A/C compressor shuts off at speed on S3 - Alfa Romeo Bulletin Board & Forums
 1Likes
  • 1 Post By bongju
post #1 of 3 (permalink) Old 06-11-2016, 04:24 PM Thread Starter
My A/C compressor works when idling or at slow speeds (less than 30 mph), but it shuts off at high speed. My mechanic said my alternator is not putting out enough volts to power the compressor; he verified this by connecting a 12 volt source directly to the compressor and it stayed on. I installed a reconditioned BNR 80 amp alternator, but the problem is the same.
Any ideas on what I need to check next?
Kim - 1987 Spider Quadrifoglio (~170K original owner miles)
Huntsville, AL
bongju is offline
post #2 of 3 (permalink) Old 06-11-2016, 06:46 PM
Jim G's Avatar
Ck the ground wire from the engine to the compressor. It a fairly thick wire. The compressed is isolated from the engine due to rubber bushings. There probably sag a little which let it complete the ground circuit at low speeds.
Jim G is online now
post #3 of 3 (permalink) Old 06-18-2016, 03:05 PM Thread Starter
Jim,
I finally set aside a day to do some serious A/C troubleshooting. I decided to start by tracing the wiring. The first thing I found was that the nut that secures the ground wire was missing. Once I replaced it, the A/C works great! Thanks for the suggestion.
rogerspeed likes this.
Huntsville, AL
bongju is offline
