Instructions: installing hard top (old style for 115) - Alfa Romeo Bulletin Board & Forums
post #1 of 12 (permalink) Old 08-26-2015, 08:17 AM Thread Starter
I'm struggling to find good instructions / pictures showing how to install the hard top. My car's an 83 and I just bought a top because it was a great deal, included the latches, stand, etc. All for $80.
Probably needs some new seals but I'll deal with that.
This style of hard top is not the same as the one that came later.
Can you point me in the right direction?
jckevin is offline
post #2 of 12 (permalink) Old 08-26-2015, 09:59 AM
rogerspeed's Avatar
assuming the ht has a tab sticking out inward near the base of the "B" pillar, you need some kind of "J" hook with a nutted shaft to grab the convertible top mech at its mounting pivot.
current:
84 Spider Veloce
ex:
rogerspeed is offline
post #3 of 12 (permalink) Old 08-26-2015, 10:01 AM
86spider's Avatar
Is it a factory top or Parrish Plastics/Smoothline. If the latter, give them a call. A couple years ago they still had rear window and gasket to repair an old PP top.
86spider is offline
post #4 of 12 (permalink) Old 08-26-2015, 11:03 AM Thread Starter
It is a factory hard top -- made by Alfa Romeo. It has two J-Hooks and the windshield clamps.
I'm just not sure where you hook the J-Hooks.
And do you do something with the chrome strips by the trunk?
jckevin is offline
post #5 of 12 (permalink) Old 08-26-2015, 12:30 PM
Norseman50's Avatar
Hi jckevin,
You will need two people need to lower the rear of the hardtop onto the chrome strips on the rear deck and then slide it forward so you can secure the J-hooks on the inside base to the folded convertible frame and the windshield hooks onto the top of the windscreen frame.
Edward
'88 Quad - "Claudia"
Norseman50 is offline
post #6 of 12 (permalink) Old 08-26-2015, 12:33 PM Thread Starter
Uh oh! I guess I need to find those clips! Ha ha
Time to start grousing around
Thanks for the post!
jckevin is offline
post #7 of 12 (permalink) Old 08-26-2015, 01:21 PM
Vintre's Avatar
Originally Posted by Norseman50 View Post
Hi jckevin,
This post (courtesy of Vintre) has some good pictures of the black Plastidip-coated clips you need to install on top of the chrome strips on the rear deck of your car, and the direction in which those clips should be oriented:
http://www.alfabb.com/bb/forums/spid...ml#post6378913
Once you have the clips mounted, two people need to lower the rear of the hardtop onto the chrome strips and then carefully slide it forward against the black clips before securing the inner J-hooks to the convertible frame and the windshield on the inside of the cabin.
I think you will find in that thread that the clips I show are for 1986 and on.
I believe your hardtop does not use them.
Good luck,
Vin
Vintre is offline
post #8 of 12 (permalink) Old 08-26-2015, 01:42 PM Thread Starter
Right on!
Any advice on where to buy replacement seals for this style? I think IAP has some or all of the seals.
And there's a place in Italy that does. afra.it
jckevin is offline
post #9 of 12 (permalink) Old 08-26-2015, 02:03 PM
Norseman50's Avatar
Good luck,
Vin
Really? The 1983 Spider does not have the same chrome strips mounted on the rear deck?
News to me. When I purchased my '88 Spider, it came with an old Series 2 hardtop mounted using those same black clips installed on the chrome runners.
Edward
post #10 of 12 (permalink) Old 08-26-2015, 02:06 PM Thread Starter
the 83 does have those chrome strips but maybe you don't need to use the clips?
anyway, assume that I do need them, can they be purchased anywhere? I haven't looked yet having just purchased the top on Sunday.
jckevin is offline
post #11 of 12 (permalink) Old 08-27-2015, 12:41 AM
spiderserie4's Avatar
....if your hardtop does not have the corresponding metal tangs bolted under the 2 rear corners like the later hardtop has, then those black clips shown in Vince's thread will be of no use whatsoever.
Looking at the photo below (courtesy BB) of the original early alfa top, they don't.
Nor can I see them here:
http://www.alfabb.com/bb/forums/6387449-post5.html
Here, you can see that if those clips were mounted on the forward screw of the chrome runners (as designed) they'd just be sitting there, doing sweet....uhmm...nothing
http://www.alfabb.com/bb/forums/254385-post2.html
The Parrish tops had a tang an the back that screwed directly on to the chrome strip, as did the german Körbler "Targa" top.
I wonder, therefore, if the older 'original alfa-branded' top used rear fastenings at all?
spiderserie4 is offline
post #12 of 12 (permalink) Old 08-27-2015, 01:19 PM
Norseman50's Avatar
Have you tried del priore?:
http://del-priore.com/shop/index.php...tegorie&cat=23
Edward
