Embarrassing Confession - Alfa Romeo Bulletin Board & Forums
post #1 of 26 (permalink) Old 04-27-2007, 07:44 AM Thread Starter
BB Janitor
ghnl's Avatar
OK, I have an embarressing confession to make. It took me 3 days of on & off searching to figure out the simple reason why our '84 Spider wasn't running right.
The symptoms began rather quickly - idle became rough, idle speed dropped from 950 to 650 rpm, and it would stumble on initial throttle opening. Once revved up to 2500+ rpm it would pull strongly to 5500.
My first thought was vacuum leak. I checked the intake air ducts and all the hoses. Didn't find anything amis.
I pulled the spark plug wires one by one and found that removing the #1 plug wire didn't make the idle worse. Removing any other spark plug wire did. I cleaned the spark plugs and swapped their locations - no change. I swapped plug wires - no change. I even replaced the cap & rotor (even though I had verified a good spark to #1). No change.
I checked compression. Good - 175 to 180 psi in all cylinders. Valve clearances all correct. I cleaned & tightened grounds.
Now I was thinking maybe I had a faulty fuel injector. I had sent them out for cleaning last year when I rebuilt the motor. Rather than just replace the injector I removed the fuel rail with injectors and had my able (and beautiful...) assistant crank the engine while I watched. All the injectors appeared to spray equally well. And not spray when they shouldn't.
Finally, with increasing desperation I decided to remove the oil vapor separator and clean it out (although I had done so last year before installing the rebuilt engine and didn't expect it to be gunked up).
Only when I removed the large hose at the top of the separator did I discover that the smaller hose - the one that goes to the intake plenum near cylinder #1 - was loose! It was near the fitting on the separator and looked OK but it wasn't snuggly attached. I know I had checked the plenum end. And looked at the separator end. But since my fat mitts wouldn't fit down in there, I hadn't actually tested that it really was attached. arggh!
Put everything back together and it immediately ran correctly.
- - Eric
don't read this
~ 1984 Spider Veloce ~
- -~ 1981 GTV-6 ~
Mebane, North Carolina
ghnl is online now
post #2 of 26 (permalink) Old 04-27-2007, 08:56 AM
the_sicilian's Avatar
Send a message via AIM to the_sicilian
thanks alot for the headsup and illustration sir
/////////////////////////////////////////////////The Sicilian ~ Guido
1990 Spider motronic
1974 Spider 1750
Los Angeles, CA
If your wife has ever had to say, "hey move this thermostatic actuator so i can make dinner"...you might be an alfisti.
the_sicilian is offline
post #3 of 26 (permalink) Old 04-27-2007, 10:37 AM
Very good point. People often overlook air leaks from the air/oil separator. Those are just as bad as air leaks anywhere else. Even a loose fitting dipstick can cause a minor air leak. If you don't believe me, remove the dipstick at idle and note the change.
Greg Gordon is offline
post #4 of 26 (permalink) Old 04-27-2007, 11:45 AM
Thanks for sharing your experience!
Duke
Duke58 is offline
post #5 of 26 (permalink) Old 04-27-2007, 04:36 PM
I have the intake plenum off for starter removal, and while cleaning the plenum I noticed that the fitting which that small hose connects to was completely plugged with krud.
Bob Ferg
Robert Ferguson is offline
post #6 of 26 (permalink) Old 04-27-2007, 05:54 PM
I'll have to try that, as my dipstick gromet is quite loose! Thanks!
Joe Papa Sr is offline
post #7 of 26 (permalink) Old 04-27-2007, 05:57 PM
Bob Ferg
(hehe)...is krud the german equivalent of crud? Bad stuff either way!! And you can always expect some in that oil separator....
post #8 of 26 (permalink) Old 04-28-2007, 11:21 AM
MrT
MrT's Avatar
When we were troubleshooting our '86 Spider Graduate, I checked for air-tightness overall on the block and hoses by blowing into one of the small diameter hoses on the intake manifold. The large volume of the system means you can stuff a few cubic inches of air into it and then block off the hose with your finger to listen for small leaks elsewhere. If you have someone else with you, you can track down leaks you wouldn't find by yourself. We found a broken oil return line from the separater that way. Before fixing this line, the block would hold zero pressure. After fixing it, I could blow a few cc's (maybe) of air into the block and it would come back out a few seconds later when I took my finger off the hose. The system would hold NO overpressure even as long as a second before replacing that hose. So you can do a check that tells you whether 1) Everything Is Tight or 2) Something Is Leaking in the manner described. Finding what Isn't Tight is still the problem, but knowing that everything is OK is a worthwhile thing.
