-   Spider - 105 & 115 Series (1966-1994) (https://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/)
-   -   1982 Alfa Romeo Spider Veloce Trunk Release Cable Broken away from the latch (https://www.alfabb.com/bb/forums/spider-105-115-series-1966-1994/429209-1982-alfa-romeo-spider-veloce-trunk-release-cable-broken-away-latch.html)
nick11179 07-02-2015 01:42 PM
Need help...
Today when changing the battery out and closing the trunk, the release cable broke. I went to open it this AM and the latch has no resistance. Pulled off the panel and the cable is still attached so it's somewhere between the trunk and were I can't see... How do I go about opening the trunk now? I would like to do it without destroying too much... just had her painted.
Alfajay 07-02-2015 01:57 PM
The inner cable always breaks right at the lever where it gets bent back-and-forth every time you open the trunk. It never breaks at the latch in the trunk or somewhere in-between.
Try gripping the cable sheath with a pair of vise grips so that you pinch the sheath enough to grip the inner cable. Then push forward. Try gripping it as far rearward as you can reach, so the sheath can curve as you compress it against the lever. You will be moving both the outer sheath and inner cable, but that's OK - the latch should pop.
nick11179 07-02-2015 02:09 PM
Just tried it. It is definitely broken somewhere else than the latch. I pulled with a pair of vice grips and just got more and more cable coming out... any other ideas?
Vintre 07-02-2015 02:16 PM
4 Attachment(s)
Thats a bummer.
You could build this tool and go from underneath. Below the latch, on the underside of the car, you will see a hole. You fish around up there and unlatch the trunk.
Attachment 818201
I didnt have the tool and tried for hours unsuccessfully.
Then I took a drill and opened the trunk in 10 mins. Once you have drilled the hole, stick a screwdriver in and open the latch.
Attachment 818209
Attachment 818217
Here is a picture of the latch.
Attachment 818225
You cant see the hole once your license plate is on anyways.
Good luck.
Vin
nick11179 07-02-2015 02:23 PM
I'll try to make one out of some heavy duty wire... Thanks for the great pics. I will post back soon with progress... or most likely failure haha Alfa's are such lovely things.
Vintre 07-02-2015 02:43 PM
You will never be able to push the latch open with wire. You need steel rod.
Best of luck.
I know you will get into the trunk one way or another.
The usual suppliers carry replacement cables once you do open it and replacing isnt too difficult.
Vin
VeloceDuetto 07-02-2015 02:45 PM
Hi Nick,
I'll second the idea of drilling the hole behind the license plate. My cable has broken twice - once at the inside release handle and once about half way in between the release and the lock. As Vin said, once you've got the license plate on, no one will ever know it's there. Just be sure to carry (INSIDE the car - not inside the trunk) whatever type of tool is needed to remove your license plate and a long, skinny screwdriver to stick inside the hole you've drilled in order to pop the latch.
David
nick11179 07-04-2015 07:05 AM
Hole worked! Thanks everyone. Had to jimmy the lock a bit but it popped open after a few tries.
