Sudden loss of power - Alfa Romeo Bulletin Board & Forums
 2Likes
  • 2 Post By ghnl
post #1 of 9 (permalink) Old 09-20-2015, 08:25 PM Thread Starter
saniei's Avatar
This has happened couple of times now, when I'm driving the car and all of the sudden I loose the power and the car comes to full stall because of the lack of gas. The car is running and I'm pushing the gas but no power until it dies slowly! After which starts right away with no issues and runs fine! I hate to see it happen in the highway! Thanks for helping!
saniei is offline
post #2 of 9 (permalink) Old 09-21-2015, 05:01 AM
I had a similar problem as the car would suddenly lose power I would coast to a stop then it would start back up.
I my case it was the ignition switch. To get to this conclusion The mechanic replaced the TA on the Spica FI. both fuel filters none of which was a fix. Replacing the ignition was the cure.
konati is offline
post #3 of 9 (permalink) Old 09-21-2015, 06:37 AM
BB Janitor
ghnl's Avatar
The picture in your avitar makes me assume a Series 3 Spider - correct?
One clue as to whether the problem is lack of fuel or spark is to note what the tach needle does when it happens. The tach gets its signal from the coil. If the tach needle drops right away (to its rest stop at ~ 500 rpm) then the problem is ignition related. If the needle drops slowly as it dies then problem is likely lack of fuel.
That doesn't directly tell you what the problem is but it will help focus the investigation. That it will start again (right away?) it seems more likely an electrical problem. It could be a faulty ignition switch, loose electrical connection, etc.
saniei and Norseman50 like this.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is offline
post #4 of 9 (permalink) Old 09-21-2015, 03:43 PM
miami592's Avatar
Check your fuel filter and fuel pumps (both). Crud in the system will give you those symptoms and they won't improve anytime soon.
Jeff
1989 Graduate S3
miami592 is offline
post #5 of 9 (permalink) Old 09-21-2015, 05:25 PM Thread Starter
saniei's Avatar
Thanks all!!
saniei is offline
post #6 of 9 (permalink) Old 09-21-2015, 07:03 PM
gtrmrk's Avatar
My S3 does something similar when the fuel tank goes below one-half full. Can this be an in-tank fuel pump/filter issue? Car runs fine when tank is full.......
gtrmrk is offline
post #7 of 9 (permalink) Old 09-21-2015, 07:21 PM
I have an '83 with the Bosch FI. I hade a similar problem a few years ago and it turned out to be a bad sensor. The sensor is located on the fly wheel. There are two them, one I think is a speed or RPM sensor the other is sensor is used as a reference point of some kind, but don't quote me this happened about ten years ago. It is an easy check with a multi meter. Just check the site for info. Someone did a write of how to check these components.
Spike is offline
post #8 of 9 (permalink) Old 09-21-2015, 08:24 PM Thread Starter
saniei's Avatar
Thanks! Those sensors have checked out ok!
saniei is offline
post #9 of 9 (permalink) Old 09-21-2015, 11:55 PM
spiderserie4's Avatar
sounds like a classic symptom of the in tank pump "stepped hose". When it cracks or leaks the pump pulls in air when gas is below half level. When tank is full the hose is submerged and works sorta normally...
remove pump and check hose (if replacing use only submersible fuel hose)
http://www.alfabb.com/bb/forums/970380-post3.html
spiderserie4 is online now
