Changed starter and S3 won't start - Page 2 - Alfa Romeo Bulletin Board & Forums
 1Likes
post #16 of 18 (permalink) Old 02-15-2015, 06:56 PM
65Sprint's Avatar
Originally Posted by bongju View Post
For a permanent solution, does anyone know where I can purchase a connector for the CTS?
A few years ago I bought several of these:
CONN-85660 GM Delphi / Packard - Bosch EV1 Type Injector Connector Pigtail Push to seat $5.99
From Ballenger Motorsports - High Performance Electronics.
No problems splicing these into the existing harness, soldering, and sealing with shrink wrap. These have the newer type wire retaining clip and are a lot easier to remove and replace than the original connectors.
Rich Hanning
65Sprint is offline
post #17 of 18 (permalink) Old 02-15-2015, 07:29 PM
vf31rhill's Avatar
Originally Posted by sloboy89 View Post
FWIW, I spliced in new connectors on my flywheel sensors with no problems (so far at least). I unbraided about an inch and a half of the braided shielding, wound it together, and connected that to the ground pin.
Those are coaxial cables (as Eric says, like TV antenna cables) and they can be successfully spliced or repaired. Fortunately I was taught how to properly repair coaxial cables while in USN aviation advanced electronics school during the Vietnam War. It has come in handy a few times working on depth sounders on US Coast Guard small craft. And maybe on an Alfa some day.
The trick is to get a good connection on the center conductor and then get 100% circumferance repair on the outer braided shield. Once in a pinch I used a piece of someones lunch sandwich aluminum foil to repair the outer shield on a depth sounder. Definately NOT recommended but it lasted several months until a replacement coax could be ordered in.
[FONT="Times New Roman"][SIZE="2"][/SIZE][/FONT]
Robert
various Alfa Romeo Spiders, current 1988 Quad (Red)
various MGs
Various Jaguar
vf31rhill is offline
post #18 of 18 (permalink) Old 02-15-2015, 08:49 PM
sloboy89's Avatar
You are correct, they are coaxial cables. To be effective, the outer braided shielding needs to have a voltage applied or be connected to ground. Unlike television cable, however, the flywheel sensors in the Alfa don't use the familiar cable TV coaxial connectors, which provide a conductive connection through the threads. The flywheel sensors have a three-pin connector, so you need to connect the braided shield to the appropriate pin.
A common way to make this connection is exactly as I described -- unbraiding a portion of the shield and connecting it to the pin. In fact, the technique that I used is shown in this photo from the Wikipedia page for coaxial cable:
Rich
'85 Spider Veloce
'17 Giulia Ti Sport
sloboy89 is offline
