Just brought home 1974 2000 Spider - Page 3 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #31 of 39 (permalink) Old 09-28-2016, 02:49 PM
alfaman's Avatar
Richard..when you get a chance could you post or send me a pic of the duetto hardtop....I'm not sure the one I have is factory or not...some say yes...some say no
http://www.alfabb.com/bb/forums/spid...and-value.html
69gtv likes this.
1969 spider
alfaman is offline
post #32 of 39 (permalink) Old 09-28-2016, 05:22 PM Thread Starter
lm2504me's Avatar
Hardtop
Here are some photos.
You should post some photos of your top also.
Richard
1974 Spider USA AR3045799 Red/Black
1978 Ferrari 308 GTS #26355 Red/Tan
lm2504me is offline
post #33 of 39 (permalink) Old 09-28-2016, 05:24 PM
alfaman's Avatar
thanks!
alfaman is offline
post #34 of 39 (permalink) Old 11-30-2016, 02:31 PM Thread Starter
lm2504me's Avatar
Removing items from engine compartment and cleaning up.
It appears battery blew its acid on the drive side engine compartment and underneath the hood in the same side.
Also, brake fluid spillage made for some lifting paint.
I will have to remove brake booster and pedal assembly (rotated pedal assembly clockwise 45 degrees to remove).
Steering box will be next.
I just bought a 40DC0E2 for 150.00 to pair with my other 40DCOE2 to use for this Alfa.
Richard
lm2504me is offline
post #35 of 39 (permalink) Old 11-30-2016, 09:07 PM
kcabpilot's Avatar
Yes pull that Burman box, it's almost guaranteed to be cracked. It was one of the things I neglected to do when I did the restoration on my '72. Took it down the road for the first test drive with all new suspension components and tires and when I pulled a u-turm BAM! - busted wide open. I replaced it with a ZF out of a later Spider and I can tell you with the engine in that thing just barely comes out of there.
Paul - 1972 Spider - (2)1991 164S's - 1983 308 - 2001 Discovery - 1997 F350
kcabpilot is online now
post #36 of 39 (permalink) Old 12-01-2016, 05:59 AM
gigem75's Avatar
That's a nifty way to block off the brake lines
currently
2017 Giulia Q4
74 GTV restored daily driver
the ones that got away:
1962 Giulietta Spider normale
1965 Giulia Sprint normale
1972 GTV
1974 GTV
1974 GTV
1977 Spider
1974 Spider
gigem75 is offline
post #37 of 39 (permalink) Old 12-01-2016, 06:21 AM Thread Starter
lm2504me's Avatar
Thanks... I use this until ready to remove the brake lines, then I use rubber vacuum caps to seal them off after flushing some 99% Isopropyl alcohol through them.
I will be removing the lines for the engine compartment paint work.
I will end up flushing all the lines. The spider sat for over 20 years with same brake fluid.
I will also have to flush the engine block coolant channels to remove the crud left from sitting with coolant for over 20 years in the garage.
I plan to flush it for several days with the appropriate cleaning agents to remove the crud.
Richard
lm2504me is offline
post #38 of 39 (permalink) Old 12-01-2016, 06:47 AM
years ago i bought a 1300 duetto that came with the hard top & these beautiful 5 spoke personal wheels
traded top for canvis top
gentleman that bought it had his spider redone one of the best cars north of the border if prices keep climbing he may get what he out into it
10yrsalfter is offline
post #39 of 39 (permalink) Old 06-16-2019, 08:28 PM Thread Starter
lm2504me's Avatar
Red face
Two and a half years later.... I am going to start on my 74 Alfa with 60k miles.
I spent 2018 getting my Ferrari to Platinum award.
Plan is for new exterior and engine compartment paint, seat coverings, brakes, tires, etc.
I still need to remove the soft top attachments to body, door handles, and door window trim.
Making phone calls to body shops tomorrow to get some estimates.
This will be my wife's Italian car for Alfa events.
Richard
lm2504me is offline