Michael
MrT is offline
post #9 of 26 (permalink) Old 04-28-2007, 08:54 PM
redspiderveloce's Avatar
I'm glad you found the problem. I never would have thought that one of those hoses would cause the car not to start.
1984 Spider Veloce
1987 Spider Quadrifoglio
redspiderveloce is offline
post #10 of 26 (permalink) Old 04-29-2007, 06:14 AM
MrT
MrT's Avatar
Wellll. the hole in the hose didn't actually keep _our_ car from running. I was just recounting a debugging technique that I had used successfully for checking on LJet hose systems. That car's problem ultimately turned out to be that a P.O. had over-leaned the AFM and the car was running chronically lean. He _may_ have been trying to enrich the mixture, but it ended up lean. Greg Gordon's LJet pages pointed me in the right directions for fixing our problem, and along the way I used the "is it tight" test I mentioned above. It wasn't, but I made it so. However, tightening it up didn't help much.
Michael
MrT is offline
post #11 of 26 (permalink) Old 04-30-2007, 05:01 AM
That's OK, I once rebuilt a Sirroco engine because of a loose carburator screw.
Mike
mrutkaus is offline
post #12 of 26 (permalink) Old 05-05-2007, 09:02 AM
WIP
Any good tips to keeping the dip stick in place... I have an '84... after driving so many miles, I'll get an occassional hard start (not really a big deal, but noticable)... look under the hood, yup, dipstick has popped up half an inch or so... push it down again... more 2-3 second crank... cranks immediately. Now, how to keep it down. (-;
Ron
'84 Spider Veloce
Arizona
WIP is offline
post #13 of 26 (permalink) Old 05-05-2007, 09:08 AM
velocedoc's Avatar
Location: located "almost" at the geographic center of Arizona +/- a few miles
Good description of how you traced all of the possibilities. Everything has to be secure.
side note: Our spider wouldn't idle when I first put it on the road and was blowing oil out the bottom of the air box. Turns out that the oil separator was plugged full of junk. Fixed it (1/2 hour of tapping to get it all out) and checked the oil return line and now everything is perfect.
velocedoc is online now
post #14 of 26 (permalink) Old 05-15-2007, 02:36 PM Thread Starter
BB Janitor
ghnl's Avatar
Thanks for this tip.
After fixing the loose hose mentioned in the first post, our Spider ran much better but it still wasn't right. I kept searching for another fault. I felt certain it was an intake/vacuum leak but couldn't find it. Finally, I remembered your reply about pressurizing the engine to help locate a leak.
I hooked up an air line to a spare piece of fuel hose (because I had piece lying around). The OD of the fuel hose was just right to fit the ID of the dipstick tube. I lowered the air line pressure to less than 10psi and stuck the hose into the dipstick tube. I left the oil cap (aka OLIO cap) off to avoid over-pressurizing the block and blowing out a gasket to something.
Then, using a 2 foot long piece of 1/2" ID heater hose as a 'stethoscope' (because that's what I had lying around) I listened to various possible areas of potential leaks. When I had the 'stethoscope' in place, I'd put the palm of my hand over the oil fill to block the escape of air thus pressurizing the block.
Here's what I found: There was a fault in the black, plastic air duct at one of the mounting tabs - where it bolts to the cam cover. The tab is so far away from the air flow path I didn't initially suspect a leak there. It appears the duct is made in two pieces and then the halfs joined together. The split was between the two halfs of the tab. Maybe the pictures below will help explain.
I cleaned it out and used Greg Gordan's 'Shoo Goo' method to repair it (although I used silicone sealer) by filling up the space on the inside of the duct.
- - Eric
don't read this
- -~ 1981 GTV-6 ~
ghnl is online now
post #15 of 26 (permalink) Old 05-15-2007, 02:50 PM
MrT
MrT's Avatar
But you didn't say whether it actually helped! So. Are you "on the road again?"
Michael (gleeful at being of some actual help to some actual person)
(_Nice_ pics, by the way.)
MrT is offline
