Aiuto! - Page 3 - Alfa Romeo Bulletin Board & Forums
 2Likes
post #31 of 34 (permalink) Old 11-08-2015, 01:52 PM
Push hard and live
DPeterson3's Avatar
Originally Posted by dondavis View Post
Don, battery voltage is fine, 12.5+ volts. Just came off a long multi-day trickle charge on Saturday...
(your signature reads like a "who's who" of Alfas!)
Yeah, I was surprised when I compiled that list several years ago. I never set out to be a ceazy person. It just happened.
To the voltage question...
The critical part is that your ECU is getting a full 12V, or something close. Find the main power feed to the ECU, and measure the voltage while someone is cranking the engine. I don't remember what the lower limit is, but suspect if you're seeing less than about 10.5V, then you've got either a bad cell in the battery, or resistance somewhere in either the B+ or your ground.
It is possible for a battery with a bad cell to show 12V+, until a load is put on it and the high internal resistance knocks it down.
Don P
Carson City, NV
Past Alfas...
Current Alfas
Oops. Add to the "present" list, 10204 01488, 2000 Touring Roadster project
And past...
1946 Luscombe 8A
And present...
64 Mooney M20E ("Rambo". My faithful steed for over 40 years) Over 55 years old, and just returned from a trip to Argentina in him
Newest in the fleet
2010 Triumph Thunderbird
DPeterson3 is offline
post #32 of 34 (permalink) Old 11-08-2015, 02:01 PM
spiderserie4's Avatar
Originally Posted by spidryell View Post
Don, I reread your last post. Did you measure voltage with one multimeter lead on + terminal of coil and the other to the engine block or did you measure across the terminals of the coil. You should be measuring the first way.
I think he did it correct (as long as ignition switch was on!), earlier he mentioned "I've measured voltage between coil + and body/engine. Zip."
Don, have you checked actual voltage when cranking as Spidryell suggested earlier? This needs to be about 10.5V before the ECU will awake. Because the battery is newly charged, does not mean the crank voltage is adequate. You need to check this before proceeding.
If cranking voltage is good, then move on and check what was suggested in post #22 (again by Spidryell)
Edit: ....as DonP just said!
spiderserie4 is offline
post #33 of 34 (permalink) Old 11-08-2015, 02:09 PM Thread Starter
FINALLY. I had to brush off my book of Italian bestemmie for that one.
The hot-side connector behind fuses 6-8 was plugged into spots 7-9, thus depriving the dreaded black/green wire to coil + of it's 12v. I must have put it back there because the connector has a notch in it and it fit. Moved it over by 1 and the car fired right up. Thanks all, and most of all to Papajam's excellent wiring diagrams.
Many thanks for everyone's suggestions and help, now I can finish putting the interior back together.
@donp, I wish I'd compiled a list of all the cars I went through while I lived in Italy '82-'98. I think it was 24 or 25 cars, some only kept a short while. The dollar was so strong against the lira back then. Most memorably, a BMW 3.0csi (still the most elegant of coupes, IMO), a 2002ti (absolute joy to drive), Alfa75 QV (lovely 3-liter V-6 which really screamed), Saab 9000CDE (2-liter turbo that would do 140mph in great comfort), several Giulias (all of which were cheap, fun and fast), a Fiat Panda (a fantastically simple and reliable little car) and not least, a 500. (I've always lusted after the Interceptor, how is it?)
@spiderserie4, "DANKE und tscheuss!" Obviously, voltage was fine once I pulled my head out and got my wires connected the way they were supposed to be.
@Norseman50 , thanks Edward for always being willing to help, you're one of the jewels here on the boards.
Don
Don Davis
Woodbridge, VA
1986 Spider
dondavis is offline
post #34 of 34 (permalink) Old 11-08-2015, 02:50 PM
spidryell's Avatar
Great!! Always feels good when you get them running after beating your head on a problem.
spidryell is offline
