Help with rear sway bar bushing removal - Alfa Romeo Bulletin Board & Forums
post #1 of 10 (permalink) Old 02-13-2016, 02:49 PM Thread Starter
Alfamiles's Avatar
I have the rear swat bar out and drilled the rubber to remove the end link. Now, I cannot remove the inner metal section of the old bushing.
I have it in a vice. I have tried vice grips twisting as well as hammering.
Any ideas?
Alfamiles is offline
post #2 of 10 (permalink) Old 02-13-2016, 02:58 PM
Heat - MAP gas is a good choice. Get it red hot.
gprocket is offline
post #3 of 10 (permalink) Old 02-13-2016, 03:46 PM Thread Starter
Alfamiles's Avatar
Ok. I will try that!
post #4 of 10 (permalink) Old 02-13-2016, 04:40 PM
ARwrench's Avatar
Location: Transplanted from Holland to The Armpit of New Jersey
Gently cut/split it in half.
“If you can't explain it simply, you don't understand it well enough”
Oo--V--oO There is a fine line between "Hobby" and "Mental Illness".
ARwrench is offline
post #5 of 10 (permalink) Old 02-13-2016, 05:05 PM
Vintre's Avatar
I used a pair of locking pliers and then knocked it off using a hammer.
Worked for me.
Good luck,
Vin
Vintre is offline
post #6 of 10 (permalink) Old 02-14-2016, 08:30 AM
GTA ALFA's Avatar
I recently removed the same, gently cutting down the length and pulling it out with a vice grip.
Anthony
72 GTV, 72 GTV (Sold), 74 Berlina (Project), 72 Spider (Sold), 76 Spider (Sold), 70 GTJ
GTA ALFA is offline
post #7 of 10 (permalink) Old 02-14-2016, 05:45 PM Thread Starter
Alfamiles's Avatar
Got it done. Thanks.
post #8 of 10 (permalink) Old 02-14-2016, 06:57 PM
Vintre's Avatar
Nice!
Glad you got it done.
Vin
Vintre is offline
post #9 of 10 (permalink) Old 02-18-2016, 07:31 PM Thread Starter
Alfamiles's Avatar
Ok. New bushings arrived today and just slide on the bar and don't stay put. I read the other thread about welding a washer, but I don't have a welder. If I buy the poly instead does that solve the problem? Easier install?
post #10 of 10 (permalink) Old 02-19-2016, 05:48 AM
You've got the same problem as many of us have experienced. Thanks to this forum I found the solution of mounting those bushings using loctite (I think it was Loctite 638).
NielsP90 is offline
