them apart. I would assume that those would need to be repacked again... correct?
post #5 of 8 (permalink) Old 06-15-2016, 08:30 PM
John533i's Avatar
My rear poly trailing arm bushings on the driver's side need greasing again after last years install. Irritating.
86 spider Veloce
74 TR6
John533i is offline
post #6 of 8 (permalink) Old 06-15-2016, 08:33 PM Thread Starter
That is unfortunate. That is what is I am trying to avoid. After a bunch of research I found something called formula 5 that seems to be exactly the same of what is provided with the Poly bushings.
Supposedly it works well
Energy Suspension 9.11104 Formula 5 Prelube Grease - 8 oz. https://www.amazon.com/dp/B000CN7B4I..._e4HyxbHSN0VJ7
post #7 of 8 (permalink) Old 06-16-2016, 06:14 AM
GV27's Avatar
I use that energy suspension stuff. It seems to work great - no squeaks yet. It's SUPER goopy and sticky. Once it's applied it's not going anywhere!
phillipah likes this.
GV27 is offline
post #8 of 8 (permalink) Old 06-16-2016, 10:26 AM
my experience to date, grease once should be fine. use liberally wherever poly touches metal (inside and out). also where poly meets poly (for parts w thrust washers etc).
should be ok.
