What did you do Alfa Spider related today? - Page 7 - Alfa Romeo Bulletin Board & Forums
 952Likes
post #91 of 1641 (permalink) Old 06-11-2016, 09:08 PM
RenaissanceMan's Avatar
-Rebuilt all 4 brake calipers
-Flushed the fluid/bled brakes
-Replaced burned-out sidemarker bulb
-Replaced faded rear emblem
-Restored connections for license plate lights and reverse lights
John533i likes this.
Adam in Nashville: '72 Alfa Romeo GTV 2000 - '86 Alfa Romeo Spider Veloce - '74 BMW 2002tii - '90 BMW E30/S52 - '05 BMW X5 - '06 BMW 325i
RenaissanceMan is offline
post #92 of 1641 (permalink) Old 06-11-2016, 11:24 PM
Charles Berman's Avatar
Took my Spider for a drive. Needed its heater today - it worked A nice toasty drive!
La meccanica delle emozioni
2016 Giulia Veloce Azzurro
2012 Giulietta 1.4 Grigio
2008 159 ti 2.4 JTD Rosso
1969 Spider Veloce 1750 Avorio
Gone:
1975 Alfasud 1200ti
2006 159 V6 Q4
1971 Giulia 1300 Super Verde
Charles Berman is offline
post #93 of 1641 (permalink) Old 06-12-2016, 08:13 AM
I started the rebuild of my 2L motor. I swapped crankshafts and the "new" one needed a .010" grind on the mains. The old one was damaged when the flywheel bolts sheared. Checked clearance of new main bearings with Plasti-gage. Next job is gapping new Hastings piston rings.
It is too hot to drive an un-air conditioned tin top today so I brewed a batch of beer for my daughter's birthday next month.
alfaloco and RenaissanceMan like this.
85 GTV6 3L
2011 Jaguar XKR
alfaparticle is online now
post #94 of 1641 (permalink) Old 06-12-2016, 08:54 AM
alfaloco's Avatar
Beer is good!
I'm checking over my Spider for the convention trip...about 3-1/2 hours from here. Pack front wheel bearings, found out my A/C needs a new relay (not just a recharge), check T&D lube levels, belt tension etc.
RenaissanceMan likes this.
alfaloco
Lexington, KY USA
alfaloco is online now
post #95 of 1641 (permalink) Old 06-12-2016, 10:05 AM
rabhalter's Avatar
'69 Spider ready for the Convention.
Drove the Spider to church this AM but had to put the top up for fear of messing the spouse's hairdo. Last week I prepped for the Convention trip by having the wheels balanced, bleeding the brakes, replacing the window rubber seals and the T-bar spacers.
alfaloco likes this.
Bob A.
Kenosha, WI
rabhalter is offline
post #96 of 1641 (permalink) Old 06-12-2016, 06:41 PM
esc2064's Avatar
I struggled all day from 7-5pm trying to put back the passenger side power window cable back in its place and still have not succeeded. What a waste day.�� I can't seem to get the proper length set right for both the up and down.
esc2064 is online now
post #97 of 1641 (permalink) Old 06-13-2016, 04:40 PM
-oil change
-repaired intermittent power window switches
-bled brakes (again)
post #98 of 1641 (permalink) Old 06-13-2016, 04:45 PM
xjspider's Avatar
Started cutting out the rusty pieces today. The garage floor is now brown with rust particles.
76' alfa spider
85' jaguar XJ6
xjspider is offline
post #99 of 1641 (permalink) Old 06-13-2016, 06:05 PM
Gapped my new Hastings piston rings to .015" compression and .013" scraper. I used the flat side of a Dremel cut-off disc to grind the ends of the rings and a piston to push them square into the liner for measurement. They had zero gap before adjusting. My parts package arrived from Classic Alfa. I had to stay in all day because i had to sign for it. Installed one set of rod bearings and verified clearance with plasti-gage. I should be able to make progress now. I am thankful that I installed air conditioning in my garage last year.
85 GTV6 3L
2011 Jaguar XKR
post #100 of 1641 (permalink) Old 06-14-2016, 10:18 AM
I called Hagerty. Not comfortable that my good neighbor is the one for my Alfa.
1991 Spider Veloce
1977 Rolls-Royce Silver Wraith II
Susan is offline
post #101 of 1641 (permalink) Old 06-14-2016, 01:05 PM
Engine rebuild continues. Installed pistons & rods, timing gear, oil pump, front cover. Chains, rings, bearings & seals are new.
The head is already prepped so I may be able to finish the job tomorrow.
RenaissanceMan and Norseman50 like this.
85 GTV6 3L
2011 Jaguar XKR
post #102 of 1641 (permalink) Old 06-14-2016, 01:38 PM
Vivace's Avatar
You are cranking!
I got this far last night...
1967 1600 Spider
Vivace is offline
post #103 of 1641 (permalink) Old 06-14-2016, 02:21 PM
Is that an adjustable spring pedestal?
85 GTV6 3L
2011 Jaguar XKR
post #104 of 1641 (permalink) Old 06-14-2016, 04:56 PM
Vivace's Avatar
When I stripped it, it turned out to be a aluminum "puck" in the center of the spring. I assume the upper rubber bump stop hits it. Attaches with a single bolt through the bottom of the spring pan. Is this unusual?
1967 1600 Spider
Vivace is offline
post #105 of 1641 (permalink) Old 06-14-2016, 05:33 PM
Jim G's Avatar
No. Thats what the 1600 Duetto's had.
Jim G is online now
